      07-17-2024, 12:46 AM   #1
x3sm
x3sm's Avatar
308
Drives: M3 E93 Porsche
Removing smoker smell
Hey guys,
Needing some advice here, so I ended up buying a Panamera for a really good deal, the downside was that it was a smoker’s car. When I removed the cabin filter it was black!! Immediately like 40% of the smell was gone with the new filter and a few days of driving. I then got the interior detailed, but I did not like the job done by local auto spa. I also did the ozone machine method and right now I’d say 25% of smell is still there and on top of that the ozone smell is also there now. Cigarette smell is very specific and even with 25% you can still pick up on it especially when just getting in.
What to do next? I will air it out and ozone smell should desipate, are there leather cleaning products that have some kind of enzyme that will eat the smoke particles in leather? Should I wipe it all down with vinegar? Maybe new car leather conditioner?
Please post your suggestions please!
M3 E93
PORSCHE MACAN S: SOLD
BMW X3 F25: SOLD
AUDI S4: SOLD
BMW E92 335: SOLD
M4Tejas1043.50
      07-17-2024, 06:36 AM   #2
cbpip
cbpip's Avatar
256
Drives: BMW Z4C 3.0si 3 pedal
2007 BMW E86C  [10.00]
Need to clean the ac evaporator to get rid of the contamination stuck to it along with same in the vent tubes. Have used this on a car that was used by a cigar smoker . Key is doing it twice to let it dissolve the trapped stuck on nicotine. If you don't clean the evaporator the smell will not go away. Make sure to remove the cabin air filter before using the FrigiClean and let the foam come up and out the vents.
After FrigiClean use the FrigiFresh through the fresh air intake. Have also used Lysol fresh air spray (linen scent) in same manner through fresh air intake occasionally.
Clean interior with
https://www.amazon.com/gp/aw/d/B0002...b_b_asin_title
Ozone machines do very little to remove the odors long term. They also cause degeneration of rubber in the interiors.
https://www.amazon.com/Frigi-Clean-E.../dp/B09WM4YXKH
https://www.bgprod.com/catalog/clima...g-frigi-clean/
      07-17-2024, 08:39 AM   #3
Car-Addicted
Car-Addicted's Avatar
Drives: 2020 BMW M4 CS
2020 BMW M4 CS  [9.91]
IMO cbpip is dead on.
I owned a dealership in the 70 and 80's when smoking was way too common. The AC system is top priority for clean up. Carpets are easy but to get everything out you may have to pull the seats. We also attacked the head liners, most are foam backed with open cell foam. Hard to clean even when pulled down. I do remember replacing one or two to get the smell out of the foam. Back then wholesale auction houses required you to denote any vehicle that has been smoked in and if you didn't the sale could be contested. (learned that the hard way). Good luck.
      07-17-2024, 01:14 PM   #4
Josh-PA
Drives: 991.2, n55 e88, B58 G05
I have had good luck with Ozium. I focused mostly on the carpets (you should shampoo and wet/dry vac them first) and the air vents. I fired a bunch of ozium behind and onto the cabin air filter and into the cabin vents. You can spray the ozium on the headliner also after a gentle vacuum.
https://www.amazon.com/sspa/click?ie...hdGY%26psc%3D1.
All of the leather and hard materials should be cleaned with good leather cleaner and a little warm water. Again, I'd lather these up and then use the wet dry vac to suck up/out as much dirt and left over ash as possible then use a good leather conditioner on it. The cockpit premium should work nicely on the hard parts.
      07-17-2024, 03:03 PM   #5
erickonphoenix
erickonphoenix's Avatar
2061
Drives: 2014 Gray 328xi Touring
or you could start smoking?
Nettles824.00
DrVenture1293.50
ekaz85.00
BSfmAZ348.50
munizfire128.00
      07-18-2024, 11:18 AM   #6
x3sm
x3sm's Avatar
308
Clean interior with
https://www.amazon.com/gp/aw/d/B0002Z2MZ4?psc=1&ref=ppx_pop_mob_b_asin_title
https://www.amazon.com/Frigi-Clean-Evaporator-Frigi-Fresh-Evaporating-Cleaning/dp/B09WM4YXKH
Awesome!! Appreciate the suggestion, never thought about the ac evap, that explains why when AC/fan is on it gets worse! I ordered what you suggested, again thank you very much!
