      05-13-2024, 01:04 PM   #1
R44 Performance
R44 Performance's Avatar
United Kingdom
2290
Drives: 1500 bhp xDrive G87 M2
Project: BMW G87 M2 xDrive 1500 bhp / 1500 kg Race Car Build
BIMMERPOST
     Featured on BIMMERPOST.com
The BMW G87 M2 xDrive project is officially underway! For those of you who are unaware, we’ve teamed up with Tom Wrigley Performance to turn our Papaya Orange BMW G87 M2 into a 1400 whp+ xDrive-converted monster to take to Texas 2K25 and be competitive amongst some of the fastest BMWs in the world. There’s a lot of work to be done between now and next April including a complete OEM xDrive swap, complete engine & gearbox build with our single-turbo kit and potentially even some custom bodywork and interior modifications.
This week, the talented technicians at Tom Wrigley Performance remove the engine and drivetrain so we can assess exactly what parts will be needed and what alterations we need to make to convert the G87 M2 to xDrive.
The way I just said “removed the engine and drivetrain” made it sound like a pretty simple task. It’s a very systemised and routine job for the guys at Tom Wrigley Performance. However, it's no easy feat for the average mechanic who doesn’t have years of BMW main dealer knowledge and experience.
WHY XDRIVE SWAP THE M2?
But, before we get into the teardown, you may be wondering why we are xDrive-swapping an M2 in the first place. Besides, BMW made the G87 to be the smaller, more nimble and engaging driver’s car. Isn’t rear wheel drive the perfect setup?
The answer, simply, is traction. If we’re aiming to make this one of the fastest BMWs in the world with upwards of 1400+ bhp, a rear wheel drive layout just couldn’t transfer all that power to the road, especially from a dig in the quarter mile. Rear wheel drive may be okay for 100-200kph/60-130mph times but not drag racing at this level of power.
You may have seen the fastest BMW from Texas 2K24 earlier this year was a 1500 bhp G42 M240i with a quarter mile time of 7.9 seconds with the xDrive setup and drag tires playing a major role in achieving those ridiculous times - Built by Shop CT.
1500HP AWD G42 M240i - 7.9 1/4
I can already sense many of you thinking “then, why not just start with a G82 M4 xDrive or G42 M240i”?
There are a few reasons for this…
Number one is the fact that the G87 is slightly lighter than the G82. Only circa 30-50kg (spec-dependent) but every little helps. Secondly, there will be no other M2 like it. As a company and as enthusiasts, we just want to create something unique. We’re unlikely to find enough people crazy enough to start retailing G87 M2 xDrive packages. This is a challenge to show what ourselves and Tom Wrigley Performance can achieve.
Anyway, back to the build.
After first getting the car up on the ramp, the underside and drivetrain all looked relatively similar to the other G8X vehicles. Something we noticed immediately was that the propshaft would need to be a fair bit shorter than the one you’d find on a G82. The drive flange on the back of the transmission also appeared to be a different design which would be a hurdle to overcome. The only way to tell for sure was to drop the engine and gearbox out of the car to have a closer look.
Rob, ex-BMW main dealer tech & general BMW wizard, jumped on the computer to make a shopping list of new bits we’d need as well as items that already cross over from rear wheel drive to xDrive cars.
Something interesting Rob pointed out from the get-go: the front anti-roll bar is the same on the rear wheel drive M2 and the G82 M4 xDrive. This either means BMW is cost-saving by having only one part number OR this could be a clue that BMW plans on releasing an xDrive version of the M2 in the future, likely the M2 CS. The latter wouldn’t be great for us so we better get cracking and beat BMW to it.
Parts that we needed for the xDrive swap include new front hubs, shocks, suspension arms, drive shafts, a front prop shaft, an xDrive steering rack + arms + track rod ends, steering column, backing plate, front differential, new arch liners with space for the new front driveshafts as well as various sensors and hardware.
