06-06-2024, 02:00 PM | #1 |
1278
Rep 1,212
REVIEW - Rogue Engineering Short Shit Kit | Rear Shifter Carrier Mount | CDV delete
Simply, the sum of all parts in one word - spectacular.
My original issues were - 1. The shift throws were too long, especially going into 2-4-6. It felt awkward to me with my elbow position pulling the gear lever down for 13 minutes to get it into the next gear. 2. The whole shifter assembly felt vague and rubbery. It didn’t feel precise, just overly dampened and soft. If it was my 24/7/365 car, then I’d likely have wanted to keep it as non-intrusive as possible, but not for a fun summer/weekend car. 3. The clutch engagement was weird, like it is on every BMW with the CDV. The solution - 1. Rogue Engineering short shift kit; 2. Rogue Engineering shifter carrier rear bushing mount; and 3. CDV delete. Because I did all parts at the same time, it’s impossible to determine what has impacted what (and to what degree), but I can say that these parts in tandem have created such a better driver’s experience, that I can’t recommend it highly enough. To get one thing out of the way early, these upgrades will not be for everyone. Shift effort is increased, notchyness is increased, and NVH is increased. For me, all three are not trade-offs, but actually contribute to a much more engaging driving experience. Hearing some of the transmission whine come through, in addition to a much more visceral engine noise experience, is a 10/10. All that combined with the much more immediate clutch engagement with the CDV delete, it’s honestly so much better. That said, for others, it’ll be a non-starter to forgo the very dampened and light shifter movement, and adding the mechanical sounds being transmitted through the lever. OEM is like a gentleman’s shifting experience, whereas my current setup is definitely a bit rougher around the edges. My experience isn’t necessarily going to be yours, but I’d say shift effort is increased 10-20%, and NVH is increased about the same. One poster mentioned the RE SSK he installed made the shift effort intolerable to the point where he’s pulling it out to replace with a different unit. Given my experience, I would blame that on a faulty unit or something RE sent out poorly setup as I don’t experience any of that. This is OEM+++ (not +) still, definitely not ‘only for race car’ or with the tradeoffs being so extreme for a shorter throw. To summarize - - Shift effort increased; - Gear-to-gear throws are dramatically shorter; - The gear selection precision is much better than OEM - no vagueness, no rubbery gear engagement, no slop (although slop wasn’t really an OEM issue); - Notchyness is increased - gear shifts now ‘click’ into place; - Transmission whine is now present (non-existent with OEM); - Engine noise is now present (non-existent with OEM); - CDV delete eliminated all vague clutch engagement when shifting quickly. 100% would recommend for anyone willing to trade some OEM comfort/vagueness/softness (whatever you want to call it) for a notchier, louder, much more precise, and engaging driving experience. I'm usually one to jump on the purchase justification posts, and I usually don't get too excited about my modifications, but this has been the biggest positive change I've had in many a car and many a mod. I did a before/after video (don’t expect high production quality…) to try to show the difference in shift throw between stock and RE, and to show how much more crisp the gear changes are. I threw a straight ruler in as well but hard to see the throw distance changes from the videos I took. I’ll try to get a driving clip as well to demonstrate some of the mechanical sounds being transmitted through the new shifter assembly. Stock - Rogue Engineering - |
06-06-2024, 05:19 PM | #4 |
Forced Induction Connoisseur
1315
Rep 944
Drives: 23 X5MC / 23 720s / 25 M4CS
Garage List 2025 M4 CS [0.00]
2023 BMW X3MC [0.00] 2023 Mclaren 720s [0.00] 2005 Honda S2000 [0.00] 2023 BMW X5MC [0.00] 1964 Ford Mustang [0.00] 1968 Pontiac GTO [0.00] |
Cool, glad yours doesn't suck. Can you take a quick video and show shift effort?
Mine's going up for sale when the CAE gets in.
Oy vey, look at all these shekels
06-06-2024, 05:42 PM | #5 | |
1278
Rep 1,212
Local BMW tech. Zero problems - shifter, carrier mount, and CDV delete, plus a test drive, all done within ~2.5 hours.
My first post has a vid in it - you can see how quickly I can shift without putting much effort into it. Not as easy as the rubberband feeling stock shifter, but definitely not having to muscle it into gear like my track-only car. |
daddyjaxx116.50 |
06-07-2024, 05:28 PM | #6 | |
1315
Rep 944
06-08-2024, 01:19 PM | #8 |
1278
Rep 1,212
Good stuff. I don’t have the patience. RE is out of the box, and their kits have treated me well in the past, so just went for it. I’m sure there’s many ways to improve on the design though, but the incremental improvements aren’t needed in my application. Looking forward to seeing your results though.
06-08-2024, 01:33 PM | #9 | |
Rep 1,267
I’ll start a new thread once in (whenever that is). |
Sleeper1278.00 |
06-09-2024, 02:24 PM | #11 | |
Rep 2,397
Does he wait til he has a queue built up for a certain type? Like 5 G87 requests or something? I’ve heard amazing things about the AS SSKs - especially the bushings he uses with like a 15% reduction.
///M
06-10-2024, 12:04 PM | #12 | |
Rep 1,267
From there he gives YOU his opinion on what you need and you get tossed into the list he built up. When he begins manufacturing on yours you will get an email and be able to pay. |
09-08-2024, 05:37 PM | #14 | |
Rep 1,592
09-08-2024, 07:20 PM | #15 |
Rep 202
Drives: 2024 BMW M2
Any sense what part increased the transmission noise into the cabin? That isn't ideal for me as I daily my car.
09-22-2024, 02:34 PM | #16 |
1278
Rep 1,212
09-23-2024, 12:44 PM | #18 | |
Rep 305
2. https://ind-distribution.com/product...-bushing-mount $129 3. CDV Delete is free unless you mess it up |
Chicanery87.50 |
10-24-2024, 09:05 PM | #19 | |
Car'a'carn
746
Rep 1,140
I saw changing shift knobs is a PITA. Is the OEM shifter a direct swap with the SSK? If it's the same work I would like to get a new knob at the same Last edited by curtdragon; 10-24-2024 at 09:08 PM.. |
Chicanery87.50 |
11-03-2024, 10:25 AM | #20 | |
Rep 202
Drives: 2024 BMW M2
But I have this weird static-like sound just in the odd gears that is barely audible so not a big deal but it is not what I'd expect as transmission whine so I'm a bit perplexed: https://g87.bimmerpost.com/forums/sh....php?t=2144459 Aside from that these are great. Huge difference. Thanks for this thread. |
11-03-2024, 02:05 PM | #21 | |
Rep 832
Drives: M2 G87 Brooklyn Grey
11-03-2024, 07:35 PM | #22 |
Rep 795
Will this void the warranty ? The reason is because Short Shift Kits make faster gear changes possible, which puts more stress on the synchros (because the revs have less time to drop between gear changes). I am concerned for you based on my personal experience, because in my 2014 M235i two second-gear synchros failed in two different gearboxes. The first gearbox was replaced under warranty, without any hassle, however it was a real nightmare to have the second gearbox covered by BMW, so in the end I had to resort to another dealer. And I also had to cough-up $4800 for clutch and dualmass-flywheel replacement, which I think was related to those gearbox problems. This needless to say soured me on the whole BMW ownership proposition for a long time.
