BMW M2 Forums 2023+ (G87) Marketplace Classifieds Sponsors Classifieds
      04-22-2024, 06:21 PM   #1
IND-Distribution
IND-Distribution's Avatar
10161
Drives: G82 / G87 / G90
IND | MC G87 M2 Splash Guard Set
Megachip™ guards offer superior protection against rock chips, seamlessly blending with your car's factory appearance.
  • No drilling or modification
  • Easy installation
  • One-year satisfaction guarantee
The flexible, foamed rubber material withstands extreme conditions for years, enduring everything from icy Canadian roads to the scorching heat of summer track days.
The front guards mount directly to the fender liner with included plastic rivets and a small piece of 3M™ VHB™ adhesive tape, while the rear guards use 3D-printed brackets and are fastened with the original hardware.
Benefits:
  • Tough rubber material is ultra-flexible with an OEM+ finish
  • Drastically reduces rock chips and splashing along the sides of the fenders, doors, and rear bumper. Drive with confidence on rough pavement, through construction sites, and offroad settings
  • Functional in all weather conditions including reducing spray from snow, salty slush, and wet pavement
  • Rear guards use a seamless bracket mounting solution for an easy install
  • Engineered and tested specifically on each G8X chassis vehicle
  • No drilling or vehicle modifications
  • Made in the USA with USA materials
What's Included:
  • Front and rear MC guards
  • Custom 3/32" punch (OE Rivet removal tool)
  • OEM plastic rivets for installation
  • Installation instructions
  • Guaranteed satisfaction
The MC G87 M2 Splash Guard Set may be viewed at the following link to our website:
https://ind-distribution.com/product...lash-guard-set
Please contact IND by phone or email for more information or to place your order.
866.963.4520 | info@ind-distribution.com
NOTE: Installed photos shown on G80 M3.
matty_f306.00
      05-15-2024, 01:40 PM   #2
JMcLellan
JMcLellan's Avatar
2976
Drives: 2020 X5M Comp
  • Easy installation
Benefits:
What's Included:
Hey there. I am installing some spacers I purchased from you guys (15mm fronts, 18mm rear). I'm curious if these guards are effective for use with and without wheel spacers. I assume these will cover me well with the size spacers I'm putting on my car?? Thanks in advance.
2020 X5M Competition
2024 M2- Sold
2019 M240i- Sold
      06-04-2024, 09:49 AM   #3
IND-Distribution
10161
These guards work great with or without wheel spacers, and you can definitely use them with your 15mm/18mm setup. We have them installed on our G87 with wheel specs about as aggressive as they can get; a square 305 Michelin Pilot Sport Cup 2 setup on there now!
While they might not stop all rock chips, you'd see a big reduction in them after installation. They're the best option out there to minimize rock chips without using paint protection film.
JMcLellan2975.50
      01-01-2025, 11:35 AM   #4
jcf2
Drives: 2025 M3 competition xdrive
whats holding the brackets on the rear flaps
IND can you explain how the rear spacer brackets are attached to the rear flaps. I have read online that in the past they were held on with adhesive that would eventually detach from the guard.
