| 02-04-2024, 03:34 PM | #1 |
![]() ![]() 288
Rep 359
Racechip
For those using a racechip and have a stock running engine what setting are you using or should you use. I occasionally track this car.
This is only my opinion as I'm a retired professional ASE master grease monkey technician, now instructor. Your best teacher is your last mistake. Use what I post at your own risk as you know teachers only know book knowledge.
| 02-05-2024, 12:42 PM | #2 |
Joint Chiefs of Staff
32722
Rep 205,990
map 5 or 6 with 91 octane
map 6 or 7 for 93 or if you mix a few gallons of E85
https://x-ph.com/sale/ Phone number 725-221-5267 ![]() |
SNOW_G42109.50 |
| 02-05-2024, 01:37 PM | #3 |
60-130 Enthusiast
3008
Rep 1,402
Ran map 7 pretty much 100% of the time with 93 from Shell. Never had any issues.
I saw Mike post somewhere on here to use map 6 with 93 and 7 if you're adding ethanol, so I lowered it to 6. The difference was noticeable to me. Went back to 7 and enjoyed it. I have to get it off the car now while my DME is on a trip. |
| 02-13-2024, 03:49 AM | #4 |
Rep 150
| 02-13-2024, 09:19 AM | #5 |
![]() 1443
Rep 1,242
Math is our friend.
10 gal of gasoline and 2 gal E 85 gets one to less than 15% ethanol - in some states that is still legal for pump gas. At that level, one should not need an ECU unlock. |
| 02-13-2024, 10:01 AM | #6 |
Rep 611
If you haven't I would call racechip explain to them what you expected out of their product a d what you are seeing they may be able to help you out and get you closer to what you are looking for. I hear they have pretty decent customer support.
| 02-13-2024, 11:13 AM | #7 | |
32722
Rep 205,990
E30 is the sweet spot
| 02-13-2024, 12:23 PM | #8 |
Rep 957
| 02-13-2024, 03:18 PM | #9 |
![]() ![]() 288
Rep 359
I need to repost this. I have a RaceChip S running 93 octane no other mods. My settings only go to 5. On the track in 3 all is well on 4 there is a slight hesitation coming out of the corners on 5 very noticeable on acceleration however I noticed lower speeds at the end of the straights. Haven't had a chance to run 1 or 2.
| Bookmarks |
