BMW M2 Forums 2023+ (G87) Marketplace Classifieds Sponsors Classifieds
      01-18-2024, 07:28 PM   #1
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Girodisc BMW G8X M2, M3, M4 380MM FRONT ROTORS
These GiroDisc 2-piece rotors are a direct replacement for the front rotors on the G80 M3, G82/83 M4, and G87 M2 without carbon ceramic brakes. Our 2-piece, fully floating assemblies help shed unsprung weight and rotating mass from the front axle of the vehicle.
The rotor rings are machined from a proprietary casting made of high-carbon steel formulated to GiroDisc’s specifications. This superior metallurgy results in a rotor that holds up better, and the 72 curved vanes act as a centrifugal pump pulling air in through the hub to effectively cool the rotors under hard use. The 2-piece design means a reusable hat which can be attached to new rings (part number D1-282) when they need to be replaced.
All major components including the hats, rotor rings, and drive pins are manufactured in-house at our facility in Bellingham, WA from domestically sourced materials. The hat is made from 6061-T6 aluminum and coated in a black anodize finish. The drive pins are made from a high-strength steel alloy and cadmium-plated for corrosion resistance. All rotors are assembled with spring clips and Belleville washers for race-ready float while also being street-friendly with no noise from loose hardware.
The minimum thickness at which we recommend replacing these rings is 34mm. We also recommend replacing them if a crack leads to the edge of the ring.
$1300 pair
https://hpautosport.com/product/bmw-...-front-rotors/
      01-31-2024, 06:18 PM   #2
HP Autosport
Drives: F80 M3
bump
      02-10-2024, 09:19 PM   #3
HP Autosport
Drives: F80 M3
bump
      02-16-2024, 04:52 PM   #4
HP Autosport
Drives: F80 M3
bump
      02-21-2024, 07:12 PM   #5
HP Autosport
Drives: F80 M3
bump
      02-28-2024, 05:01 PM   #6
HP Autosport
Drives: F80 M3
bump
      03-10-2024, 07:19 PM   #7
HP Autosport
Drives: F80 M3
bump
      03-16-2024, 10:30 PM   #8
HP Autosport
Drives: F80 M3
PM for quotes
      03-24-2024, 10:50 PM   #9
HP Autosport
Drives: F80 M3
bump
      03-29-2024, 04:49 PM   #10
HP Autosport
Drives: F80 M3
bump
      04-09-2024, 07:20 PM   #11
HP Autosport
Drives: F80 M3
bump
      04-14-2024, 06:51 PM   #12
HP Autosport
Drives: F80 M3
bump
      04-22-2024, 10:35 PM   #13
HP Autosport
Drives: F80 M3
bump
      04-23-2024, 08:19 PM   #14
HP Autosport
Drives: F80 M3
bump
      04-26-2024, 01:14 PM   #15
HP Autosport
Drives: F80 M3
PM for quote!
