06-02-2024, 01:17 PM | #1 |
![]() ![]() ![]() ![]() 1884
Rep 934
M Performance HAS - Port Installed Setting with Pictures
Here are pictures of my front left and right settings for the MP HAS, which or factory ordered and installed at the Port of NY/NJ VPC.
I read in multiple places that the nominal setting from the port is -10mm/0.4in. For those who know, eyeballing the adjustment range position, does this look full down? It loooks like more than -10mm to me. Thanks.
G87 M2 BSM On Order
06-02-2024, 01:41 PM | #3 |
33000
Rep 9,975
At least your boot is installed correctly
The first picture not so much
06-02-2024, 01:51 PM | #4 | |
Rep 934
P.S. Of course, my car was on a jack in the front, as I was flipping my wheels/tires on the paddock.
G87 M2 BSM On Order
06-02-2024, 01:55 PM | #5 |
Rep 934
Man. It looks like mine is setup much lower. My spring perch’s are over the shocks.
Is this thing a random draw of the installer?
G87 M2 BSM On Order
06-02-2024, 02:07 PM | #7 |
this is the way
20598
Rep 9,088
06-02-2024, 02:54 PM | #8 |
![]() ![]() 403
Rep 205
06-02-2024, 03:07 PM | #9 |
Rep 934
Day of delivery at the dealer and after 500 miles. It does not look good without spacers like I have it. But does not seem too low.
G87 M2 BSM On Order
06-02-2024, 03:18 PM | #11 | |
![]() ![]() 1787
Rep 4,693
Current: 2024 ///M2 Zandvoort Blue
Past: 2021 ///M3 Competition IOMG | 2018 X3 ///M40i | 2012 328i | 2009 335i | 2007 335i Coupe | 2005 545i | 2001 325i |
06-02-2024, 03:21 PM | #12 |
this is the way
20598
Rep 9,088
The drop looks good. When any car is lowered the top of the tire tucks into the wheel well more. Running spacers or getting wheels with different offset comes with the territory. Do you not like the current height or feel it's too stiff that you want to raise it?
Ronin761769.00 |
06-02-2024, 03:41 PM | #13 |
![]() 4874
Rep 3,893
Mine cam fully lowered from the port. Here is the height (20" on front and rear).
06-02-2024, 03:50 PM | #14 |
Rep 934
Beats me. First BMW ever. Seems to function well on track. No noises or unexpected behavior. But can’t say I have full confidence in the port install.
G87 M2 BSM On Order
06-02-2024, 03:53 PM | #15 |
Rep 934
I feel the height is perfect. No issues over speed bumps, etc. Was just wondering if mine is maxed out or the nominal -10mm everyone speaks off. I would not want to go any lower. Can’t even get a jack for the front center lift point without ramps.
G87 M2 BSM On Order
Tag20597.50 |
06-02-2024, 04:22 PM | #16 |
this is the way
20598
Rep 9,088
Appears to just be a mark indicating it's been torqued down. Since your perch is bottomed out there's no need to torque it.
06-02-2024, 08:51 PM | #17 |
![]() ![]() ![]() ![]() ![]() 1319
Rep 1,061
Port installed at only the 10mm drop. You can see a significant difference than that of Robs above where they clearly maxed his drop at install.
06-04-2024, 10:03 AM | #19 |
![]() 124
Rep 74
My steering wheel is also slight out of center, did they have to remove the steering wheel to correct? I am going to the dealer next week for my break in service.
06-04-2024, 10:22 PM | #20 |
Rep 934
No. Just normal alignment and reset steering wheel centering. It’s one of the advantages of electrical steering - you can set the center position with the computers 😎
G87 M2 BSM On Order
06-05-2024, 05:24 AM | #21 |
![]() 124
Rep 74
