BMW 2 Series Technical Topics (G42) Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      06-16-2024, 10:29 PM   #1
VegasG42
VegasG42's Avatar
795
Drives: 2024 BMW M240i xDrive
A Bit Of Confusion Regarding The Valve System For Our Exhaust System
More specifically - the dual valve system for aftermarket catback exhausts.
So, simply enough, our factory exhaust has a single valve that opens and closes depending on whether you have the vehicle in Eco, Comfort, Sport etc. , which will allow more or less flow through the exhaust to increase or reduce sound level.
However, I see that there are available for sale, a few catback systems that have 2 flow valves.
And I also see that they also have available a powered unit for controlling the valves, that are engaged with a remote control.
So, once the aftermarket catback is installed , will Eco, Comfort, Sport, etc. no longer control the 2 valves? Or will the controller device with the remote control become the only means of control ? Or do both still work together ?
Here is a catback that has the dual valve system :
Name:  Screenshot 2024-06-16 192540.png
      06-17-2024, 11:54 AM   #2
felixlamb
felixlamb's Avatar
United Kingdom
9
Drives: 2022 M240i xDrive
So that exhaust specifically looks to have vacuum operated valves. The standard valve on the G42 is electronically actuated, so I expect some sort of device would be required required to generate the vacuum for this exhaust (or you have to pull it from the engine). I believe some exhaust systems with controllers have settings to respect the OEM settings though.
I'm curious how dual valve systems work though, to achieve OEM settings (given OEM is one valve only). I assume the original connector goes through a splitter which then connects into both valves?
VegasG42795.00
      06-17-2024, 12:21 PM   #3
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
The stock exhaust is closed on comfort and open in wide open throttle, but it does not open all the way (up to 70%)
Customers get a valve controller to open the valves to 100% for more sound.
When you get an exhaust with valves, in most cases, those exhausts reuse the stock valve motor so that it will act exactly like stock.
You can still use the sports buttons to open the valves, but they only open to 70% without a valve controller, just like the stock system.
https://x-ph.com/sale/
Phone number 702-494-9435
kudos265.00
VegasG42795.00
      06-18-2024, 09:58 PM   #4
VegasG42
VegasG42's Avatar
795
Ah, okay, that makes sense now. I was trying to understand how the two systems worked together. Thank you
      06-19-2024, 10:59 AM   #5
mike@x-ph.com
My pleasure
      06-19-2024, 08:59 PM   #6
G$Money
Drives: 2023 m240i
I bought the Dahler controller second hand on this forum and it is Gucci. Cleanly mounted inside the trunk by the battery, and the remote is velcroed to the back wall of the compartment where the phone charging pad is. I mostly set the valve to always open and it stays that way until you change it
      06-19-2024, 09:50 PM   #7
VegasG42
VegasG42's Avatar
795
Nice, thank you for the feedback.
Are you using the valve controller to operate the valve on the stock exhaust, or do you have an aftermarket catback?
      06-19-2024, 10:02 PM   #8
G$Money
Drives: 2023 m240i
No problem! On the stock exhaust
VegasG42795.00
      06-21-2024, 10:14 AM   #9
TopG42
M-Lite Enjoyer
TopG42's Avatar
48
Drives: G42 M240i
I unplugged the valve cable yesterday while it was in sport so does that mean mine is only open 70% at all times as opposed to the 100% you achieved from the controller?
      06-21-2024, 12:32 PM   #10
mike@x-ph.com
70% or less.
Note sport mode does not automatically mean the valves are open at 70%. It can fluctuate but reaches a max of 70% without a valve controller.
when you unplug the controller, it gets stuck in the current position.
TopG4247.50
      06-21-2024, 08:30 PM   #11
TopG42
M-Lite Enjoyer
TopG42's Avatar
48
Drives: G42 M240i
70% or less.
Time and time again you come in clutch with the info!
