07-15-2024, 11:01 AM | #1 |
Rep 2,491
Drives: 9Y0 Cayenne S
Do WiFi boosters work?
Small area of indoor coverage. Looking for better WiFi in the home office which is blocked by several walls between the router location.
Do boosters work? I have had excellent results with cell boosters but have not used a WiFi booster. Thanks for comments. p.s. I searched and did not find a thread for this. |
07-15-2024, 11:15 AM | #2 |
Rep 3,317
WiFi boosters/extenders/repeaters are pure junk. Don't ever use them. There's no reason to use them when there are so many different options out on the market now with mesh WiFi systems. Boosters/extenders/repeaters hurt WiFi performance by increasing latency and the network bandwidth gets halved when going through these things.
07-15-2024, 11:41 AM | #3 | |
Rep 3,317
Second, the latency reference I made is due to how WiFi works. WiFi is similar to a half duplex network. This means only one device can broadcast at any given time. When you have an extender/repeater/booster, the client would send data to this device. Then this device has to send this data to the wireless router as its client. The same goes for return traffic. While this is occurring, no other device can broadcast on the wireless network until this transaction is done in any given direction. Wireless mesh systems avoid/minimize these issues by using a dedicated wireless backhaul that isn't associated with the wireless client to AP connectivity. |
07-15-2024, 11:45 AM | #4 |
Rep 1,002
Also move everything that supports it to 5 GHz wifi, because 2.4 GHz is a train wreck with limited channels. I have different wifi SSID network names on my 2.4 and 5 GHz networks, so that I know that only stuff that doesn't support 5 GHz is using 2.4.....
chassis7971.00 |
07-15-2024, 11:49 AM | #5 |
Rep 3,317
I know a little about these stuff because it's part of my job. I've assisted in scoping wireless networks for organizations and Federal agencies. I'm by far not an expert. But can provide decent guidance over general deployments. I also play with the stuff in my home. I have an Aruba Networks wireless system with 3 APs and a hardware controller, a SonicWall wireless system with a single AP managed by one of my SonicWall firewalls, and a Cisco wireless system with 2 APs managed by a virtual controller. All of these are running in my house.
07-15-2024, 11:51 AM | #6 |
Ninja
177
Rep 150
Any AX router should cover any small area even with walls in between.
Also for things like Nest Thermostat, door bell or garage opener i create its own 2.4ghz Wifi. 2.4 has a wider rang, but a little slower. Also adjusting you channels makes a big difference especially if you have a lot of other wifi around you. |
07-15-2024, 11:55 AM | #7 | |
Rep 3,317
You're correct with the limited channels with 2.4 which there are only 3 available. And the channels get more limited when you go up in wireless speed as channel bonding is required to get the higher speed increments. 5 GHz as you've pointed out has more channels available to avoid interference and to be able to channel bond to get the faster speeds. ETA: People fall into the trap about how they want the hotest signal strength so you see full bars at where your wireless client is going to be used. But people don't think that these wireless clients don't output the same amount of power as an AP. It's counter to the goal of a mobile device. Mobile devices are more concerned over energy efficiency and use time before needing to recharge the battery. This is why in a business/organization multiple APs are deployed in areas where mobile clients are likely to be used. You want the AP and the wireless client to be as close as possible. In some cases depending on the wireless client density, there can be multiple APs in the same room. You see this in large conference rooms.
07-15-2024, 12:38 PM | #8 |
Rep 111
This is what solved a poor signal on a second floor for me - https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1.
chassis7971.00 |
07-15-2024, 01:02 PM | #9 |
Big Beaver Smile
2141
Rep 3,799
My house is 4 floors built in 1864. It’s built with stone/stucco/horsehair/brick and God knows what else so of course Wi-Fi is a nightmare here.
I also like a bit of tech -13 Sonos wireless speakers (running cable is also a nightmare), cameras, door locks, thermostat, smoke alarm, smart plugs, you get the picture. I’ve tried extenders, but never ended up with good results. I had decent coverage with my last router but just replaced it with a Netgear Orbi 960 on my 3rd floor, and 1 satellite on my 2nd floor. The coverage is unbelievable. It even reaches to my back yard now and even the Sonos (everybody is having problems with since a recent new release) works perfectly. The week after I bought it, they released a 7 series for way less money which I’d bet would be just as good, but oh well
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch |
07-15-2024, 02:11 PM | #10 |
Rep 1,750
I have orbi in a bedroom and it works...you can't stream Netflix in 1080 but it works from having 0 signal (previously) to now having a decent signal...and it didn't impact anything else in our house. So yes, they absolutely work depending on your goals
07-15-2024, 02:25 PM | #11 | |
Rep 1,002
FWIW, my place of employment until I involuntarily retired a few weeks ago has 600+ access points spread across 26 or so buildings, and had the most, um, eclectic collection of BYOD devices that have challenged several vendors' wifi infrastructure over the years with various wifi compatibility issues. A lot of that stuff was intended for home use with a single access point on a flat IP subnet, and barely supports WPA2-personal never mind enterprise encryption. I noticed that some major home ISP's are shipping their consumer wifi gateways with separate 2.4 and 5 GHz SSIDs out of the box, but I have never looked at their instructions to see if they tell the customer why they should connect to the network name that ends in "-5" or something similar to identify the preferred band.....
