BMW
X1 / X2
BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Android Head unit 12.3 inch
      01-19-2024, 06:18 PM   #1
limsheng
Drives: BMW X1
2016 BMW X1  [9.00]
Hi, asking this question as I’ve run out of ideas what made this. The right side toggle menu covered half of the screen even when it’s minimized.
When I ticked the option for ‘disabled full screen on car menu it’s became worse’.
      01-19-2024, 06:59 PM   #2
Homersbud
Drives: BMW X1
probably have more luck searching/posting at the thread below since it’s a Droid unit.
https://f30.bimmerpost.com/forums/sh....php?t=1832178
      01-21-2024, 03:31 AM   #3
X1604M
X1604M's Avatar
Drives: 2018, F48 28i
2018 BMW X1 F48  [0.00]
You need to give more information.
How did it happen?
Was is showing full screen before ?
Did you change any settings on Android screen settings or idrive settings?
So that others can think of the possible causes.
I will suggest doing the followings.
Performing factory reset on the android screen.
In the factory settings. You can change the screen resolution one after another to see if it comes back to full screen.
Another thing is you can use Bimmercode in expert mode
HU NBT 3005 display_pip_config
Change CID_Display_res
Change CID_Display_size
You will have to change one at a time and see if the display comes back to normal.
When using Bimmercode try to choose your android screen resolution and 10.5 for the display size. You won't find 12.3 inch in display size.
Those are the things I will check first.
Good luck.
      01-21-2024, 09:17 AM   #4
ziza47
Switzerland
Drives: BMW X1
I had the same issue. Bimmercode support suggests using e-sys.
With e-sys changing the same keys made an immediate effect.
      01-21-2024, 10:19 AM   #5
limsheng
Drives: BMW X1
2016 BMW X1  [9.00]
Hi, thanks for replying. As per referred I went to the android thread and followed the discord channel to find some answers.
Basically if I was having a ksw system it would be much easier for the android factory settings to choose screen size, resolution, extended screen etc.
But mine came from different seller and software version where they had a default right side toggle menu with 3 icons (Navi,car,music) which are useless to me. I assumed that the right toggle menu is a default app that will take up the extended screen and can’t be switched off.
I’ve tried all the settings starting with coding the HU with 6.5, 8, 10 inch. After that with android factory settings. The automatic setting worked easier so I won’t have some funny zoomed images.
I’ve attached the software version and I’ll think I’ll put up the seller link for info as well.
the HU link
I’ve ticked the split screen checkbox for now so the menu list will keep to the left.
      03-22-2024, 09:21 AM   #6
limsheng
Drives: BMW X1
2016 BMW X1  [9.00]
I finally did it!
I’m crying with joy
      03-22-2024, 12:00 PM   #7
X1604M
X1604M's Avatar
Glad to hear you did it. What did you do? I am just curious.
      03-22-2024, 11:34 PM   #8
limsheng
Drives: BMW X1
2016 BMW X1  [9.00]
I did just this. I wasn’t using e-sys until yesterday. Managed to install e-sys and used BimmerUtility as launcher. Has zero idea how to use e-sys. Followed some guide online and the ncd editor were all dots.
Lucky to have the BU pops up its own window so I searched the display resolution and variante. Literally just changed 2 coding and back to e-sys click on the code ncd, tada! It worked just like that.
My previous anxiety and misery were all for nothing haha.
But I still need to find out how to view all the dots in e-sys
      03-29-2024, 10:31 PM   #9
jwzubieta
Drives: 2017 BMW X1 M Sport
What screen did you buy/install? I’ve been looking to do this to my X1, but many of the larger screens come with their own UI. I’m hoping to keep the iDrive (like yours seems to), but add CarPlay and a touchscreen…
Any recommendations? Thank you!
      03-31-2024, 01:31 AM   #10
limsheng
Drives: BMW X1
2016 BMW X1  [9.00]
Hi, well honestly it’s good to have some views around different models and sellers. And make sure you get good customer support if it’s from AliExpress.
Mine was okay-ish in my opinion, the seller was responsive but they are not bmw experts. The firmware, UI are all from third party engineer I think. Don’t buy mine, I’m still not pleased they advertised different firmware and so called “ID8” tacho screen but I get rubbish screen instead.
You might have heard of KSW firmware those are reliable and lots of experts in the community if you need help.
Another one I saw is Hifimax from Paul he’s active on YouTube you can do a search. Recently he launched a new model which got thinner bezel and lighter! How I wish id buy that instead. You can contact Paul by any means. He replied my questions even though I buy nothing from him. Good guy!
xbimmers
