BMW 2 Series Technical Topics (G42) Wheels / Tires
      02-27-2024, 02:53 PM   #1
capturedbysebastian
capturedbysebastian's Avatar
Drives: BMW G42
19x9.5 Front?
Does anyone know if we can run a 19x9.5 et30 in the front? Worried about strut clearance.
      02-27-2024, 06:15 PM   #2
yordmech
yordmech's Avatar
44
Drives: 2022 BMW M240i xDrive
I run 9.5" ET25 for my summer set on 255/35/19 without issue but not sure if ET30 would have an impact. I believe the upper limit is 265mm for the fronts.
Personally, I would have preferred a 9" set if the availability had been better at the time when I was shopping because at 9.5" I wouldn't go any lower than 255mm due to the amount of sidewall stretch that comes along with it.
      02-27-2024, 06:18 PM   #3
ryo-
Drives: '22 MWM M240i
this is a good write up from Apex (it should apply to all wheels, not just theirs):
https://apexwheels.com/fitment-guide...guide#overview
      02-27-2024, 07:39 PM   #4
capturedbysebastian
Drives: BMW G42
Thank you
      02-27-2024, 07:41 PM   #5
capturedbysebastian
Drives: BMW G42
I can’t reply to you, but I found a set of rims that are 19x9.5 et 30. I was trying to see if i can run them without any spacers. Still debating tire size.
      02-27-2024, 07:57 PM   #6
Fronzdan
Drives: '24 M240 xDrive
Yeah I run the same on my Winter set…9.5” ET25 with 255/35/19’s (ZTK brakes) Not sure if ET30 would have problems with the struts though.
      02-27-2024, 09:13 PM   #7
ryo-
if they're the only option you have and you are set on those wheels, buy them and test it out. if it doesn't fit, just buy spacers. afaik, it shouldn't matter what size the spacers are as long as you get the matching length lug bolt (obviously don't use the stock ones) and you are probably not going like 10mm spacers lol. it might poke out the fender line tho...