In addition to that, we needed a new ZF HP76 gearbox and of course the transfer case for xDrive. We were hoping that we could attach the transfer case to our existing rear wheel drive gearbox as xDrive cars use the same 8-speed ZF HP76 unit. Unfortunately, the design of the drive flange is different on the rear-wheel drive HP76, meaning you’d either have to modify it or swap the transmission completely. We opted to swap it completely as we already had a complete donor drivetrain from a G82 M4 xDrive. We would then keep the existing mechatronics unit already coded to our G87 and put that into the new gearbox.
To put it simply, we’d be taking the brain (mechatronics unit) from our original rear wheel drive gearbox and putting it in the new xDrive gearbox. The mechatronics is already pre-coded to our car so there’s nothing to worry about on that front. What we will need to code, however, is the transfer case but we’ll cross that bridge at a later date.
In around 90 minutes, the guys at Tom Wrigley Performance had the engine and drivetrain out of the car. They prefer to drop the whole thing out as one unit to make things easier for them.
WHAT ARE THE NEXT STEPS?
With the engine and gearbox now out of the car (yes, we found it quite painful to see our 1-year-old G87 M2 in this state), the guys began the xDrive swap along with installing the new front suspension components and giving a few other components a refresh with brand new OEM parts.
The next step is to get the new xDrive running gear and engine back in the car and see how many wheels decide to turn. Undoubtedly there will be some sort of serious issue as the conversion has gone too smoothly for us so far.
I know many of you will be eager to know whether our efforts were a success or a massive waste of time but you’ll have to wait until the next episode of the series. A couple of big ‘unknowns’ for us still are the front prop shaft and coding the transfer case which will likely require some specialist help.
It’s important to note that we don’t know anyone who has successfully xDrive-converted a G87, meaning we’re figuring everything out as we go along. We’ve seen many people on forums saying it isn’t even possible.
If you want to see a different angle of the build, feel free to check out EP.1 and 2 of our newest docu-series on YouTube.
EP.1 Where it all Started?
EP.2 How to build an xDrive G87 M2
Appreciate 49
Montaver2739.50
Tag20056.00
eleven11412.00
aerobod4262.00
apez820.50
Lost2381.00
s58_oreO142.50
2srsman93.00
jad4ca5.50
alexy228.50
MT6775.50
TheMaxXHD645.50
skiparock184.00
werdn711.50
G87M2GS104.00
BMR.WRLD388.00
KB7149.50
Tenac4812.00
Mr. Hankey1646.50
gnx946.50
jpf34012.00
JustChris17683.00
VANOS352.50
BigYak122.50
ZHPsedan135.50
Edwardsc1305.00
Holset323.50
Ram.Rx168.50
SoCalS2k452.50
      05-13-2024, 01:12 PM   #2
Msondeck
Msondeck's Avatar
Drives: f85 x5m
2016 X5M  [0.00]
2024 M2  [10.00]
Interesting...
For anyone wondering that m240 is from The Shop CT
      05-13-2024, 01:15 PM   #3
Tag
this is the way
Tag's Avatar
20056
Drives: N-1 starfighter
Wow, this build is going to be next level. Can't wait to see you guys pull this off.
      05-13-2024, 02:00 PM   #4
JWdrives
Singapore
40
Drives: NA
That is sick! looking forward to following you guys along on this journey!
      05-13-2024, 02:57 PM   #5
Lappy
Drives: 2020 BMW M2C 2018 BMW M4
I'm beyond confused by the front sway bar comment. G87 m2 guys are using the m4 csl bars and its a direct swap. Arn't the x version front sway bars a completely different shape?
      05-13-2024, 03:41 PM   #6
DrewNewM2
Drives: Brooklyn Grey G87 Manual
Do a 6MT!
      05-14-2024, 04:34 AM   #7
R44 Performance
United Kingdom
2290
Originally Posted by Msondeck View Post
Interesting...
Is indeed! Have added that to the post now, thank you!
      05-14-2024, 04:35 AM   #8
R44 Performance
United Kingdom
2290
Let's hope we can make it happen then!
