05-31-2024, 10:56 AM | #1 |
Rep 3,325
Drives: 2019 M2 Competition
Evolution Racewerks cross over pipe - easy DIY
I love my BMWs but every now and then, they make an engineering decision that makes no sense whatsoever. The exhaust cross over pipe on the new S58 motors is a GREAT example of what were they thinking?! They squash the pipe in the middle, interfering with exhaust flow, for no particular reason which increases back pressure to one of the turbos?
Huh? Well, the good news is its a very quick and easy fix, plus an upgrade from Evolution Racewerks! It literally takes 6 nuts and about 15min to pull off the heavy OEM pipe and replace it with a proper 3-inch cross over pipe increasing exhaust flow, reducing back pressure and even helping heat evacuation. I went with the ceramic coating as well, to help keep heat in the pipe and flowing out the back. This is such an easy and logical upgrade that for me, it's an absolute no brainer to do. Check it out!
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
05-31-2024, 12:28 PM | #2 |
Rep 2,441
So did you notice any difference after the install? I’ve had my eye on this pipe as well. And obviously ER’s DPs.
///M
BMW DIY Guy3666.00 |
05-31-2024, 12:30 PM | #3 |
Rep 3,325
I am seriously looking at their coated catless DPs as well, so good call there. The difference is going to be small, and hard to say without real metrics. I *believe* I notice a slight exhaust note change, and hard to say (again without metrics) on performance, but also believe the change is positive as well. Many of these changes are additive, so keep adding small improvements will eventually make a BIG change.
BroDoze2395.50 |
05-31-2024, 01:06 PM | #4 |
Rep 2,441
Well, just ordered an ER ceramic coated crossover pipe to mate to the ER midpipes.
EAS still running 20% off..
///M
06-03-2024, 05:25 PM | #5 |
Rep 2,649
I did too. Going to go well with my ER mid pipe.
Present BMW: 2023 M2 BSM W/Carbon everything, 6 Speed
Past BMWs: 2020 M2C HS Executive, 6 Speed 2017 M3 YMB Executive, 6 Speed, ZCP Everything else: 2024 Wrangler 4Xe 2020 MK 7.5 GTI |
08-21-2024, 12:03 PM | #6 | |
Rep 1,595
08-21-2024, 12:12 PM | #7 |
Rep 3,325
The change would be really small in really almost every case with sound. As I have also changed my mids and exhaust box, it's hard to separate this specific item. My main focus really for this upgrade was possible heat reductions with the ceramic coating, and less back pressure to the turbos, so incrementally better response. This isn't a night and day change like some upgrades, but I see as part of an incremental whole with the build picture in mind.
ourlee1643.00 Bumpinjeep6464.00 |
08-21-2024, 12:17 PM | #9 |
Rep 3,325
I am always happy to help, let me know if there is anything I can for you and your build.
ourlee1643.00 |
08-21-2024, 12:41 PM | #10 |
Rep 1,595
You can talk my wife into purple.
BMW DIY Guy3666.00 BradMX5527.50 |
08-21-2024, 02:06 PM | #11 | |
Rep 2,649
ourlee1643.00 |
08-21-2024, 08:41 PM | #12 |
Rep 1,595
Feeling like a no brainer
Bumpinjeep6464.00 |
08-22-2024, 11:39 PM | #13 |
Rep 366
I just ordered one. I need a quicker turbo response in the lower RPM's and i'm hoping this gets it done.
Bumpinjeep6464.00 |
