      05-09-2024, 12:52 PM   #1
TwinWhistles
Drives: '23 G87 M2 & '24 Rivian R1S
Back Seat Dog Cover
I've searched but haven't found anything specific.
Does anyone have a recommendation for a dog cover that fits the small back portion of the car? I know there are many sling-style options, but the M2 has such a small area, and I'd like it to fit neatly.
I don't want to tote my pups around in the M2, but sometimes I have to and would like protection.
      05-13-2024, 08:25 PM   #2
sharpmoney
Drives: NA
id be interested in this as well.
      05-14-2024, 12:32 AM   #3
DarkNight707
DarkNight707's Avatar
Drives: BMW G87 (2024),BMW E82(2009)-s
I use a small carrier but that may not work for you.
      05-16-2024, 01:39 PM   #4
Geighty7
Geighty7's Avatar
Drives: 2024 BMW M2
I usually strap my dog to the roof
sycd263.00
      05-16-2024, 05:15 PM   #5
two_three_two
Drives: BSM G87, Mk4 R32
the beast is contained..... for now.... god help us all if he gets out
      05-17-2024, 03:46 PM   #6
mynameisnick4
Drives: 2023 M2
I have two boxers that I cart around from time to time in the back seat, they are the reason I have an M2 instead of a Supra. I use a combination of seat covers/blankets with goal of protecting the seats and containing all the dog fur so my setup probably goes above and beyond what most people do.
1: I put down 2 bed sheets, one on the bench that goes down and covers the floor and a second that covers the back rest.
2: I put down a blanket that goes over the entire back seat and extends down over the floor as well.
3: I have a fitted Kurgo cover that goes down first. it is similar to this one:
https://www.kurgo.com/car-seat-cover...nch-seat-cover
It has a strap that goes behind the seats into the trunk plus the loops that cover the head rests.
4: The last thing that goes in is a hammock style dog seat cover. This is the exact one I have but it's no longer sold. There are a lot of similar options out there:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
This one makes the hammock by lopping over the front seats. I raise the headrests and buckle around that gap. This one is the most important because it prevents the dogs from falling into the gap between the front and back seats. Since we do not have grab handles in the back seat for the side protectors to hook onto, I use these:
I put one on each backseat window for the side protectors to hook onto. These are the only things I have found to work. If you try to use the clothes hanger hook, the covers will come unhooked in 2 minutes. With these you can remove the metal hook when you are not using them.
When I am done transporting the dogs, I can scoop this whole setup out in one big ball containing all the dog fur.
      05-22-2024, 09:49 PM   #7
TwinWhistles
Just a little follow-up to my solution, which turned out about as good as I could hope.
Purchased this hard bottomed seat cover with 8 12" square hard pannels: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
If anyone goes this route, be sure to get a seat cover that zips up on each corner, not plastic buckles like the one I linked above. I'm sure the dog fur will be sneaking through those cracks.
I took the rear 4 pannels and tucked them in the crack where the back seats pivot down. I used cardboard to make a pattern of the bolsters so the hard panels could be cut to tuck as far back as possible. The two middle panels also require some trimming to fit around the armrest hinge. After that, everything else fit fine.
Due to our cars not having rear grab handles, I purchased 4 of these hooked super strong suction cups and positioned them on the back windows: https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
I hope this helps someone in the future. This is just my backup solution to my normal dog hauler of a Rivian R1S with a full Canvasback custom cover.
      05-22-2024, 10:49 PM   #8
///M TOWN
///M TOWN's Avatar
33000
Drives: M GmbH
2018 M2  [9.27]
Mitt Romney style ‼️
Geighty72779.50
      05-23-2024, 09:26 AM   #9
ScottyRyan2019
Licensed Professional Slacker
ScottyRyan2019's Avatar
Drives: 2024 M2 and 2025 i4 M50
  [9.25]
  [9.25]
2024 BMW M2  [9.50]
Just like Aunt Edna
2024 M2 and 2023 Mazda CX-30
Geighty72779.50
      05-24-2024, 04:48 AM   #10
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
3200
Drives: 340 6MT, 50e, others
put them in a cage/create where they belong.
      05-24-2024, 08:59 AM   #11
DrewNewM2
Drives: Brooklyn Grey G87 Manual
I have 2 Border Collies and no way in hell they’re going in the M2, but check out offerings from Orvis. They have a good selection of covers.
///M TOWN32999.50
KC87ZB480.00
      05-31-2024, 01:50 PM   #12
KC87ZB
KC87ZB's Avatar
480
Drives: 2023 M2
2023 BMW M2  [10.00]
We have 2 goldens again; no way are they even getting in. Too big to sit comfortably in the front and too hard to get them in the back. That's why the wife has a car, oh and we have a winter Rav4 I lovingly call the red turd, both of which work much better.
2023 M2
2014 Triumph Trophy
      05-31-2024, 03:21 PM   #13
NewToM
NewToM's Avatar
Drives: M2 G87 Brooklyn Grey
2024 BMW M2 G87  [9.55]
We have a 68 pound Bernedoodle who gets in the back no issue. Took him a bit to realize to let the seat fully go forward before stepping down. We just use a random seat cover from Amazon to avoid most issues. Then just clean after if necessary. Haven’t run into any real issues and seat is clean when cover removed.
      06-01-2024, 01:59 AM   #14
uter
BMW nerd
uter's Avatar
91
Drives: E9, E28, E31, G87 M2
They also fit nicely with the seats folded down
2024 Zandvoort M2
1995 Schwartz 840Ci
1984 Arktisblau 528e
1973 Baikalblau 3.0 CS
NewToM1771.00
BroDoze2492.50
      06-01-2024, 08:35 AM   #15
BroDoze
Drives: 2025 M2 LCI
Wow. We take our giant hairy beast in the daily-SUV with blankets covering everything.
I could imagine her drooling and hairing-up an M2, lol.
///M
      06-04-2024, 02:54 PM   #16
mynameisnick4
Drives: 2023 M2
To follow up on this, here are some pics of my setup:
