01-03-2024, 01:22 AM | #1 |
Rep 91
Coming from the F87 comp, the DCT sharpness was something I missed on this car. Granted the upshifts on this trans was just as fast, but the downshifts left a bit to be desired. Also a weird delay sometimes near redline.
To address this I initially thought of going XHP, but XHP has a lot of options to fiddle with and I am not looking at spending hours and hours fiddling with them to find what works for me. I want a fit it and forget it type of solution that works as smooth as stock, but adds a bit of a kick in the more aggressive settings. I do know XHP have some OTS maps, but even there some tweaking may be needed to get it right, from what I hear. Enter M4CSL transmission flash as an option. This got a lot of positive feedback on the M3/M4 forums and seemed like a safe choice considering its an OE map. Was in touch with kubax86 to flash this, he seems to have done many cars on this forum and seemed reliable so decided to go ahead with him. Paid him via PayPal and later that night he flashed the map remotely. Within the first KM of driving the car I knew this may not work for me. The M4CSL map is surprisingly aggressive and jerky even with the gearbox in its lowest setting. On an open road with the most aggressive settings it was violently fast and enjoyable, but the jerkiness and 'on it all the time' setting was not something I could have lived with in the long run. I spend 70% of my time in this car cruising to wherever good roads are to be 'on it' 30% of the time. So giving up the comfort during that 70% if the driving time was not something that made sense to me. After all, the whole benefit of the ZF is how smooth it can be for normal driving. To be fair kubax86 did mention that the M4CSL map is super aggressive and he suggested the M3 CS map instead which is smoother. In my head I was like I am hardcore Bro, coming from the previous DCT , not that hardcore after all, apparently So after an hour of driving it, we swapped to the M3 CS map. One of the main worries I had with this was that its designed for an XDrive car, but being the same transmission, it should work. So with the CS map flashed, I was back on the road and the car immediately felt similar to the stock car. I took it for a longer drive the next morning and managed to floor it a few times WOT, and it seemed like it was a touch quicker, but not by much vs stock. I tried launch control to see if it worked, but it didn't, I guess this is to be expected considering its launch control was designed for XDrive and this is RWD. Overall, the M3 CS map added some refinement and part throttle drivability back while being aggressive enough when WOT. Is it noticeable quicker/better than stock, I'm not entirely sure yet, maybe after some more driving I will get a better feel for it. From a timings perspective, I did a couple 100-200 runs and the numbers were exactly the same as stock, so no measurable difference there. Thanks to kubax86 for his patience, and service! Hope my experience helps others who may have been considering these. |
01-03-2024, 11:19 AM | #2 | |
Rep 4,518
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
01-03-2024, 05:01 PM | #4 |
Rep 3,057
you can check the pricing in my webstore (link in signature)
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
01-04-2024, 06:21 AM | #5 | |
Rep 91
So far I'm really liking the CS map, part throttle drivability seems a lot better than stock and smooth, yet responsive at all times. Will report back once I've had more time with it. |
Bee Pee1779.00 |
01-11-2024, 11:46 AM | #7 |
Rep 3,057
Ahmadg870.00 |
01-30-2024, 07:46 AM | #9 |
Rep 72
Is there a big difference with the steering? That's my biggest gripe with the car, I feel like I can run over a curb and not feel anything through the wheel.
