BMW M2 Forums 2023+ (G87) Issues, Repairs, Warranty, TSB, Recalls
      07-01-2024, 04:24 PM   #1
Dirtywabbit
Drives: M2 G87
Door creak while opening/closing?
Anyone have experienced creaking noise while closing/opening the door?
In my case when closing the driver side door while is 70% closed there is this creak that is annoying the crap out of me. I can literally move the door open/close and make a symphony with the creak it’s making.
      07-01-2024, 07:01 PM   #2
BroDoze
Drives: 2025 M2 LCI
Dealer. Warranty issue.
///M
      07-03-2024, 12:59 AM   #3
1slowspec3
Had same issue. Sprayed a little wd40 into the black door hinge , the part going into the door. No more noise!
BroDoze2333.50
      07-03-2024, 02:00 PM   #4
Dirtywabbit
Drives: M2 G87
Thank you. I’ll try this vs having the dealer take apart the doors.
      07-17-2024, 12:39 PM   #5
motorknut
Drives: BMW G87 M2
i started noticing this too. will try asking the dealer when i get some delivery issues fixed.
      07-17-2024, 12:55 PM   #6
Dirtywabbit
Drives: M2 G87
My friend who also has a brand new m2 started to hear the same creak….. like wtf. I added grease in the black arm looking thing and didn’t do anything.
      07-17-2024, 01:27 PM   #7
M_Power Rob
Drives: '23 M240 and '23 M2
Using WD40 is unwise.
Taking it to the dealer is the best method. They won’t pull anything apart, but they will clean and use the appropriate grease as needed. If they determine a part is faulty they’ll replace it.
If you know which grease they use (perhaps your dealer is far, so call their service department and ask), use that grease to try to fix the issue.
Don’t use WD40.
Agree...WD40 is no bueno.
m3616.50
      09-02-2024, 09:24 AM   #8
Dirtywabbit
Drives: M2 G87
For anyone with this issue. I sprayed white lithium grease and too care of the issue.
      09-22-2024, 12:27 PM   #9
TheSIG
TheSIG's Avatar
Drives: BMW M240i XDrive
I experience a sound like this, but it seems to be from the window going back up.
