01-02-2024, 07:39 PM | #1 |
Rep 56
M240i Dislikes
Hello!
It's been around 6 months since I took ownership of my 2023 BMW M240i and it's been a wild ride. I thought I'd take some time to go over my personal dislikes of the vehicle and I'd like to hear others thoughts as well. Please note, this is not a hate post, I absolutely love the car and wouldn't choose any other vehicle, this is simply for discussion and feedback. Cons - Shutting the door of the vehicle can be a little hard at times for someone who doesn't want their car door slammed or damaged or for someone who wants to preserve their vehicle as much as possible, I find that due to the weight of the door and it's length, it's tough to softly close the door in most situations. - The climate control (while visually pleasing within the infotainment) is tough to use while driving, I prefer physical buttons or knobs, one of my biggest grips about the climate control in iDrive 8 is the fact that you're setting a specific degree (either hot or cold), I'm not sure what BMW was thinking when designing the UI but I don't think anyone would ever say "I want to be 27.5 degrees hot.", I think having a couple options such as low, medium, or high would be preferred instead of specific temperatures. - The windshield wipers don't extend to the full length (horizontally) of the window, therefore, it's often dirty on the edges of the window, nothing a quick wipe can't fix. - The button to release the trunk hatch is kind of useless in my opinion as the trunk is not automatic, I don't see much of a point in unlocking the hatch with the key fob or the drivers side button. - When in sport mode and slamming the pedal, or just driving semi-fast, the car doesn't shift as fast as it should, often leading to really high rpms before the shift, therefore, you need to rely on the paddle shifters a lot for faster driving. - I was disappointed when I discovered that purple is no longer an ambient lighting option in the 2023 models, I really wanted Thundernight Metallic paint with purple ambient light but it's not possible without third-party coding. I don't know why BMW would remove this color or not just give us full rgb control, on top of this, the ambient lights are a bit dim. - When using Apple Car Play with low fuel, you need to press the next or previous button on the steering wheel twice in order to switch songs, I believe this is because it dismisses the warning first, however, I'm sure this can be switched off somewhere in the settings but I haven't bothered to look around. |
01-03-2024, 02:04 PM | #2 | |
Rep 425
The lack of steering feel; The “thump” sound when using sport dampening; Sunroof not opening fully |
THDRNIGHT111.50 |
01-03-2024, 05:18 PM | #3 |
Rep 542
I don’t like that I have to look at the back of other, boring cars whilst everyone else gets to enjoy the view of my Thundernight 2 series coupe.
14
TJZ67201874.50 Bandit009384.50 darkvader0144.00 ThunderM240134.00 THDRNIGHT111.50 jpf34012.00 liondog2.00 aiursblade81.00 V series7.50 sk8funk174.50 Invisiblename359.50 zzt4225.50 blueshead125.50 PP3121373.00 |
01-03-2024, 06:58 PM | #4 |
Rep 160
I got to follow one yesterday for the first time....Car does look fine from the rear !! Not sure if the driver took a long look in the rear view mirror at mine....I wouldn't mind that view either 😁
Current: 2022 M240i X-Drive Thundernight
Previous: 2014 435i M-Sport Estoril Blue PCD 5/20/14 2007 335i ED 4/13/07 2003 325i |
Evilmoretea275.00 |
01-03-2024, 07:02 PM | #5 |
Rep 542
01-03-2024, 07:48 PM | #6 |
Rep 425
The long hood with the power dome and they didn’t bastardize the grill. Also, larger rear quarter panels show nice.
01-04-2024, 12:17 AM | #7 |
Rep 36
For my 2023 with xDrive:
The main dislike is the weight, this car weighs as much as a F32 440i xDrive. No lane-centering driving available (opposed to just lane-keeping warning/input), both my F150 and GTI have these and work flawlessly. Haven't found the way to permanently disable start/stop. The runflats are terrible, replacing the tires is the one upgrade I'm most looking forward to do. The car is too quiet even with an aftermarket catted downpipe. Noise coming from the rear suspension, already a thread going on it. I wish I could have option it without a sunroof. Wish it had: an oil dipstick, e-brake handle, shifter knob like on the 2022 car. Otherwise there's a lot to like about the car. I understand where the heft comes from, BMW listening to their owners, making the car more refined and adding a bunch of noise insulation. The problem is that the 2-series is supposed to be the fun one, and adding weight is a sure wait to kill that fun factor. Even the M2 got really heavy, those days of pointing at Mustang owners and laughing at their heavy 3800+ lbs cars are gone.
