      07-08-2024, 01:36 PM   #1
TimothyW13
Drives: M850i
M850i, running a 0-60 time of about 5.0 seconds
Hi everyone, I have an M850i that I bought with 20k miles on it 6 weeks ago. I noticed it was definitely not performing as I expected since getting it. I bought a dragy and I'm reliably running a 0-60 time of about 5.0 seconds (4.9-5.3 seconds). Engine readout on the car is showing good HP and torque... above the 560 that the display caps it at.
I brought it to the dealer today and they told me, sorry, we can't see any codes... maybe the fuel that's in it isn't good enough. They suggested that I could only get a 0-60 time in the 3s if I was using launch control, not comfort or sports mode.
What do you guys think? Anyone else have this kind of problem? What might be a good course of action for me?
      07-08-2024, 01:47 PM   #2
NYG
NYG's Avatar
Drives: Audi R8
Are you getting these times with launch control?
      07-08-2024, 02:29 PM   #3
pz619
Drives: F87 M2C 6MT, Tesla Highland 3P
I wouldn't think you would get into the 3s without launch control. I wouldn't necessary expect 5 seconds but 4s sound reasonable if you are just mashing the pedal from a standstill, without building revs.
      07-08-2024, 05:27 PM   #4
Neusser
Neusser's Avatar
Germany
813
Drives: G31 540i; F87 M2 Comp.
Well, what fuel are you using? Sports mode should get you there, partic. if you have the tranny in sport as well.
      07-08-2024, 05:33 PM   #5
TimothyW13
Drives: M850i
Hey, yah I'm using only 93 octane. All sports mode or comfort seems to have about the same result, 5.0 -5.2 seconds from stopped
      07-10-2024, 08:06 PM   #6
24CBX4M40i
Drives: 2024 CB X4 M40i
Those times u see published use a 1 foot roll out..so they get a running start so to speak
      07-10-2024, 10:28 PM   #7
Mason Hatcher
Drives: BMW X3
In comfort and sport the nannies reduce engine power and apply braking to prevent wheel spin. The numbers you are getting make absolute sense.
Try launch mode and post the results.
      07-11-2024, 09:24 AM   #8
MineralWhiteF80
Dont listen to me
916
Drives: F82, E92 M3, '25 Taycan4S, E46
OP, you are likely overthinking this and inventing a problem when there isn't one. It sounds like your car is running normally and the expectation of a specific 0-60mph time is not realistic.
Car manufacturers go to great lengths to post certain 0-60 times, but in reality, to get that published time, you must follow a very specific set of requirements for car setup, environment, road conditions, tire model, fuel level, density altitude, moon phase, etc. Then you have the actual measurement method of the time and when the time starts, such as the "1 foot rollout" rule.
Instagram: @thatwhitem4
      07-11-2024, 09:34 AM   #9
p0p
Ninja
177
Drives: N54 & B58
Maybe Sport Mode with Traction control off and launch in 2nd -
      07-11-2024, 12:41 PM   #10
Mason Hatcher
Drives: BMW X3
      07-11-2024, 01:09 PM   #11
p0p
Ninja
177
Drives: N54 & B58
Originally Posted by Mason Hatcher View Post
Why the sarcasm?
Try it - Even some M cars will only launch control in 2nd
My F30 TCU is set to start in 2nd when warmed up.
      07-11-2024, 03:33 PM   #12
TimothyW13
Drives: M850i
I completely understand what you're saying and agree to an extent... but I find it hard to believe that a car with roughly 600 lb ft of torque and 570hp real world shouldn't be able to beat my old mustang or the genesis g80 (with roughly half the torque and hp, similar weight) that I traded in for this m850.
      07-11-2024, 03:38 PM   #13
TimothyW13
Drives: M850i
I have not tried this, I actually didn't know you could launch from 2nd, I'll see if it'll do it though! I can get as good as low 4s if I hold gas and brake for a second and then release brake, but it's really more just across the whole acceleration band when it's not a launch. Like I responded to the other guy, I feel like you'd kind of expect a flagship engine from bmw to be able to beat a mustang or a genesis across the band.
