BMW
X1 / X2
BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Errors 118001 & 118401
      04-02-2024, 05:16 AM   #1
TheRiddle
Drives: '17 X1 18i + '00 323Cic
118001 Mixture too lean
118401 Mixture too lean, large deviation
sporadically the idle is over 1300rpms
your best shot?
Vacuum
injectors
fuel filter (or contaminated gas)
car runs fine
no shaking/strange behaviours at cold start
maf readings are within normal parameters
      04-02-2024, 07:33 AM   #2
mDrive1
Drives: X1
fuel tank breather valve?
      04-04-2024, 11:25 AM   #3
TheRiddle
Bimmerlink didn't gave any specific issue, I haven't tried with Ista yet..
i remember that INPA used to give a specific error on my e46 for Evap and tank breather valve..
is there a direct way to test it via Bimmerlink on the go?
      04-05-2024, 07:25 AM   #4
mDrive1
Drives: X1
Ista has a test option, but you only hear a click sound, so I don't think it checks the integrity of the membrane at all. However, many other things could be leading to your problem. good luck troubleshooting. Let us know what you find.
xbimmers
