      03-11-2024, 10:39 PM   #1
bmhewett
Drives: 3012 328i sport 6 speed MT.
problerm with auto roll down windows
Hello friends, I greet you with pleasure and take this opportunity to ask the owners of M2 G87 or series 2 from 2022 onwards, (I assume the Edrive system is the same).
The problem is the following: there is a function to automatically lower the car's windows halfway by PRESSING THE UNLOCK BUTTON TWICE, and then opening the door. This function is activated from the car in the windows/key option.
The problem is that it does NOT work in my car, has anyone had this same case? Any recommendation?
thank you so much
      03-12-2024, 12:10 AM   #2
JABCAT
Professor
JABCAT's Avatar
4250
Window functions are on pg 86 in the owners manual, and there is no mention of the window opening 1/2 way by pressing the unlock button twice.
      03-12-2024, 01:04 AM   #3
nype
nype's Avatar
Drives: BMW M240i / BMW X5 35d
I’ve seen this feature on the BMW YouTube tutorials though I can’t seem to find it now.
      03-12-2024, 01:19 AM   #4
nype
nype's Avatar
Triple click and then pull the door handle.
But I suspect you need to disable the comfort access proximity setting.
https://www.reddit.com/r/BMW/comment...t=share_button
Has been discussed on here in another thread but I’m too lazy to search at the moment.
      03-12-2024, 07:26 AM   #5
RockCrusher
Found this in my M2's digital owners manual:
When a window is frequently opened to the same position, this task can be performed by the BMW Intelligent Personal Assistant. This is useful if you frequently use the same parking garage, for example.
Additional information:
BMW Intelligent Personal Assistant, refer to page 51.
Page 51 starts the section which details how to use voice commands to enable various operations. Apparently one of which is controlling windows.
And for opening the windows with the key fob:
With the vehicle key
Opening windows
Press and hold the [unlock] button on the vehicle key after unlocking.
The windows open for as long as the button on the vehicle key is pressed.
      03-14-2024, 01:16 AM   #6
bmhewett
apreciate everybody for your reply.
so, if any M2 G87 owner have the opportunity to try, please let me know.
remember: just press UNLOCK button twice, then open the door, and tell me what happens..
thanks
      03-14-2024, 06:05 AM   #7
M2_Steph
Drives: M2 G87
2023 BMW M2  [0.00]
thanks
That feature is called "comfort entry". It is explicitly mentioned in the manual. Unfortunately, I couldn't get it to work in my car
I have already checked the settings in the car.
      03-15-2024, 03:56 PM   #8
bmhewett
Thanks, then i believe this is a software configuración error in all M2 G87. This feature is Not available eventhough the car has the option to activate!!
      03-15-2024, 04:24 PM   #9
JABCAT
Professor
JABCAT's Avatar
4250
Which page of the manual?
There's no mention of this supposed feature with the windows anywhere in the manual that I can find. Not under comfort access (p. 74) or windows (p. 86).
      03-15-2024, 10:55 PM   #10
bmhewett
there is no mention in the manual, i have looked all of it. the option is actually in idrive in the car, key configurator
set it ON , the feature don't work. what a shame...
      03-16-2024, 07:15 AM   #11
M2_Steph
Drives: M2 G87
2023 BMW M2  [0.00]
I only have a German manual. The feature is mentioned on page 81.
It says: "Comfort entry, press the button on the vehicle key twice in quick succession to activate the comfort entry.
Depending on the settings, the window is lowered further when a door is opened."
      03-17-2024, 12:55 PM   #12
bmhewett
Interessant. Dies steht nicht in der nordamerikanischen Bedienungsanleitung. Es ist möglicherweise nicht in den USA und Kanada verfügbar.
i agree, maybe this function is for europe only, still our cars shows the feature....
did someone elese have the chance to try double click ??
      03-17-2024, 01:31 PM   #13
Tag
this is the way
Tag's Avatar
20006
Drives: N-1 starfighter
All BMW coupes have frameless windows. When you open a door, the window lowers about 1/2"/12mm so you can safely open the door without the glass still being recessed into the rubber trim.
      03-17-2024, 04:53 PM   #14
M2_Steph
Drives: M2 G87
2023 BMW M2  [0.00]
I know, but this feature should lower the window approx. halfway down.
The "standard" lowering for frameless windows which you mentioned shouldn't have the be activated in an additional step.
      03-17-2024, 04:56 PM   #15
Tag
this is the way
Tag's Avatar
20006
Where does it say halfway?
      03-17-2024, 09:34 PM   #16
bmhewett
      03-17-2024, 09:44 PM   #17
bmhewett
      03-17-2024, 09:47 PM   #18
bmhewett
      03-17-2024, 09:48 PM   #19
bmhewett
This feature also works in my 2019 F21 but Not in my New G87!!
      03-17-2024, 10:57 PM   #20
bmhewett
Take this as the joke it’s intented to be, but do you have a smartphone or a camera you can use to take a picture? I appreciate the photo posted above, but since it was taken with a potato l can’t make out what the option says.
I am however able to see you have an additional option below “tailgate”. Mine only shows tailgate. Thanks, that helps clear the confusion in my head.
What software version are you running? And what does the option say?
These are only Thumbnails, select the pic to see the actual image.
This is my 2024 G87
      03-17-2024, 11:18 PM   #21
bmhewett
Ah you posted in a different site, the app doesn’t allow us to see it. I was able to see it using the web version, thanks!
Yes, I get it, but what version? Wondering if this feature became available in a newer version of the software.
Did you try double click in your car?
      03-18-2024, 01:00 AM   #22
bmhewett
Yes.
Nothing happened?