      07-11-2024, 03:45 PM   #14
Michael1316
Drives: E90 328i, 2025 M2 - Ordered
Are you using the cars actual launch control mode? You're not going to get the advertised 0-60 times if you're just mashing the throttle pedal from a standstill.
      07-11-2024, 04:43 PM   #15
eleven11
eleven11's Avatar
Drives: -F85 X5M-
I agree with you, OP. I think you should be able to a least slip under 4 seconds without launch control.
Being a used car, I'd throw some Liqui Moly voodoo at it (Fuel/Injector/Oil cleaner - all of it) - might do nothing, but will cost you less than $100.
I'd also find a reputable independent mechanic near you, ideally one who deals with modified cars regularly. You might have a minor boost leak.
Are you slipping at all (i.e. tire grip)?
2017 X5M - Current
2017 F31 Wagon - Current
2014 M5 ZCP - Retired
2011 135i Coupe - Retired
2007 335i Sedan - Retired
      07-11-2024, 05:36 PM   #16
TimothyW13
Drives: M850i
Sweet, thanks man. Yah, I just threw in a bunch of fuel system cleaner and I haven't tested with dragy yet but it does feel a bit more responsive. It's over 90f here every day right now so it's hard to test out without temperature slowing the damn car down further.
I did think there might have been a bit of tire slip. The car came with all season run flats so I just bought some sweet Michelin pilot 4s summer tires. Really hoping that'll do something good. Thanks for the suggestion about the boost, I will follow through on that and let you know!
eleven11410.50
      07-12-2024, 10:57 AM   #17
Ugly Kar
Drives: E92 to C43 Cab to G42
Have to agree. Even the tests you see with testers not using the rollout are only .2-.3 sec slower. And that's pretty much what I've experienced even with LC off. I wouldn't be happy if I paid M850 $ and couldn't get within .5 sec of the best magazine tester times.
      07-12-2024, 12:38 PM   #18
TimothyW13
Drives: M850i
Thanks man, good to hear someone else who doesn't think I'm crazy for being upset about it.
      07-12-2024, 12:51 PM   #19
G30M
G30M's Avatar
5274
Drives: M550i; retired - M340i
i have a M550i and with brake boost i timed it at 4.35 0-100, didn't do more as too scared to break it.
are you using brake boost?
i am presuming without brake boost it will be 5 seconds 0-100
the throttle response in every auto non hybrid BMW i've tested without brake boost is crap, even my 2007 Toyota moves off the line faster
my 2.5 tonne EV Kia however, is 3.7 0-100 every single time (did >20 runs in an hour) without brake boost and it spins all 4 wheels all the way to 100 (now winter). i will try again in summer to see if i can get another 0.2 with better traction
      07-12-2024, 04:54 PM   #20
bimmertricks
bimmertricks's Avatar
Drives: G30
Definitely need car in sports+, traction control/ dsc mode off. And transmission should be flipped in sport as well. Launch control shouldn’t need to activate to reach 3s-4s. IMO, the car definitely has some issues if you cannot do that
      07-12-2024, 05:09 PM   #21
G30M
G30M's Avatar
5274
Nah, the car doesn't move until the rpms hit 3000.
So if you don't brake boost, it will crawl slowly until it hits 3000rpm before it flies. That thing weighs a good 2 tonnes.
      07-13-2024, 03:25 PM   #22
G30M
G30M's Avatar
5274
did about 6 brake boosted 0-100 in a row in my 550 on a cold frosty morning today
average 4.2s, fastest i got was 3.99s
never even bothered without brake boosting, i don't want to see the number lol
my brake boosting is to let go as soon as the revs stop climbing (around 2100rpm), so i didn't even build that much boost, just enough to give it a kick in the ass.
i feel the TC intervening in some runs so could have been faster with DTC but i don't want to be unsafe
