03-03-2024, 08:15 PM | #1 |
Rep 137
Drives: 2023 M2 & 2018 M2
Wow! This is how the car should be. I can’t compare to stock cuz I’ve had AST HAS on for a bit. But it’s a night and day difference between that. Set to 7 clicks all around and the car drives so smooth. Actually really surprised cuz people have said it rides harsh. I think just the opposite. Whereas the AST on Sport plus struggled on bump to control rebound this suspension just eats it up. Yes hard compression you feel the stiff springs but I’m ok with that.
The car is flat in turns and feels way more planted on exit accel. The biggest issue I had with the HAS is it lowers the vehicle but shortens the shock stroke as well. I may do some tweaking. I nailed the front height. Went about 6mm lower than Ohlins spec. The back is a bit high. Bad news the whole suspension comes apart to adjust the coil height and then match the shock length. However that means the car will be lower without a change to how it rides. I did have some popping turning lock to lock. I had added some more camber on the Millway plates. I removed the extra camber and it is fine now. Track tires will be on later this week and in for an alignment.
2023 G87 ///M2 6MT - Ohlins R&T, Vorshlag Camber Plates, Fall-Line Rear Toe Arms, APEX VS-5RS, Conti Extreme Contact Force, Pagid RSL29, BM3 Stg1, IRL single mid-pipe
2018 F87 ///M2 DCT - MPE, BM3 stg1, MAD Intake, xHP stg2, M4GTS Diff/Steering, Euro MDM, Ferodo 3.12, APEX VS-5RS, Potenza RE-71RS, Cobra Nogaro next mods: Ohlins R&T, Vorshlag Camber Plates, SPL parts IG: Follow ME: genXg87 |
03-04-2024, 02:50 PM | #2 |
Joint Chiefs of Staff
24354
Rep 191,163
Ohlins are the best
GenXG87190.50 |
03-04-2024, 03:06 PM | #3 |
Rep 18,849
HAS is still a good bang for the buck mod, but once you forked over the cash for a quality suspension setup - there's no going back.
JTO245276.00 |
03-13-2024, 01:48 PM | #4 |
Rep 228
I was gonna say, "Full Ohlins coilover conversion WAYYYY Better than $700 height adjustable springs are! WOW!".....
Mike
No more BMWs A truck and a couple motorcycles |
03-13-2024, 05:21 PM | #5 |
Rep 1,807
No issues with the M Performance HAS performance here. Not sure how you can possibly compare it to a $4000 aftermarket suspension.
03-18-2024, 01:22 PM | #6 |
Supreme Allied Commander
3886
Rep 54,500
Drives: F80 M3
It's hard to beat well-engineered, 7-post shaker rig-tested monotube coilovers. HAS will likely make the OEM system under-dampened.
It's an apples-to-oranges comparison, though. |
Ronin76846.50 |
03-18-2024, 03:11 PM | #7 |
Rep 137
100% agree. Many would also argue that BMW spends millions and 1000s of hours on their suspension tuning so why change that. However they do sell the M-Performance HAS kit and I would argue that it does not improve the vehicle on the track and may make it worse.
chris7197363.50 |
03-18-2024, 03:15 PM | #8 | |
Rep 137
Based on my experience on the track Ohlins > OEM > HAS
JTO245276.00 |
03-18-2024, 03:30 PM | #9 | |
Rep 1,807
03-18-2024, 03:44 PM | #10 | |
Rep 137
Not acting like anything. Sharing my experience. You take what you want from it.
03-21-2024, 11:55 PM | #11 | |
Rep 39
03-22-2024, 11:14 AM | #12 |
Rep 268
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Nankang CR-S, Adro wing, IRL exhaust, Racechip, Mishi Skidplate, KG Splitter; IG:g87_43 |
kevinG8751.00 |
03-22-2024, 01:00 PM | #13 |
Rep 1,133
I guess WAYYY better is in the hands of that Fast And Furious crowd.
HAS is fine for me, I’ll spend the savings on vintage champagne. |
03-22-2024, 04:53 PM | #14 | |
Rep 137
I wouldn’t recommend it. Streets will work but the uniball ones won’t without a different bushing. There are a couple threads in the millway issues. If you use them you take the spring pad off the stock plates. Cut the boot off and put them on the millways. The Ohlins have their own boot.
03-23-2024, 07:06 PM | #15 | |
Rep 39
03-24-2024, 09:08 AM | #16 | |
Rep 137
Once I did that I put them on the car. I had to rotate the ring a bit once I got it on the car for the bracket to be positioned right and clear everything gotta be careful if you rotate or the boot may slip out again. This is the only pic I have. It is the passenger side.
kevinG8751.00 |
03-24-2024, 10:18 PM | #18 | |
Rep 137
But ultimately over the v3 I liked the fact Ohlins didn’t impact suspension travel when adjusting ride height. I also read up on some testing of their DFV technology and thought it would provide a good balance for street track use. I also liked the simplicity of a single adjustment for where I am at with the car. Lastly I got a good Black Friday deal so saving a few bucks never hurts. In hindsight starting with Ohlins/Vorshlag would have saved me some $$$ but live and learn. Oh forgot to add about the end links. They are on my to-do list the mounting points are a bit different and I think they will need to be shorter than stock.
03-25-2024, 06:20 AM | #20 |
Rep 107
How is the ride compared to stock for everyday driving? I planned to just go with Eibach Springs to hold me over until I'm ready for a more purposeful setup like this. I like having the settings available, and the wife likes the ride, but I've never been a fan of lowering springs, and I like to have my car perform as well as it looks.
03-25-2024, 10:50 AM | #21 | |
24354
Rep 191,163
If you are a serious track driver, the Ohlins are the better investment.
GenXG87190.50 |
03-25-2024, 03:22 PM | #22 | |
Rep 2
