      03-14-2024, 08:57 PM   #1
KindaSortaTerrible
Drives: 21 Civic Type R
Did something stupid today
So i tried something today and ended up in a highly embarrassing situation. I was on a hill, stopped at a light. Put on my ebrake to see if that would help provide a bit of an extra safeguard against rolling backward. Well, i stalled when I tried to take off. Turned the car back on, stalled again. Same thing the next time. During these attempts I think I kept the car in first but I would keep the clutch pressed in when I turned the car back on.
From what I described, did i do anything particularly egregious or was it just nerves fucking me up?
      03-14-2024, 09:02 PM   #2
ronin13013
It wont roll back in that second it takes to release the clutch with throttle input.
      03-14-2024, 09:16 PM   #3
wjones14
wjones14's Avatar
928
Drives: 2025 M2
Did you stall because you left the e-brake on? You have to have the clutch in to start once you've stalled so that part wasn't wrong. But I think the hill-hold feature gives you two full seconds before it will roll backward once you release the foot brake, so it doesn't make sense to also use the e-brake.
Vehicles: 2025 M2 6MT; 2011 Kawasaki Z1000 (1/4 mile 10.3 seconds @ 129 mph - stock)
Previous: 2021 Alpine White M2C 6MT; 2018 Camaro 2SS 1LE 6MT; 2015 BMW M235i 6MT; 2015 Mini Cooper F56 6MT; 2005 Mustang GT 5MT
Sebis201.50
      03-14-2024, 09:40 PM   #4
abrandonment
abrandonment's Avatar
879
Drives: M2
Does the M2 not have a 'brake hold' or a 'hill assist' ?
      03-14-2024, 09:48 PM   #5
clydefrog
clydefrog's Avatar
406
Drives: Subaru BRZ, G87 M2
2024 BMW G87 M2  [10.00]
2013 Subaru BRZ  [10.00]
it definitely does by default, at least I didn't even need to go into the settings or put it on when I'm on a hill.
In fact it's so aggressive sometimes it does it on the slightest incline.
Not really sure what OP did besides stall
Zatellia229.50
baj_baj410.50
      03-14-2024, 09:54 PM   #6
Kepha
Kepha's Avatar
Drives: 2024 BMW M2 (G87)
It does have a “Drive-off assistant” function that holds the brake pressure for approx. 2 seconds. The manual also describes using the parking brake as an option just like you described.
So I don’t think you did anything wrong in using the parking brake. It wasn’t causing the stalls as the parking brake will automatically release with sufficient throttle input.
      03-14-2024, 10:08 PM   #7
G87M
Net takeaway - don't worry, the car is fine 😊.
      03-14-2024, 10:36 PM   #8
mrdudley
mrdudley's Avatar
Drives: BMW X3 M40i
Probably nerves. I rarely stall but when I do it’s on a hill and twice 😂
      03-15-2024, 12:05 AM   #9
ScottyRyan2019
Licensed Professional Slacker
ScottyRyan2019's Avatar
Drives: 2024 M2 and 2025 i4 M50
  [9.25]
  [9.25]
2024 BMW M2  [9.50]
Probably just nerves. Try a Viagra next time.
2024 M2 and 2023 Mazda CX-30
      03-15-2024, 12:12 AM   #10
baron95
baron95's Avatar
1884
Drives: BMW G87 M2
It is a rule from the manual transmission gods. If you stall once, you will likely stall again, because you are frustrated for having stalled the first time.
OP - don't over think it. Next time gas it up and light those rear tires up. Guaranteed not to stall.
G87 M2 BSM On Order
      03-15-2024, 01:01 AM   #11
xtougher
Drives: 2024 G87 M2 6MT
It definitely has the "hold" feature.
When I first learned to drive my first car, I was nervous about rolling on hills, so I used to use my e-brake if someone was a bit closer to me than I was comfortable with...but that was with a pull-up hand brake.
I never really thought about doing that with an electronic version of that. I don't think I'm coordinated enough to do it, and would likely result in it CAUSING me to stall. LOL
      03-15-2024, 09:58 AM   #12
RockCrusher
Nerves and lack of practice.
