BMW M2 Forums 2023+ (G87) Wheels | Tires | Suspension | Brakes | Chassis
      06-19-2024, 07:03 PM   #1
Prullo
Drives: BMW M2 Porsche GT4 Honda CTR
Square wheel set up G87 M2 interfering with traction control
Hello,
I did do a search on the forum for "interfering with traction control" and was not able to find anything specific to the topic.
I would like to do a 19 x 10 square Apex set up with 285 35 19 tires.
I have read somewhere that this can interfere with traction control. Does anyone have any experience with this?
Thank you for any information you can provide.
      06-19-2024, 07:13 PM   #2
Svet
Drives: 2008 E90 M3, 2023 M2
You will not have such problems with the m2. Generally traction or transfer case problems can happen on 4wd cars where there is a large variance in size between front and rear tires. Land Rovers in particular are supper sensitive to that.
      06-19-2024, 07:18 PM   #3
ZPD
ZPD's Avatar
664
Drives: 2022 M850i GC, 2023 G87
Not a problem
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Goodyear 3R, SPL links, Adro wing, IRL exhaust, Racechip, Verus Splitter; IG:g87_43
      06-25-2024, 09:46 AM   #4
ZPD
ZPD's Avatar
664
Originally Posted by maxwell smart View Post
The G87 has a special setting in the tire settings app. it's called racetrack/special authorization tires. when you choose that setting it automatically sets it up for a square setup , furthermore your phone app will stop telling you to add 2 more psi to your tires all the time like the standard tire setting prompts you to do constantly even if the tires are not low. I used this setting last year and it works great.
What are you talking about? Can you provide a link for this? What does the app do to allow for a square setup? I have my tires set to racetrack (or whatever it is called) and I still get low-pressure alarms on the dash when it goes below 27 psi.
2022 M850i
