BMW M2 Forums 2023+ (G87) Engine, Exhaust, Drivetrain, Tuning Modifications
      04-04-2024, 03:28 PM   #1
BMW DIY Guy
BMW DIY Guy's Avatar
Drives: 2019 M2 Competition
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Upgrading the S58 charge pipes - step by step DIY
Ok y'all... its serious now with Kies Motorsports and Mishimoto Automotive for big power upgrades into the G87 M2. The weakest point in most modern BMW engines are the charge pipes, espeically if you plan on going beyond stock horsepower. Mishimoto makes a fantastic upgrade to the weaker plastic charge Y pipe in the S58 motor, and I knew I wanted it.
This isn't as easy as some of my DIYs but I will walk you through every single step that will allow you to do this yourself.
Check it out!
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy **
'Nimona' G87 M2 Build Thread
'Lillith' F87 M2 Competition Build Thread
      04-20-2024, 12:17 PM   #2
Geighty7
Geighty7's Avatar
Drives: 2024 BMW M2
Check it out!
OP- if I don’t tune my car but want better flow with aftermarket charge pipes- is it worth it?
      04-20-2024, 12:21 PM   #3
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
I would, but that's just me.. might as well upgrade your heat exchanger too while there since it's 90% the same job.
      04-20-2024, 12:21 PM   #4
Geighty7
Geighty7's Avatar
Drives: 2024 BMW M2
Which brand would you go with?
      04-20-2024, 12:25 PM   #5
M_Power Rob
Drives: '23 M240 and '23 M2
Money not an object, go for Wagner heat exchanger. Best for the price, Carbahn.
Geighty72331.50
      04-20-2024, 12:27 PM   #6
M_Power Rob
If upgrading charge pipes, you need to do hot side and cold side (and stay away from plastic). Personally, on a stock motor/tune, not necessary.
Geighty72331.50
      04-21-2024, 07:49 PM   #7
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
I did the CSF and like their quality.
