BMW 2 Series Technical Topics (G42) Wheels / Tires
      02-19-2024, 07:57 PM   #1
ap2x
ap2x's Avatar
Drives: '23 M240xi
Tire sizes for 19X8 OEM wheels
Anyone know if I need 245/35ZR19 or 245/40ZR19 Michelin ps4s on my 19x8 OEM non ZTK square wheel setup? Which aspect ratio is better or do both work? Is a square setup better or staggered?
      02-19-2024, 09:02 PM   #2
BG42
Drives: M240ix
if they are 19x8 square they are 225s not 245s. Just punch your car into tire rack.
      02-19-2024, 09:07 PM   #3
ap2x
ap2x's Avatar
Drives: '23 M240xi
I wanted to increase size a bit for better traction/handling. The range for 8” width is supposedly 215-245 mm
      02-19-2024, 09:40 PM   #4
BG42
Drives: M240ix
If you wanted 245s you could run the oem ztk wheel front its 245/35-19.
ap2x21.00
      02-20-2024, 11:56 AM   #5
Wasp_Factory
Drives: 2023 M240i xDrive
You'd need to go 245/35/19 to keep the speedo accuracy. 245s are going to be pretty baggy on an 8'.
      02-20-2024, 12:03 PM   #6
ap2x
ap2x's Avatar
Drives: '23 M240xi
Would a staggered or square setup be more preferable? I’m also lowered so I’m not sure if the 245/40/19 would rub since it’s a bit larger diameter
      02-20-2024, 03:52 PM   #7
BG42
Drives: M240ix
theres no point staggering tire sizes on wheels that are the same size. You wont rub. its 245/35/19 too btw unless you want more side wall than stock.
      02-20-2024, 04:19 PM   #8
ap2x
ap2x's Avatar
Drives: '23 M240xi
Thanks