Drives: 2023 M240i xDrive, 2022 F150 2.7EB
Past: F30 340i, C5 Z06, C7 Z51, Fiesta ST, Explorer ST, FA24 BRZ, SVT Focus, NA Miata (x2), 2.7L F150 (x4), Mk5 - Mk8 GTI (x8) |
01-04-2024, 02:41 AM | #8 |
G42 B58 C56
63
Rep 57
Overall very pleased, but my dislikes ...
01-04-2024, 03:58 AM | #9 |
Rep 3
I was going to add the sunroof option to my build so can you tell me s bit more about this - do you mean it only slides say half way? Does it tilt? Is there a 'roof-panel' to close out the sunroof and does this slide with the glass, or can it be removed?
Thanks. |
01-04-2024, 09:55 AM | #10 |
Rep 425
[QUOTE=GavinK;30783336]I was going to add the sunroof option to my build so can you tell me s bit more about this - do you mean it only slides say half way? Does it tilt? Is there a 'roof-panel' to close out the sunroof and does this slide with the glass, or can it be removed?
Thanks. 1) only slides halfway into roof. With my older BMW the glass fully retracted. When the sunroof is closed the amount of glass is larger than my prior BMW. However, when retracted the 240i only retracts about 1/2 way. 2) yes, the sunroof tilts 3) yes there is a “roof panel” that can be retracted and closed separately from the sunroof. |
01-04-2024, 01:20 PM | #11 | |
Rep 151
I ordered my 2022 with lane assist even though I knew full well that I wouldn't be using it that much. When I have tried it, I found it to be next to useless. A warning isn't activated until you are practically off the road! Two cars ago, I had an Accord Touring that kept me perfectly centered on the road— and for those rare times when I needed it, it was absolutely AWESOME. Don't even get me started on the rear suspension noise— if that's indeed what it is. No one seems to know. Is it the dampers? Is it the rear deck? It blows my mind, and there's not a day that goes by when it doesn't aggravate me. Sounds like a tiny Kyrie Irving dribbling a basketball inside a wooden box in my trunk. I thought I'd get used to it. Nope. I brought it to the dealer sometime last year. Drove it with the service manager and neither of us could hear anything on that occasion. Of course I heard it on the way home... |
01-04-2024, 02:44 PM | #12 | |
Rep 425
01-04-2024, 03:07 PM | #13 | ||||||||||
Rep 2,539
I like it - currently sitting at 21.5c and in summer I’m usually at 17.5c. I thought I’d be fussed about virtual buttons but climate control is usually set and forget for me. I do miss the fresh air mix dial that previous models had though. Quote:
I honestly think, if they didn’t publish the weight no one would really care. It’s still what? 220bhp per tonne? It’s not as I’ve you have to physically push it. Quote:
People get very hung up on this. Quote:
And the sport seats Quote:
You can select a different profile in the idrive but the idea is each driver has their own BMW id and key They are also trying to promote virtual keys. Quote:
I guess I should add my gripes to the thread… Front seats are glacially slow in moving when accessing the rear seats. The idrive sometimes defaults to the nav screen from the map screen on start up. The side menu options don’t always disappear. I’ve also noticed the radio sometimes reverts to all stations rather than maintaining saved stations as the prime selection. Idrive display is too bright at night. HUD should sit a little lower on the windscreen No internal boot release button or foot slip opening option. Standard M badges in front seats are tacky. I’ve replaced with the illuminated M badges Seat backs are plastic tat. I’ve replaced mine with alcantera / carbon seat backs. Standard floor mats are cheap rubbish. |
01-04-2024, 08:33 PM | #14 |
Rep 2,127
The HUD isn’t perfectly centered, I should have cancelled my order on delivery day.
Evilmoretea275.00 |
01-04-2024, 08:50 PM | #15 |
Rep 3
01-04-2024, 09:23 PM | #16 | |
Rep 56
01-05-2024, 03:06 AM | #17 | |
Rep 2,539
On the M240i, the sunroof doesn’t retract all the way back into the roof so you don’t get the whole open roof benefit. You also have to maintain them. If they are not regularly opened, they can gunk up. I just felt this time it was a cost more than it was worth. (Oh and it adds weight ) |
01-05-2024, 07:07 AM | #18 | |
Rep 3
01-05-2024, 10:05 AM | #19 | |
Rep 2,539
01-05-2024, 10:21 AM | #20 |
Rep 323
Wish we had an option for sunroof delete in the states
This is only my opinion as I'm a retired professional ASE master grease monkey technician, now instructor. Your best teacher is your last mistake. Use what I post at your own risk as you know teachers only know book knowledge.
Jashue216.00 |
01-05-2024, 02:29 PM | #21 |
Rep 151
Tags |
bmw, bmw m240i, m240i |
