BMW 2 Series Technical Topics (G42) Wheels / Tires
      07-12-2024, 02:02 PM   #1
inevitab1e
inevitab1e's Avatar
102
Drives: 2023 M240i G42
Vredestein ULTRAC PRO tires?
I'm looking to replace my OEM Pirelli PZero runflats with a non-runflat.
I noticed this new tire design and the price seems good. No reviews.
Do you think I could get away with a wider front/rear tire on the stock wheels?
--Current setup--
Non-ZTK
OEM 791M wheels = 8" front, 8.5" rear width
OEM Pirelli PZero runflat = 225/40R19, 255/35R19
--New tires--
Vredestein ULTRAC PRO = 235/40ZR19, 265/35ZR19
The Vredestein SPEC section says the rear 265 tire needs 9" rear wheel width. Will this work with 8.5"?
Additionally, what's the spacer setup for non-ztk? 12mm/10mm F/R?
Thanks everyone.
Vredestein ULTRAC PRO link
      07-12-2024, 02:38 PM   #2
NKiss
Drives: 2024 BMW M240i
--Current setup--
Non-ZTK
--New tires--
Thanks everyone.
Stretching a tire "can" lead to rapid degradation, it all depends on how hard you drive. If you drive like a grandma then you should be ok, I personally wouldn't risk it.
I'm facing the same dilemma, I want more tread on the ground, but not ready to burn $3-4K for rubber on a brand new car.
      07-13-2024, 09:58 PM   #3
NKiss
As for spacers, I just ordered 12mm Front, 15mm Rear. Waiting on Dinan to get the 15mm's in stock. Also make sure whatever size, you get correct length lugnuts.
      07-14-2024, 08:25 PM   #4
inevitab1e
inevitab1e's Avatar
102
What's your current tire/wheel setup? Most of the spacers I would buy come with extended lugs, so should be good.
      07-15-2024, 11:37 AM   #5
NKiss
I have the factory 19" wheels, I believe 225F 255R.