///M TOWN32402.00
      05-14-2024, 04:36 AM   #9
R44 Performance
United Kingdom
2290
Originally Posted by DrewNewM2 View Post
Do a 6MT!
Would love to BUT, the ZF8 is the best and fastest option for this build, this car needs to compete with the fastest,
Maybe one day...
      05-14-2024, 05:39 AM   #10
Kevin_The_Clean1
Kevin_The_Clean1's Avatar
Drives: 2020 X3 MC
These are my very same thoughts. My hat goes off to you guys & I have confidence this car is going to be an awesome one of a kind build that people around the country are going to be talking about.
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten
2011 E90 335i M-Sport - Daily Driver
2017 F87 M2 - Sold & missed
2020 F97 X3 M Competition - Finally arrived ///
      05-14-2024, 05:53 AM   #11
murderspice
Drives: 2018 BMW M2
Lost2381.00
KB7149.50
///M TOWN32402.00
      05-14-2024, 09:56 AM   #12
rons e92
60-130 Enthusiast
rons e92's Avatar
Can you guys share the costs associated with this swap in an upcoming video? I've been throwing this idea around with a few people since last summer, but I didn't want to get into a $20k project adding xDrive to an otherwise stock car.
Now I'm making 780 at the tire and xDrive would be incredible at this power level.
I just want to know what I'm in for. The most concerning to me is the wiring diagrams that were partially shown during the video. Do you guys have plans to offer a plug and play wiring kit for this swap going forward?
Just want to thank you guys for doing this. Really excited to see the results.
      05-15-2024, 01:29 PM   #13
cfm56d7b
Drives: 2017 440i Gran Coupe & 2015 X5
THE project of the year - no doubt. Looking forward to more updates.
      05-15-2024, 01:32 PM   #14
M2 SoCal
BMW CCA ///M Chapter - Marketing Director
M2 SoCal's Avatar
1493
Drives: 2024 M2 (G87)
Very cool
      05-15-2024, 01:36 PM   #15
2srsman
United Kingdom
93
Drives: 2022 BMW M240i
This is one of those conversions I had always imagined! Thanks for bringing it to life!
      05-15-2024, 03:03 PM   #16
MT6
MT6's Avatar
Drives: '23 M3 '19 CTR '14 Accord MT6
Ultimate research and plan to mod G87 to xDrive
      05-15-2024, 03:07 PM   #17
G30M
G30M's Avatar
5371
Drives: M550i; retired - M340i
i don't think math is a strength here.
after conversion the G87 won't be lighter
Blue Angel1247.50
MJBO3526.50
      05-15-2024, 05:09 PM   #18
Smilodon
Drives: '24 M2
Maybe some sort of optical illusion, but on the third picture in the thread, it looks like part of the front fender is cut-up or torn. What am I seeing? A decal that was on the car originally? Wouldn't see any reason to saw up a fender in that jagged way for any reason.
Anyhow, amazingly ambitious project. I'm sure with the skills involved, you'll make it happen somehow. If I had a "good luck" to pass on, it would be that the end result will be as fast as you hope for!
      05-15-2024, 05:17 PM   #19
Sleeper
Sleeper's Avatar
Drives: 2023 X5M, 2024 M2, 2006 M3
Following this one.
Protective film. Look at the grilles. Same material.
      05-15-2024, 05:18 PM   #20
Steveo
Steveo's Avatar
164
Pretty sure the LMV3 transfer box requires secure coding at the BMW back end, but good luck, hope goes well 👍
      05-15-2024, 06:18 PM   #21
Smilodon
Drives: '24 M2
Originally Posted by Sleeper View Post
Following this one.
Thank you, now that you say that, my eyes adjusted correctly on the next viewing. For some reason, I couldn't unsee wires and such when looking at the wrinkles in the plastic.
I have failed the rorschach test apparently...
      05-16-2024, 04:06 AM   #22
R44 Performance
United Kingdom
2290
Really appreciate it! Means a lot...
Bee Pee1959.00
Tags
bmwm, bmwm2, g87m2