Way back when and I used the parking brake -- lever operated -- to hold a car on a hill to avoid roll back when driving on a hill, smooth take off required timing which was improved by practice.
But I soon just developed a technique of getting the car moving by in quick succession releasing the brakes and applying some throttle and concurrently easing the clutch into engagement. This eliminated the use of the parking brake.
Then at some point one then both of my vehicles were fitted with automatic transmissions and even came with hill hold and that was that.
Well, not quite..
I have bounced from vehicles equipped with automatics and those equipped with manual transmissions. Often and is now the case, one car (230xi) is an automatic and the other (M2) is a manual.
The M2 (and the 230xi too) has what is called "Drive-Off Assistant". From my M2's owners manual:
Drive-off assistant
Principle
The drive-off assistant supports driving off on uphill grades.
Driving off
1. Hold the vehicle by depressing the brake pedal.
2. Release the brake pedal and drive off quickly. After the brake pedal is released, the vehicle is held in place for approx. 2 seconds.
Depending on the vehicle loading, the vehicle may roll back slightly.
In order to prevent rolling back when driving off, use the parking brake.
1. Pull and release switch before driving off. The parking brake is set.
2. Step on the accelerator pedal sufficiently to drive off.
My experience with my M2 (with the 6-speed manual) is given my usage of the vehicle the drive off assistant makes the use of the parking brake unnecessary.
      03-15-2024, 10:01 AM   #13
KindaSortaTerrible
Thanks too all who provided advice. Unfortunately the clutch definitely feels different today- slightly quivers as I release it starting from a sttop, and the bite point is more vague than before. Totally drivable and frankly a bit more pleasant, but yeah, I think the clutch needs to be looked at.
Drove a type r and nothing like this ever happened, just my luck
      03-15-2024, 11:12 AM   #14
Legit
Drives: 2024 G87 M2 (6spd Manual)
Here is a slightly on topic question. I was under the impression this car can't stall? I have literally tried on purpose to stall this car and it gets ugly, jerky and lurches forward awkwardly but the engine does not turn off and the car just settles itself and continues. The engine has never shut off on me.
      03-15-2024, 11:28 AM   #15
Tag
this is the way
Tag's Avatar
20598
Drives: N-1 starfighter
What gave you that impression?
Why were you trying to stall it?
      03-15-2024, 11:29 AM   #16
Tag
this is the way
Tag's Avatar
20598
The car is not that fragile. Perhaps you're just overthinking this.
      03-15-2024, 11:48 AM   #17
Legit
To test the stall characteristics. I realized this car does not shut off, at least on me. Maybe some anti stall software I have no idea. Literally no gas let go of clutch it lurches forward but does not shut off and I can just go on my way.
      03-15-2024, 12:57 PM   #18
JMcLellan
JMcLellan's Avatar
2976
Drives: 2020 X5M Comp
I agree that it is hard to stall this car- still haven't done it when driving. However, I did stall it when I was parked when I forgot the car was in gear and still running. Let off the clutch and the car turned off.
The true test will be this afternoon as my wife will be taking the car for a drive. It's been 15+ years since she has driven a stick....if she doesn't stall it then maybe there is something to the theory the car can't be stalled
2020 X5M Competition
2024 M2- Sold
2019 M240i- Sold
      03-15-2024, 01:17 PM   #19
Habber
Habber's Avatar
Drives: BMW M3 2024 Brooklyn Grey SOLD
  [9.87]
All those years learning to perfect the first gear engagement stopping on a hill….
What a waste now.
grl.racr386.00
      03-15-2024, 01:40 PM   #20
ScottyRyan2019
  [9.25]
  [9.25]
2024 BMW M2  [9.50]
Let me know her route so I can stay the phuck on the other side of town!! 🤪
      03-15-2024, 01:48 PM   #21
JMcLellan
JMcLellan's Avatar
2976
I am riding passenger and hoping she navigates to pound town. Lol. I hope she never reads this......
2024 M2- Sold
2019 M240i- Sold
      03-15-2024, 01:49 PM   #22
ScottyRyan2019
  [9.25]
  [9.25]
2024 BMW M2  [9.50]
Originally Posted by jmclellan View Post
i am riding passenger and hoping she navigates to pound town. Lol. I hope she never reads this......
