06-13-2024, 11:02 AM | #1 |
Rep 348
Android Auto for music/phone, not for Nav?
Can Android Auto be configured to ignore the Navigation apps (waze, etc)?
I prefer the ID8 navigation interface. I don't mind Android Auto for music/phone Last edited by inevitab1e; 06-13-2024 at 11:08 AM.. |
06-13-2024, 03:19 PM | #2 |
Rep 2,675
Don’t know about Android but with Apple CarPlay, you just select Nav wither via touchscreen or the hard idrive buttons.
Media and phone can be through CarPlay |
inevitab1e101.00 |
06-13-2024, 06:33 PM | #4 |
Rep 288
Occasionally, the Nav button on iDrive in my car (ID8) will take me to the BMW navigation (which I don't want). I think if that doesn't do it for you, I think you could press Home to go back to the main screen, then select the BMW navigation tile? Maybe you can then shortcut that to your shortcuts as well.
Alternatively, you can disable some apps on Android Auto. I somehow doubt it will let you disable Google Maps, but who knows? Found this on the interwebs: ***On your phone*** "In the Settings search bar, type "Android Auto." Tap the first result to open the Android Auto settings. On the Android Auto menu, tap Customize Launcher under General settings. Uncheck the boxes next to any apps that you want to remove from the Android Auto launcher." |
inevitab1e101.00 |
06-13-2024, 07:34 PM | #5 | |
Rep 348
The ID8 button is changed and not accessible like normal. When pressing, it just goes back to android auto (waze, etc) in the AA screen. |
06-13-2024, 07:36 PM | #6 | |
Rep 348
The last bit I think is what I was looking for. Selecting which apps are available through the Android Auto interface. I was able to uncheck Waze and will test the next time in vehicle. Google maps didn't have the option to uncheck, but I'm better off now than before. Thank you |
06-14-2024, 09:48 AM | #7 | |
Rep 288
inevitab1e101.00 |
06-14-2024, 11:53 AM | #8 | |
Rep 2,675
06-14-2024, 12:39 PM | #9 |
Rep 123
i dont connect my phone to android auto. i just go through bluetooth. a couple of reasons i dont use AA is bc i want my hud to display the map and aa was buggy when i tried it out and i am much more comfortable using waze and other apps on my phone than aa. apps seem to have limited functions (or more like, i cant bother to learn them on the aa ui while im driving) and everything is seamless anyways thru bt.
06-14-2024, 01:35 PM | #10 |
Rep 288
I added specificity to your post with particulars to Android Auto. You cannot use the navigation tile because it is linked to Android Auto. You can use the button on the leftmost side though as that is a direct link to the ID8 navigation. You also mentioned the hard buttons would go to the ID8 navigation, this is not always the case when connected to Android Auto; normally the hard navigation button when linked to Android Auto will go to your navigation through Android Auto, not the ID8 navigation. When mine has actually gone to ID8 navigation when using Android Auto using the button, this is a glitch.
I see you mentioned your comment pertains to CarPlay, and not Android Auto. I suspect the functionality is different between the two since our two experiences differ. |
