E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > N54 Vacuum Lines
Reply
      03-14-2024, 05:22 PM   #1
Connors N54-N55
Drives: BMW 2008 & 2011 335i e93
N54 Vacuum Lines
My bov has really bad compression surge. Guessing I have a vacuum/boost leak. I have read a lot of forums on about DIY’s for vacuum lines. Have seen a lot of diagrams but haven’t really found how to route to the rear turbo or where to go after the bov. If anyone could help that would be great, and also which lines for vacuum they use?
Last edited by Connors N54-N55; 03-14-2024 at 05:24 PM.. Reason: Didn’t explain why I need to replace my lines
      03-16-2024, 05:08 PM   #2
Clubfed11
Drives: 2013 335is
not sure how much of a help it is but check out https://www.realoem.com/bmw/enUS/select
and put in the last 7 of your VIN. click on engine then vacuum control.
Here is mine but its for a 2013 335is, probably the same:
https://www.realoem.com/bmw/enUS/sho...diagId=11_3975
It doesn't show exact routing but it should help you understand it a little better.
Hope that's of some help.
Reply
e90post