I will be ordering the sst exhaust valve controller from you soon then. I actually ordered it and cancelled because someone I know told me the valve unplug would work the same but what you just said makes alot more sense considering I unplugged it and was NOT WOT meaning theres no way its stuck at 100% open rn. Thanks again Mike!
      06-23-2024, 09:28 PM   #12
kudos
kudos's Avatar
265
Drives: BMW M240i
I was under the impression sport was 70% but sport+ was 100%.
E90
      09-20-2024, 04:31 PM   #13
whatthehuck
whatthehuck's Avatar
the thing I still don't understand is why the aftermarket exhausts don't just include a valve controller that opens 100% AND is able to be controlled by the factory plugs. The whole valve system is already there, electrical wiring etc, seems like it wouldn't be any problem at all to just replace the valve motor with one that opens 100% and be done without having to rewire stuff.
      09-20-2024, 08:29 PM   #14
MPR
MPR's Avatar
2033
Drives: 22 M240i
I recall seeing a pic on the forums recently showing the valves open 100% using the fuse pull trick while in sports+. Can someone with a factory exhaust without aftermarket tips confirm the truth for us?
      09-21-2024, 11:00 AM   #15
mike@x-ph.com
i have not seen that but why would you want to mess with the fuses when you can control the valves for ~$250 with a valve controller
      09-21-2024, 11:08 AM   #16
MPR
MPR's Avatar
2033
Drives: 22 M240i
Is this a trick/sarcastic question that is going over my head?
1. I like spending $0 instead of $250.
2. I never need it to be quiet.
3. Its a single fuse, not fuses. Easily reversible.
      09-21-2024, 11:36 AM   #17
oldbmwtech
oldbmwtech's Avatar
261
Drives: BMW M240i
BTW, the valve does open 100% in sport+. There is another thread about this with photos but you can see for yourself.
MPR2033.00
      09-21-2024, 11:56 AM   #18
mike@x-ph.com
If you want the valves open all the time, just unplug the valves and keep the valves open. You do not need to mess with the fuse and it also $0. thats not what the valve controller does.
This upgrade is for those who want the flexibility to switch back to quiet mode when needed. For example, I would never want my cold start with the valves open, and I would also not want them open when driving in the neighborhood early or late. Others may not want the valves fully open while picking up their kids from school, going to work, or taking clients.
      09-21-2024, 12:19 PM   #19
MPR
MPR's Avatar
2033
Drives: 22 M240i
Removing the plug then exposes the plugs pins/plug to the conditions. Better to just remove the single fuse when the valves are open, the plug then remains connected and protected.
Agreed, if I was worried about having the valve closed for cold start or at night time then I would definitely consider the controller. IMO, the car is quiet enough with the factory exhaust system where you can drive in a neighborhood at night without making noise.
      10-04-2024, 02:37 PM   #20
Info@mad-us.com
Info@mad-us.com's Avatar
3417
Drives: bmw
Agreed. Our controller Will allow you to open fully 100% 50% or you can switch back to oem with the click of a button. If remotes aren't your thing you can also connect it to your homelink button on your mirror.
- Click Here
Performance Parts For Your Bmw At Crazy Low Prices!
5% OFF Code "BimmerPost" Email: info@mad-us.com
h3600.00
      11-18-2024, 10:36 PM   #21
GKirt
Drives: M340i
The question still stands, why is someone not selling a system that utilizes the factory wiring to control 1 or 2 aftermarket valves with the drive modes? Would the computer not like the aftermarket valve and throw a code? Are electronic valves so inferior to the vacuum controlled valves that it’s not worth it? I’m thinking about making a custom valved exhaust for my G20 and I’m weighing my options
      11-19-2024, 08:43 AM   #22
jammy8911
Drives: BMW G42
Factory exhaust here. Putting the car in sport + opens the flap 100%, then pulling the fuse keeps it open. No error codes on car dash but will throw a code when scanning ODB port. You can put the fuse back in and car will return to stock. Zero cost method to making the car sound a bit better in all modes.
MPR2033.00
