      01-29-2024, 05:34 PM   #1
TheBatM2
TheBatM2's Avatar
325
Drives: 2023 BMW M3C, Individual DBB
Help - Yellow Bug Splatter not coming off
Folks, I have ‘23 M3C in Daytona Beach Blue with Full Frontal PPF and whole body ceramic coating. Recently I encountered a significantly large dead bug with yellow residue. I think it must have stayed on for about 4-5 days before I tried cleaning it. I’m have tried everything but this yellow stain is not coming off. I’m in NW Houston.
Methods used:
- Soap and Water
- Alcohol Rub
- Warm water rub
- Grease Off Paste
Any ideas?
      01-29-2024, 08:04 PM   #2
jg4c
jg4c's Avatar
452
Drives: 2022 M340i XDrive
I’d try ScratchX. Very lightly applied.
Might have deeply stained the PPF.
If nothing works, back to the professional detailer.
Beautiful color, btw.
      01-29-2024, 08:39 PM   #3
to_riffic
to_riffic's Avatar
Drives: rwd
Maybe try Gyeon Q²M Bug & Grime?
~loud noises~
      01-30-2024, 05:34 AM   #4
DubaiRich
Drives: 2010 Z4; 2008 118D
2010 BMW Z4  [8.17]
That looks etched into the PPF. I've had good results with Simple Green to remove bug splatter. but nothing that etched.
      01-30-2024, 05:36 AM   #5
disintegrator66
disintegrator66's Avatar
Drives: '18 340i M-Sport 6MT THP MPPSK
Here's your huckleberry...... if it's stuck on this will take it off!
      01-30-2024, 08:43 AM   #6
///MPhatic
Drives: OG M2 • Exige
2018 BMW M2  [9.22]
I use PPG SX330, it's what paint shops use before they start sanding the car. It's safe on PPF though. It's a bit expensive, but I use it for so many things (ever get tar in jeans? It'll take it out) that I don't mind buying some once a year.
https://www.oreillyauto.com/detail/c...r/ppga/sx330qt
If that doesn't work then a light buffing compound might do the trick.
Before using either of these though, I'd call a PPF installer and get their take.
      01-30-2024, 08:58 AM   #7
Autoaddict
Autoaddict's Avatar
Drives: 2008 BMW 328xi Sportwagon, G80
I use P&S Bug Off. I used this on the front of our minivan after a trip through the Carolina mountains. The front was blasted by bugs. I sprayed this, let it dwell, then sprayed Koch Chemie foam, and then power washed it off. The bugs literally melted away.
ROASTM163.50
      01-30-2024, 11:28 AM   #8
aa2033
aa2033's Avatar
381
Drives: 2018 BMW M3
I dealt with this on my old PPF. Certain PPF's just stain easier than others, and if it was on the car for a few days, it likely etched into the ppf. It is very difficult to polish PPF correctly and not ruin the self healing properties, burn through the ppf, or haze it in general.
When this happened to me, i tried a handful of different products and what worked best was Gyeon PPF renew. I applied it by hand, but eventually had to use a polisher on low speed. It got 90% of it out.
https://gyeonusa.com/products/q-m-ppf-renew
      01-30-2024, 12:21 PM   #9
TR930
Car Enthusiast
Drives: 2016 F80 M3 TB/AB
Wd 40
      01-30-2024, 12:41 PM   #10
TheBatM2
TheBatM2's Avatar
325
Thank you for the feedback and suggestions. It might be that the ceramic coating is stained, and polishing it gently may remove that coating itself. Will tryout a couple of different ways to remove this based on your recommendations.
Thank you once again.
      01-30-2024, 12:43 PM   #11
TheBatM2
TheBatM2's Avatar
325
Originally Posted by TR930 View Post
Wd 40
Is it PPF and ceramic coating safe?
      01-30-2024, 06:00 PM   #12
Westside Guy
Westside Guy's Avatar
7597
Drives: 22 Z4 M40i, 21 228i Retired
Why aren’t you going to the shop that installed the PPF and ceramic? Let the pros handle the issue.
      01-30-2024, 06:14 PM   #13
jkoral
Drives: 2017 M2 LBB 6MT
+1.
Had to look for better pictures (sans bug stain):
https://g80.bimmerpost.com/forums/sh....php?t=1996399
      02-05-2024, 02:35 PM   #14
TheBatM2
TheBatM2's Avatar
325
I’m on their schedule. Installer’s recommendation is to polish the spot hoping to remove it, and the re-ceramic coat it. I’ve heard all sorts of things about polishing a PPF, some not so good. It’s a Suntek Ultra PPF film.
      02-05-2024, 02:38 PM   #15
TheBatM2
TheBatM2's Avatar
325
Thanks for the suggestion. Didn’t work after letting it rest for about 10 minutes.
      02-05-2024, 02:58 PM   #16
to_riffic
to_riffic's Avatar
Drives: rwd
Have you tried a clay bar/mitt?
~loud noises~
