03-04-2024, 09:44 AM | #1 |
Rep 76
Power
Sold the C7Z for the G87, so here I am. Is DP, Exhaust, and one of these chip tuners going to net 600whp? Or am I going to need to learn more about what the whole unlocking of the DME thing is and run new turbos? I am asking about dyno proven numbers. Not seeing a lot of that backing the boxes up. Looking to land in-between 600 and 700 on this car, but no more.
Appreciate you all. |
03-04-2024, 11:22 AM | #2 | |
Rep 2,978
With a femto unlock and ecubtune, here are your basic options: - stock fuel system, intake, highflow catted downpipes, exhaust heat exchanger, oil and trans coolers and colder plugs on 93 octane = ~650whp - modified fuel system (for E85), intake, highflow catted downpipes, exhaust heat exchanger, oil and trans coolers and colder plugs on E85 = ~700 - 750whp - upgraded fuel system (pumps, delivery, rails, injectors, manifold, etc.), big turbo, intake, highflow catted downpipes, exhaust heat exchanger, oil and trans coolers and colder plugs on E85 = can get in excess of 1,000whp The above assumes one has an 8AT. Of course, there are possible variations within each. I included the extra cooling mods which are recommended for a safest build). Last edited by M_Power Rob; 03-04-2024 at 04:11 PM.. Reason: To add 8AT disclaimer and correct 3rd option whp |
03-04-2024, 02:34 PM | #3 | |
Rep 76
03-04-2024, 02:40 PM | #4 |
Joint Chiefs of Staff
24208
Rep 190,807
this is a fun car to mod and makes a lot of power with minimal upgrades, good luck
03-05-2024, 10:54 AM | #5 |
Rep 76
03-05-2024, 06:48 PM | #6 |
Rep 195
Love the power you can make with just a few mods on these
Cars but I just found out that with the Femto unlock, if dealer needs to connect to ECU when in for service or there is an over the air software update, the ECU gets locked again. If I end up going Femto route, need to figure a way to be sure dealer won’t connect but isn’t that necessary sometimes and don’t you want or need to get software updates sometimes? |
03-05-2024, 07:24 PM | #7 | |
Rep 2,978
If you do femto unlock, your days going to the dealership are done. If you do the unlock, as soon as you hook it up you need to go into your BMW app on your phone and disable the updates (and dont do any manual updates) or its bye bye to the unlock. |
CadolinaRipr319.00 |
03-06-2024, 07:51 AM | #9 | |
Rep 195
Aren’t there updates that are necessary ? |
03-06-2024, 08:26 AM | #10 |
Rep 2,978
03-06-2024, 09:36 AM | #11 |
Rep 412
03-06-2024, 10:54 AM | #12 | |
Rep 1,168
https://www.denso.com/global/en/prod...sic/heatrange/ |
M2Jorge785.00 |
03-06-2024, 12:55 PM | #13 |
Rep 195
Maybe like infotainment update or anything really.
Can you not get state inspections if they have to connect to OBD? Sorry for all the Qs. I came from a bunch of Subarus using Cobb accessport and you just flash back to stock and unmarry the device. No accidental locking of ECU |
03-06-2024, 01:00 PM | #14 | |
Rep 2,978
Unfortunately, no updates. Honestly, not sure about State inspections. I would deder to those in yours or other States that have them. |
03-06-2024, 02:20 PM | #17 | |
Rep 2,978
With higher stage tuning/increasing power comes more heat. Heat is a killer (why using upgraded heat exganger and aftermarket oil and trans coolers are a great benefit). The colder range plugs help transfer the heat faster and prevents pre-ignition. |
03-21-2024, 07:32 PM | #18 | |
Rep 84
03-21-2024, 08:01 PM | #19 | |
Rep 2,978
Carbahn for the heat exchanger. If their oil cooler and trans cooler are out, those would be my choice. Wagner is also a top choice. CSF is good but not quite on the same level as Carbahn and Wagner. Yeah, if going 600+ whp on the manual, I would upgrade the clutch. |
03-22-2024, 07:59 AM | #20 |
Rep 195
Is it just the clutch that’s the weak point with the manual or the entire transmission? A clutch is a a pretty easy upgrade. Also need to figure out how to get some traction with 600-700 whp and RWD.
03-22-2024, 10:57 AM | #21 | |
24208
Rep 190,807
ToneM2148.50 |
03-22-2024, 11:29 AM | #22 | |
Rep 2,978
I have a mix of Carbahn and CSF (based on availability at the time). The overall quality of the Carbahn (fitment, welds, etc) was far superior to CSF. CSF required some cleanup welding and customized piping (custom machined and bent piece) on one if the coolers to be able to fit and install. The CSF seemed to now be a more mass produced part whereas more personal attention seems to be given by Carbahn and Wagner. My builder has used all three manufacturers parts on the G80/82/87. |
