BMW 2 Series Technical Topics (G42) App, Nav, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics
      07-03-2024, 12:01 PM   #1
Marylander0101
Drives: M2
fuses functions for 2024 m2
does anyone know what these fuses do :
f47(20a) f51(30a) f224(30a) f227(30a) f229(40a) f259(15a) f265(30a)
Was going to use F259 for my hardwired POWERCELL8 leveraging an add a fuse powering a dashcam
https://www.blackboxmycar.com/produc...SAAEgJKhPD_BwE
      07-03-2024, 12:32 PM   #2
Pentland
Drives: BMW M240i (G42)
Might get a better response in the M2 forum.
      07-03-2024, 12:38 PM   #3
Marylander0101
Drives: M2
Oh thanks, i thought i was in the m2 g87 forum :/
      07-06-2024, 09:28 AM   #4
BlueLEDz
BlueLEDz's Avatar
248
Drives: 2023 BMW 230i
If you are still looking for the fuse information, check out this site.
https://www.bmw.cc/en/topics/offers-.../fusecard.html
Enter your vin and the system will display the fuse panel layout.
      07-24-2024, 05:24 PM   #5
Marylander0101
Drives: M2
Thank you! i got the fuse card but it doesnt really specify exactly what each fuse does. I have a handful to choose from that are in the ENGINE category but i am unsure which exact part of the engine each fuse is assigned to.
I am thinking about using f259 a 15 amp fuse ( and only 15 amp fuse) in the engine category and just putting the battery draw on low. However i am not sure on what this fuse does for the engine specifically on a 2024 m2
      08-13-2024, 07:59 PM   #6
BlueLEDz
BlueLEDz's Avatar
248
For my dashcam, I used the 12v socket fuse.
Fuses F46, F251, F273 are for the 12V socket. However your car may not have all of those since the rear 12v socket was removed
      09-18-2024, 07:00 PM   #7
Marylander0101
Drives: M2
You are the best! Now I have to figure out the best way to route my wires all the way from the dashcam to the rear of my car. The fusebox is actually hidden by a breakaway cover on the passenger side of my trunk. Any ideas on the cleanest method ? Did you go through the A piller ( airbag area) ?
Cleanest method to wire into the fusebox when its on the right side like that?
      09-19-2024, 01:29 PM   #8
Pentland
Go along the roof lining to the RHS, under the a pillar cover and go behind the airbag. Use cable ties to tie into the existing loom. Follow down to the floor and tuck cable under carpet and under the door sill.
Feed under the back seat ant to the boot.
Use the battery terminals for constant with an inline fuse.
