BMW 2 Series Technical Topics (G42) Cosmetic Modifications (Exterior, Interior, Lighting)
      03-02-2024, 08:44 AM   #1
capturedbysebastian
capturedbysebastian's Avatar
Drives: BMW G42
First 23 G42 DIY Starlight 😂
Hey guys, some I am installing the starlight myself. Here is an update took off the headliner and was able to take it out through the passenger door. Also took out the rear seats and rear right trunk pannel to see all the fuses and figure out where I am going to get my power and hide the box.
Ruebarb416.50
      03-02-2024, 07:36 PM   #2
THDRNIGHT
THDRNIGHT's Avatar
112
Drives: 2023 BMW M240i
Beat ya to it XD
      03-03-2024, 12:33 PM   #3
Ruebarb
Ruebarb's Avatar
417
Drives: BMW G42 M240i
Complete G42 OEM Headlining removal
File Type: pdf Lowering the headlining (after vehicle diagnosis).pdf (7.18 MB, 49 views)
File Type: pdf Lowering the headlining with SHD (after vehicle diagnosis).pdf (7.33 MB, 51 views)
File Type: pdf Releasing and securing the headlining on the left (after vehicle diagnosis).pdf (7.14 MB, 35 views)
File Type: pdf Releasing and securing the headlining on the right (after vehicle diagnosis).pdf (7.14 MB, 74 views)
File Type: pdf Releasing and securing the headlining with the SHD on the left (after vehicle diagnosis).pdf (6.62 MB, 31 views)
File Type: pdf Releasing and securing the headlining with the SHD on the right (after vehicle diagnosis).pdf (7.25 MB, 31 views)
File Type: pdf Removing and installing_replacing headlining (Equipment specification with a slide_tilt sunroof).pdf (9.91 MB, 32 views)
File Type: pdf Removing and installing_replacing headlining (Equipment specification without slide_tilt sunroof.pdf (9.77 MB, 31 views)
      03-03-2024, 12:39 PM   #4
capturedbysebastian
Drives: BMW G42
Wow, where was this when I needed it 😭
      03-04-2024, 12:41 PM   #5
Ruebarb
Ruebarb's Avatar
417
I was trying to get it since I posted the G20 info on 2/16 in the other thread. My typical source was not working.
      03-04-2024, 02:16 PM   #6
capturedbysebastian
Drives: BMW G42
Well thank you for the information, was able to properly take off the C pillars
      03-04-2024, 09:08 PM   #7
capturedbysebastian
Drives: BMW G42
Here’s an update.
Made all the boxes and separated the fiber optics.
Ruebarb416.50
      03-05-2024, 05:48 PM   #8
Bumpinjeep
Bumpinjeep's Avatar
Drives: 2023 M2
2023 M2  [8.33]
You have lost your mind, but I'm here for the ride. Keep updating this post!
Present BMW: 2023 M2 BSM W/Carbon everything, 6 Speed
Past BMWs: 2020 M2C HS Executive, 6 Speed
2017 M3 YMB Executive, 6 Speed, ZCP
Everything else: 2024 Wrangler 4Xe
2020 MK 7.5 GTI
      03-05-2024, 08:18 PM   #9
capturedbysebastian
Drives: BMW G42
I did loose my mind 😂 , had to take everything out and did around 200 lights
Ruebarb416.50
      03-07-2024, 08:11 AM   #10
Ruebarb
Ruebarb's Avatar
417
Please keep this going, can you list parts and other details as you go along or at the end.
I may actually do this in the future.
      03-07-2024, 09:34 AM   #11
capturedbysebastian
Drives: BMW G42
Of course so I ended up using
a starlight kit with 500 lights
hot glue gun
electrical tape
sharpie
measuring tape
sewing needle
tools of course to take out the headliner
for wiring i used
some pliers to cut the cable
Ruebarb416.50
      03-08-2024, 11:49 AM   #12
Pentland
Drives: BMW M240i (G42)
I’ve said it before, but I’ll say it again. We should have a thread called how I wiped £10k off my car’s value. ETTO tho.
      03-10-2024, 12:07 PM   #13
Ruebarb
Ruebarb's Avatar
417
Have you got this installed or still working on it?
      03-10-2024, 12:09 PM   #14
capturedbysebastian
Drives: BMW G42
Yes, here is an update sir.
I wanted to go a professional job, so took me a bit longer than anticipated. This is my second time doing this, and wanted to make sure for my car that it came out as best as humanly possible.
Going to install soon on the car, the car is going crazy, throwing me a whole bunch of codes 😂
Ruebarb416.50
      03-11-2024, 07:26 PM   #15
Ruebarb
Ruebarb's Avatar
417
Nice, are you going to hide the controller/light box ontop of the headlining or did you have a better spot to hide it?
      03-11-2024, 07:28 PM   #16
capturedbysebastian
Drives: BMW G42
So the proper way to do it, is the hide the box somewhere else. If you place it on the headliner than you are going to face fitment issues.
      03-11-2024, 08:00 PM   #17
Ruebarb
Ruebarb's Avatar
417
I figured, but did you find the somewhere else so far?
I was looking through the electrical docs, for an elegant solution to power the lights only when the headlights/parking lights are on, vs with ignition and manually turning them off during the day if so desired. Everything is Lin Bus controlled on these cars, no more switches and relays, no simple wire tied to the parking lights or ambient lights.
      03-11-2024, 08:16 PM   #18
J-RO
Drives: 2024 M240ix BMW X1 28i
I am thinking Disco Inferno
      03-11-2024, 08:54 PM   #19
capturedbysebastian
Drives: BMW G42
I plugged it into a fuse in the rear trunk. Turns on and off on start button. Just went through all my fusing in the back with a volt meter.
      03-12-2024, 11:24 PM   #20
THDRNIGHT
THDRNIGHT's Avatar
112
Before I installed my starlight headliner I called the dealer and asked the price of a new headliner, I was quoted $1200.00 CAD. That means you'd only essentially lose a couple thousand, if the dealer or person you're selling to actually cares about the starlight headliner.
