03-03-2024, 08:34 PM | #1 |
Rep 127
Drives: 2023 M2 & 2018 M2
Wow!
First the weight difference. Gotta be 20-25lbs. Second sounds great. Third I think this is what the car needed. I have a JB4 and this mid pipe really woke it up. Seat of the pants meter is like 30-40hp. Responsive and torquey too. https://www.youtube.com/watch?v=HnArbN1Q4ag Fitment was spot on. Pretty easy to install. Only gripe and it seems to be pretty common with some of the more cost effective solutions is no instructions, parts list or links to pdfs or videos. I heard about cutting at the dimples. Well there is one spot with one dimple and one with two. Cut first at the one since it was less pipe removed. Then mocked it up and realized it needed to be cut at the two dimples, about 2 inches. That was perfect.
2023 G87 ///M2 6MT - Ohlins R&T, Vorshlag Camber Plates, Fall-Line Rear Toe Arms, APEX VS-5RS, Conti Extreme Contact Force, JB4, IRL single mid-pipe
2018 F87 ///M2 DCT - MPE, BM3 stg1, MAD Intake, xHP stg2, M4GTS Diff/Steering, Euro MDM, Ferodo 3.12, APEX VS-5RS, Potenza RE-71RS, Cobra Nogaro IG: Follow ME: genXg87 Last edited by GenXG87; 03-03-2024 at 08:48 PM.. |
03-04-2024, 02:42 PM | #2 |
Joint Chiefs of Staff
24210
Rep 190,807
GenXG87179.00 |
03-05-2024, 08:53 PM | #3 | |
Rep 165
GenXG87179.00 |
03-05-2024, 09:34 PM | #4 |
Rep 127
Correct. Still pretty quiet. Valves closed windows up it isn’t much difference. In the throttle you notice it.
Open valves a bit more noise at cruise. No drone. More burble on lift. WOT roars a bit now.
2018 F87 ///M2 DCT - MPE, BM3 stg1, MAD Intake, xHP stg2, M4GTS Diff/Steering, Euro MDM, Ferodo 3.12, APEX VS-5RS, Potenza RE-71RS, Cobra Nogaro IG: Follow ME: genXg87 |
03-05-2024, 10:44 PM | #5 |
Rep 261
Did you take this pic halfway through your Ohlins install?
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Nankang CR-S, Adro wing, IRL exhaust, Racechip, Mishi Skidplate, KG Splitter; IG:g87_43 |
GenXG87179.00 |
03-06-2024, 06:37 AM | #6 |
Rep 127
lol. Good eye.
03-07-2024, 05:09 PM | #8 |
Rep 31
I installed one of these last week and used a sawzall. Cut the oem exhaust and dropped the middle section. Left the muffler box on the car.
03-07-2024, 07:36 PM | #9 | |
Rep 127
You probably can't use a chain cutter with stainless pipe. I dropped the whole exhaust. It takes like 10-15 min to drop. You need two people though cuz it's pretty heavy.
mtenhoven124.00 |
04-08-2024, 06:19 PM | #11 |
Rep 165
EngineerTheVoid & GenXG87 - How low does the main pipe hang coming off the downpipes prior to the bracket on your install?
Seems lower than I expected on my install. |
04-09-2024, 05:49 AM | #12 |
Rep 618
How's the JB4 been on the G87? What settings have you been running? Lowkey interested in getting one for my car sometime in the future
Current: 2024 G87 M2 (ZF8)
Past: 2022 330i RWD 2020 M2 Competition DCT |
04-09-2024, 07:44 AM | #13 | |
Rep 127
However, on a road course it's not ideal. The main issue is that it will kick-in at a certain throttle %. This can cause some issues since throttle modulation needs to be consistent. So I set it to map 0 (stock) on a road course. On the street I run map 2 on 93 and the car is a blast.
04-09-2024, 06:30 PM | #14 |
24210
Rep 190,807
It's a solid option for more power safely
GenXG87179.00 |
