01-22-2024, 02:22 PM | #1 |
Rep 691
Normal Engine Temp Range?
I have a mishi plate plus stradale design side and center cooling guards and have noticed on a few occasions the oil temp will get a few "notches" above the midline 210F point- never more than 1/3 of the way up the third bar, but still higher than the midpoint. First few times was when i was running backroads pretty hard, and then again this weekend running up to the mountains and back cruising in 6th gear at approx 80 mph. Is this normal, or something i need to look into? It happened both in comfort, and in "sport" mode on the engine.
if i backed off on the load, it would come back down, but i was surprised to see it go above the midpoint considering ambient temps were approx 20F |
01-23-2024, 07:37 PM | #2 |
Rep 95
There shouldn't be that much of a change in airflow with those mods. If you're in sport or track display modes and use the info screen for the infotainment display, you can get a larger/clearer read-out of the exact engine temps. 210-220 is generally what I observe. If there's less air flow and I'm holding high revs, then it'll creep up more.
I'm also not sure if the car keeps things a bit warmer, considering it was below freezing ambient. I do know this car performs amazingly at high speeds; on the track during hot laps, the oil temps fall into the 190F range. |
two_three_two1123.00 |
01-23-2024, 07:53 PM | #3 | |
Rep 691
01-25-2024, 03:59 PM | #4 | |
Rep 95
The car will of course warn you if its toasty and I'm sure it'll be logged for a tech to read. |
01-26-2024, 08:06 AM | #5 | |
Rep 1,432
But the oil temperature and coolant temperature appears to be quite under control. See pics. Note ambient temperature is 100F. Pics taken August 23, 2023 at 5:18pm. The coolant temperature is quite low. What I have observed is when I give the engine the whip the coolant temperature goes down. That is about as low as I have seen it go. If I resume normal driving the temperature climbs back up to nominal at or just a tiny bit above the 210F point. I have used voice command to query the car for the oil temperature. IIRC it was like this: Press the microphone button on the steering wheel. "Hey BMW. What is the engine oil temperature?" Tried this with coolant in place of oil and the system did not respond. |
03-14-2024, 08:14 PM | #6 | |
Rep 47
I live in the desert where the summers get over 100 and I plan on running higher boost with other mods (intakes, full exhaust and downpipes) so I'll need to the engine to be operating efficiently. as such, I'm seriously considering getting a high performance engine oil cooler. But I might be overreacting as I do remember it was completely normal and fine for my f80 and f80 cs to go slightly above mid. |
03-15-2024, 09:08 AM | #7 | |
Rep 1,432
I will mention the highest oil temperatures I saw with my Hellcat (supercharged V8 making 707hp) were during just town driving. Oil temperature approached 240F. (Pretty much observed the same oil temperature behavior from my Scat Pack with a N/A engine making 485hp.) But once on the freeway oil temperature dropped to around 200F. But with my M2 oil temperature around town or on the freeway remains pretty darn steady. And as I covered in a previous post when I push the M2 hard coolant temperature drops. But I do not see real increase or decrease in oil temperature. It would appear BMW has some real sophisticated engine cooling technology in play. |
03-15-2024, 09:32 AM | #8 |
Rep 821
Seems to be variable speed water pump that they have been using for a number of years. The cooling behavior you talk about is same I see on my 135i.
03-15-2024, 12:47 PM | #9 | |
Rep 47
It funny bc my 911 turbo has 700 hp and tq and never ticks over mid on the engine oil even when its 110 out during hard push. Porsches just built different I guess. |
03-15-2024, 01:01 PM | #10 |
Car Geek
4129
Rep 3,828
The S58 seems to have gone back to a fixed displacement mechanical pump for the main engine cooling circuit, but the sophisticated cooling management is from a combination of the flow redirection by the heat management module (effectively a sophisticated thermostat) and the variable flows through the turbo cooling circuit and passenger compartment circuit electric pumps. (see P81 of https://www.bimmerpost.com/goodiesfo...S58-Engine.pdf).
Albator_IIII1053.50 TallGibbs203.00 |
03-15-2024, 01:35 PM | #11 | |
Car Geek
4129
Rep 3,828
Albator_IIII1053.50 two_three_two1123.00 |
03-15-2024, 02:14 PM | #13 | |
Rep 47
07-11-2024, 06:09 AM | #14 | |
Rep 170
Car History (oldest to newest): Accord, 318i, 330i, Prius, Prius, M2
aerobod4129.00 two_three_two1123.00 |
07-11-2024, 09:00 AM | #15 |
Rep 170
Based on the manual that was shared there is a really nice page #66 showing the operating ranges for the engine oil cooler thermostat. You can see below 212F the thermostat does not even open (so no oil to the cooler).
azv31113.50 two_three_two1123.00 |
