07-11-2024, 03:40 PM | #1 |
Rep 285
S58 Engine: Cooling System Schematic/Layout
I was doing my own research trying to understand the 5 different radiators used on the S58. Most search results all talked about the mesh guard options available and not the actual layout of the cooling system. Luckily I found someone posted a technical manual for the engine and I ran across this schematic/drawing.
Hopefully this helps others in the future looking to see the whole cooling system comprehensively. It starts on page 86 of the engine manual. https://www.bimmerpost.com/goodiesfo...S58-Engine.pdf
Car History (oldest to newest): Accord, 318i, 330i, Prius, Prius, M2
07-11-2024, 03:42 PM | #2 |
Rep 285
Actually 6 coolers if you also include the indirect charge air cooler. That is a whole lot of cooling!
07-12-2024, 08:54 AM | #3 |
Rep 359
Can you post the second page? I am curious if any radiators are in series and if they all use the same pump.
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Goodyear 3R, SPL links, Adro wing, IRL exhaust, Racechip, Verus Splitter; IG:g87_43 |
07-12-2024, 09:01 AM | #4 |
Rep 285
Does this link work? Here is the whole manual: chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://www.bimmerpost.com/goodiesforyou/docs/ST1926-S58-Engine.pdf
07-12-2024, 09:03 AM | #5 |
Rep 285
Here is the full manual in PDF form
CadolinaRipr444.00 motorknut42.00 |
07-12-2024, 09:10 AM | #6 | |
Rep 359
Thanks!
2022 M850i
07-12-2024, 09:25 AM | #7 |
Rep 285
No worries, hopefully the full PDF works for you. I think this is one of the best documents I have seen shared on this engine, so would be amazing if others out there have more technical documents like this to share on other components/aspects of the car & chasis.
lensnaH4.50 |
08-03-2024, 08:55 AM | #8 | |
Rep 637
TallGibbs390.00 |
