07-10-2024, 09:55 PM | #1 |
Rep 5,120
BMW app shows lower mpg figure than iDrive!
I've found that the fuel consumption display on the car with iDrive 7 is always higher than what the app shows.
Anyone found that? (I'm comparing fuel consumption in a particular day on the app vs iDrive for that day.) |
07-11-2024, 11:10 AM | #2 |
Rep 8,336
If you keep a running tally to get the average from both calculations...you may find that the difference is negligible...or it could indicate a big difference.
I keep an excel spreadsheet of avg mpg were I track what the OBC says and what the avg mpg from every gas fill calculates to be. They may not always be the same results, but as I average out each column...by the end of the year they always end up being very close to each other. Here's an example below from my old 2014 650ix GC...you can see that there's only a difference of 0.235066 MPGs when you compare the accumulated average of column G (calculation from tank miles and gallons of gas at previous fill-up) vs column H (OBC calculated MPGs that appears in the car's screen display):
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 07-11-2024 at 11:31 AM.. |