07-15-2024, 03:40 PM | #12 |
Rep 2,491
Thanks for the comments.
Non-IT professional here, as if that wasn’t obvious! I am using a SurfBoard SBG10 (I know). I want to avoid buying a new modem. The SBG10 has 2 Ethernet ports. Can I buy a better router and connect via Ethernet cable to the SBG10? Or will the new router and SBG10 router fight each other? ps of course Google has answers, none of them useful. |
07-15-2024, 03:55 PM | #13 |
Rep 1,003
I’ve fought home routers for years, most don’t seem to last very long (heat seems to be their downfall).
At a prior house, which was 3 floors and a lot of distance from the entry point for Internet and use points for mobile and streaming devices, we tried Velop. Had one master and three others. They were great when working, but needed to be reset too often for my likes (and way too often for my wife’s). I don’t know why; but hard reset to all, then turn them back on in sequence resulted in good performance again. That was 2018-2020 Since my last Velop failed, we bought an Amplifi Alien. Now in a smaller house and able to locate it more centrally. Much easier to manage with their iPad/iPhone app, has not needed a reset in 18 months (although I do it now and then, and power outages also do it). The thing is a tank. However I found out that it is hard (or maybe impossible) to extend when you buy just one - have to buy them in pairs or threes if that is the plan. (That is 18 month old info, their products now may be more adaptable/extendable.) The Alien is a great home router, and worth the extra cost, in our experience. |
chassis7971.00 |
07-15-2024, 07:17 PM | #14 | |
Rep 3,317
Can't say what the ISPs are telling their customers on the differences between 2.4 and 5 GHz. I've never used ISP provided equipment since getting off of DSL decades ago. I've always used a cable modem I bought and provided my own hardware sitting behind it. |
07-15-2024, 07:21 PM | #15 | |
Rep 3,317
07-15-2024, 07:33 PM | #16 | |
Rep 2,491
07-16-2024, 07:30 AM | #18 |
Rep 2,039
I agree, repeter and extender are good let says to get your outdoor wifi dongle for something like lights, pools, water, etc.
For serious stuff : mesh. In my case, Ive opted to move the router in the middle of the house, in the ceiling. Not super practical when I need to access it, like once every year, but I have coverage everywhere, and looks clean. |
chassis7971.00 |
07-16-2024, 08:05 AM | #19 |
Rep 3,317
I have to repeat. No one should be using a repeater/extender/booster when there are very good mesh systems available. Repeater/extender/boosters are just pure junk with today's technology.
I also want to comment about placement of wireless routers and access points. Pretty much every wireless router and access point designed for indoor use have omni directional antennas. What does this mean? Depending on the characteristics of the antenna, meaning the gain, will affect the RF pattern. An omni directional antenna with a gain of 0 will be a spherical RF pattern in three dimensions. As you increase the gain, the RF pattern changes to have more "squish" in the middle but extending the range/reach of the RF signal out the x and y axis. Many antennas included with wireless routers and indoor access points have a gain which has the RF pattern represent a donut shaped output. So when you have a device with internal antennas, you have to keep this in mind when moving a wireless router/access point in your home. You may get better coverage in one part of the house but lose it in another. If you have a wireless router/access point with external antennas, you can move the antennas to try to "aim" the RF coverage where it's most optimal for your situation. |
07-16-2024, 09:36 AM | #20 |
Rep 1,261
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
I'm not sure what everyone else is talking about, but I have great luck with boosters. I use them in our plant to extend the range of our WIFI for our display screens. When I reboot them everything goes down, but when they are up everything works great.
I used on at my farm too so I can push the signal out enough to get it in my detached shed as well. Everything I use them for is cameras, display screens, etc so I am not gaming on them, but they work great for my needs.
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
chassis7971.00 |
07-16-2024, 10:11 AM | #21 |
The Seeker
15308
Rep 3,804
This whole conversation is so over my head.
I get 600MB wired, but on the other side of the house a video won't even play consistently, and in the basement on that side I only get 30MB. It's enough to make you pull your hair out. |
07-16-2024, 10:33 AM | #22 | |||
Rep 1,002
I was the first home Roadrunner cable modem customer in our region, and know this for a fact because I was involved with training their installers. I was also the first customer in the region to supply my own cable modem, because the ones they provided at the time would not link on the ethernet side to my commercial-grade router without an old-school 10Mbps ethernet hub (not a switch) between them.....
