BMW M2 Forums 2023+ (G87) Wheels | Tires | Suspension | Brakes | Chassis
      07-14-2024, 01:50 PM   #1
NekoRacing
NekoRacing's Avatar
20
Drives: bmw g87 m2
305 square on 19x11
Went to SCCA TX time trail event yesterday at ECR. Trying out some v730, 305 square definitely helps with corner entry rotation a lot.
Doesn’t feel much faster than PS4S star spec. But it’s cheap and last long , good practice tire!
ZPD662.50
Montaver2724.50
sebaflex133.50
      11-02-2024, 02:00 AM   #2
curtdragon
Car'a'carn
665
Drives: I drive one
What offset and spacers are you running?
I'm trying to find this setup without spacers.
Polo088161642.50
      11-04-2024, 11:44 AM   #3
Polo08816
Drives: 2014 335i M Sport
Curious about this (and suspension) setup as well.
      11-04-2024, 07:48 PM   #4
LeggoRacing
LeggoRacing's Avatar
240
Drives: M2
Different setup but apex 19x11 square with 305 Goodyear 3r (12mm rear spacer and 15mm front spacer ). Need at least -3.3 front camber for it to clear. No rubbing otherwise
Lienrocs754.00
      11-04-2024, 08:21 PM   #5
curtdragon
Car'a'carn
665
Drives: I drive one
Do they just not have an offset that would work without spacers?
I feel like if I'm gonna buy spacers I'll just keep the stock wheels
      11-04-2024, 10:08 PM   #6
LeggoRacing
240
Drives: M2
Pretty sure the Titan wheels from PHD Racing don’t require spacers due to the lower offset.
      11-12-2024, 04:41 PM   #7
NekoRacing
NekoRacing's Avatar
20
Drives: bmw g87 m2
Mine is 19x11 +8, also getting set of 18x11 +9. Both would work with no spacers. Personally I don’t like using spacers, less unsprung weight is always better
Mike_H_360.00
      11-12-2024, 04:43 PM   #8
NekoRacing
NekoRacing's Avatar
20
Drives: bmw g87 m2
Stock suspension, if you don’t wanna use camber plate, get this fender clearance kit. No rubbing
      11-12-2024, 04:51 PM   #9
NekoRacing
NekoRacing's Avatar
20
Drives: bmw g87 m2
Gonna try these 18x11 +9, with 295/35-18.
See how it performs compare to 19s
Mark_1737.50
      11-12-2024, 10:52 PM   #10
Orange fever
Orange fever's Avatar
2610
Drives: E36M,E46M,E90M,X5M,i3,M2,i8,M2
Was looking at does, keep us posted
G87 M2 25 Frozen Pure Grey Metallic-Lightweight lip,Macht Schnell spacers n stud conversion,KW`s-HAS
F87 M2 Aw-Vorsteiner Aero Kit,VFF-107,Macht Schnell Springs,VF-Engineering/Hex tuning Stage2,ER DP,Stock Exhaust,Drop-In Bmc Filter,AA Intercooler,FTP Charge pipe+boost pipe
      11-13-2024, 12:48 AM   #11
bluekitty
Drives: 2024 BMW M2
the stock brakes fit without any clearance issues?
      11-13-2024, 07:07 AM   #12
TallGibbs
Drives: 2024 M2 (coming Sep '24)
NekoRacing shouldn’t a 18” wheel go up to 40 profile sidewall? OEM the 19” wheel is 35 profile (with the rears 20” being a 30 profile).
Car History (oldest to newest): Accord, 318i, 330i, Prius, Prius, M2
      11-13-2024, 09:45 AM   #13
NekoRacing
NekoRacing's Avatar
20
Drives: bmw g87 m2
Depends on the manufacturer, this wheel manufacturer made sure it will clear stock calipers with their barrel. I’ll keep you updated
      11-13-2024, 09:54 AM   #14
NekoRacing
NekoRacing's Avatar
20
Drives: bmw g87 m2
Yes, 275/40-20 would be the ideal size for track matching stock sidewall thickness. Both the GT4 and M2 Racing will use 300/40-20 slicks. But most track guys and I’ve been running 305/30-19, it’s a very popular tire size with a lot of options. Downsizing thickness is not a big problem to TC as long as front and rear keep the same ratio. Some people prefer the corner turn in feeling of smaller sidewalls ,the car feels more responsive. But I’m giving 295/35-18 a try to see if I like how it feels.
TallGibbs390.00
      11-13-2024, 09:59 AM   #15
NekoRacing
NekoRacing's Avatar
20
Drives: bmw g87 m2
Will do! Lead time was 2 weeks, and it’s finally in a shipping container on the way here. $1750 for a set of 11” forged wheel, can’t complain, very excited to try these compare to my 19”.
      11-13-2024, 10:07 AM   #16
TallGibbs
Ah ok got ya: so no worry about overall OD being different. Simply going for track setup/feel of the car and what tire options are available. I was assuming the constraint of keeping final OD the same as OEM spec tire as the design constraint.
      11-13-2024, 10:13 AM   #17
NekoRacing
NekoRacing's Avatar
20
Drives: bmw g87 m2
Don’t worry about overall OD being a little different, that’s one of the easiest way track people modify their final drive according to different track preferences (acceleration/top speed of each gear). As long as front and rear is the same ratio, you’re good to go!
TallGibbs390.00
