      04-04-2024, 02:22 PM   #1
MineralGreyMetallic
MineralGreyMetallic's Avatar
1115
Drives: 24 BGM M2 6MT
Clutch pedal clicking/creaking on release
When I release the clutch pedal, somewhere near the top of release, there is an audible clicking/creaking sound.
I've found various threads in other forums of similar issues, but wondering if anyone has experienced this with the G87 yet?
Those threads targeted the clutch master cylinder and sometimes the spring as the culprit.
I'm going to have the dealer look at it during break-in maintenance. I'll update the thread with more info as I get it.
      04-04-2024, 02:47 PM   #2
Geighty7
Geighty7's Avatar
Drives: 2024 BMW M2
Have not experienced this in either of my G87’s. Seems like a possible spring issue (small fix hopefully).
How many miles do you have on the car? The clutch fully breaks in around 300-500 miles after being soft on it for a bit.
      04-04-2024, 02:56 PM   #3
MineralGreyMetallic
1115
~900 miles currently.
It seems to be getting worse over time.
Geighty72779.50
      04-04-2024, 02:57 PM   #4
Geighty7
Geighty7's Avatar
Drives: 2024 BMW M2
Worth getting checked out asap. Sounds like you may have a bad spring.
      04-05-2024, 09:20 AM   #5
baj_baj
baj_baj's Avatar
408
I had an issue on my F56 Cooper S, creaked like an old barn door. They tried lubricating everything, then changed the spring, in the end they changed the whole clutch assembly. The issue would occur just in hot weather, probably a tolerance issue where something would expand and creak.
The problem I have on the M2 is in cold weather, while the car is also cold. There is a catching feeling as if the pedal is catching the carpet. It goes away after 5-10min driving
      04-05-2024, 11:08 PM   #6
sclui56
Drives: E86, IS-F, G42, G87
OP, while I haven't come across this on my G87, I had a similar experience with my 2018 F87 @ ~5k. I can feel the click on up-stroke near the top, not on every release and didn't seem to have much of a pattern, almost felt like a sleeved spring catching some imperfection.
This drove me nuts and the tech of course came back with "cannot replicate", though the foreman took another look, he drove around but couldn't replicate either. Then when I picked up the car, he drove it once more for about 2 miles in traffic and he detected multiple instances.
Below is the parts list of what was done to fix that line item, maybe some parts were not affected, but I haven't come across the problem up to the time when I sold the F. Ignore the last 2 parts, not sure why they were lumped into there.
      04-05-2024, 11:27 PM   #7
MineralGreyMetallic
1115
Thanks, that is super helpful.
Mine is very easy to replicate at the moment, so hopefully I don't need to go through the run-around.
