      06-06-2024, 04:52 AM   #1
pengpeng28
Drives: BMW M2 G87
Timing belt noise inside cabin
Hi I just picked up a new g87 m2 (coming from electric so excuse my lack of info here), is it normal to hear the sound of the timing belt inside the car when the engine is on?
      06-06-2024, 07:48 AM   #2
RockCrusher
The M2 (S58B30T0) engine doesn't have a timing belt. The cams are driven by chain.
Link to engine details:
https://en.wikipedia.org/wiki/BMW_B58
Being you are coming from an electric car you might just be hearing -- for the first time in a long time -- normal engine noises a running IC engine makes, a high performance engine.
For instance there were posts from new owners about the noise that I think arose from the radiator fan running at an elevated speed at (warm/hot) engine start.
My advice would be you have the car in at the dealer and demo the noise and hear what a professional tech has to say.
Added: Forgot to mention but of course the engine has other belts, rubber belts, and a variety of hardware associated with these belts. The hardware -- I'm thinking bearings of the idler rollers, tensioner roller -- could be noisy. (Early on with another brand of car it manifested a noise -- "dry" bearing sound -- that proved to be due to the premature failure of an idler roller bearing.)
But if there is an abnormal noise I'm sure the tech will pick up on it.
Last edited by RockCrusher; 06-07-2024 at 08:46 AM.. Reason: Correct engine mode number... Was B58. S/B S58.
Geighty72994.50
      06-06-2024, 07:50 AM   #3
BroDoze
Drives: 2025 M2 LCI, 25 Y63 Pro4X
The Direct-Injection cars are noisier than usual now. Some almost have a diesel sound to them. This may be what you’re hearing.
///M
baj_baj442.50
Hypori151.00
LTE2WRK52.50
      06-06-2024, 08:03 AM   #4
M_Power Rob
Drives: '23 M240 and '23 M2
Here is a better response to the OP, what is the noise you are hearing (what does it sound like)? Maybe post a video if it is loud enough that you think it may be an issue.
      06-06-2024, 09:26 AM   #5
CadolinaRipr
CadolinaRipr's Avatar
459
Drives: BMW M2
This^
      06-06-2024, 03:08 PM   #6
daddyjaxx
daddyjaxx's Avatar
257
Drives: 2024 G87 M2
Originally Posted by RockCrusher View Post
The M2 (B58B30M2) engine
Ahh yes... The legendary B58 M2
chris7197783.50
      06-06-2024, 03:12 PM   #7
Carefree
Drives: M240i, M2
Special order option.
chris7197783.50
      06-07-2024, 08:28 AM   #8
pengpeng28
Drives: BMW M2 G87
Here is a video link of the sound
https://youtube.com/shorts/7Z8tHD0ruqQ
      06-07-2024, 08:40 AM   #9
DomMuc
DomMuc's Avatar
Germany
835
i only hear regular engine Sounds.. nothing wrong... if this is your issue.. get an ev again :-)
      06-07-2024, 08:43 AM   #10
KC87ZB
KC87ZB's Avatar
523
Drives: 2023 M2
2023 BMW M2  [10.00]
Probably best checked with the hood open so you can try to pin down the sound and where it comes from. It sure sounds louder than mine but I think someone with RHD needs to chime in as us LHD folks are on the intake side, not the exhaust. Sure sounds like DI noise to me though.
2023 M2
2014 Triumph Trophy
      06-07-2024, 08:46 AM   #11
RockCrusher
I cut/pasted the wrong engine model. My bad. Corrected it.
      06-07-2024, 08:52 AM   #12
RockCrusher
Sounds normal to me. Sure a bit noisy but you are outside of the car and you can hear the engine better.
With your time with an EV I believe you have forgotten how much noise an IC engine can make a healthy IC engine. Lots going on in the engine. There's a reason why the engine has a plastic cover over it.
But if you are concerned have the car in and have a tech give a listen.
      06-07-2024, 08:59 AM   #13
two_three_two
Drives: BSM G87, Mk4 R32
sounds like a totally normal cold start.
      06-07-2024, 10:19 AM   #14
BroDoze
That's the Direct Injection clacking. Normal. 135i N54 had it super loud. All my Subaru DITs have it loud. Sort of a diesel sound.
///M
      06-07-2024, 05:36 PM   #15
pengpeng28
Drives: BMW M2 G87
Phew thank you all 😅