Good point, I might replace the headliner if it comes down to it or get it re-wrapped in alcantara. The interesting part is that headliner and pillars had no sign of smoke on them, they are tan color so usually you can see where smoke accumulated, but these were pretty clean, aside from some aging.
https://www.amazon.com/sspa/click?ie=UTF8&spc=MTo2NzU3ODg5MzcwOTQxNjA6MTcyMTIz NjM2MDpzcF9hdGY6MjAwMDY2NDIwODQ4MTcxOjowOjo&url=%2 FOzium-Oz-Sanitizer-Eliminator-Original%2Fdp%2FB086T517RH%2Fref%3Dsr_1_1_sspa%3Fd ib%3DeyJ2IjoiMSJ9.1L5H0fOcXa7tE6toqWAh0Z0vKp6Q2xdb qgfoMjOOwfBDpbN_OWrUF5r067L1m8w_i-Cll61JCxmgXM-ItFPRbOq6F7B6ofPozk6r63kO5I2H6H8xXNKCYivo-NQQA2dBLEW54IQLEzJaxauhRvSroEMhB3dkhQ8knM-49gq4btitQ5gkHN6gvo56N-ITtcWTI94YhtAr5pcY7LDiE1F9DMMKsQOEMmYoRPsLqZtb6mLK bSUn-1sU7oJ42Z5Re-DLTqAGRhndcb-JaWNxWqWzeGPUjx6kf—2NhIET1thpKI.YPMVpK8Bi_f7JgR7Tu RqWr4tTS56hPBuyzvQbmz9x-s%26dib_tag%3Dse%26keywords%3Dozium%26qid%3D172123 6360%26sr%3D8-1-spons%26sp_csd%3Dd2lkZ2V0TmFtZT1zcF9hdGY%26psc%3D1.
Thanks for the tip! Did you spray it from outside the car under the hood is where the fresh air intake is for cabin air?
I might also try Zaino-10, I believe it has a strong leather smell.
Hahaha, I actually lol’d
M3 E93
BMW X3 F25: SOLD
AUDI S4: SOLD
BMW E92 335: SOLD
      07-18-2024, 11:22 AM   #7
Car-Addicted
Good luck. I'm particularly sensitive to cigarette smell. If you can drop back in with your results as this could help a lot of folks.
      07-18-2024, 11:43 AM   #8
omgzirra_exe
omgzirra_exe's Avatar
Drives: 4.4L M3, IS300
Deep clean the interior again because I'm 100% positive your local detailer did not use a carpet extractor and a steamer.
Step 1: Clean the air vents
Thoroughly scrub the vents and use an air blower to blow out all the cigarette ashes.
Step 2: Work the leather
Since you have leather seats, deep clean them as follows:
- Use your favorite leather cleaner (I use the Colourlock Leather Care Kit). Spray the seats, let it sit for a bit, use a soft brush to work the grime off, and then wipe it down.
- Use a steam cleaner and wrap it with a microfiber towel. If you do not use a microfiber towel around the head of the steamer, it will stain your seats.
Step 3: Clean the carpet
- Remove the floormats, deep clean, scrub, and vacuum them. I suggest using a carpet extractor, which can be rented for $60 at Lowe's or Home Depot with the attachment.
- Spray the carpet liner, scrub, and extract it.
Step 4: wipe it all down.
- Use the steam cleaner to remove ALL the grime on the interior pieces, it is safe to use it directly with no microfiber towel. wipe down with a microfiber towel as you go. (if you have leather on your interior panels, please cover the steamer with a microfiber towel)
- Remove microfiber towel if applicable to get between all the crevice's.
- Finish using your favorite interior detailer (I use Griot's Interior Spray).
Optional: I do recommend this
Run this product in your car with the AC on high circulation mode after deep cleaning: https://biobombs.com/collections/all...47822537949487.
Then, wipe down your entire interior again with an interior detailer.
Use the Colourlock Leather Care Kit to clean and rejuvenate your leather.
This will take you a whole weekend. Have fun!
Build: ZillaSpec M3 N1 Build
M3Post Track General Discussion: Discord
#fakeGTS
      07-18-2024, 11:46 AM   #9
dscabra
dscabra's Avatar
5308
Drives: GMC Denali
Once you've cleaned everything, try using one of these:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
      07-18-2024, 11:52 AM   #10
cbpip
cbpip's Avatar
256
Make sure you follow directions on FrigiClean, Must block off / plug the evaporator drain under the car so the product doesn't just drain out. Let it sit for 30- 40 min before unplugging it.
Stay away from the Ozone machines. The reasons you don't want to use it in you car. Not immediately seen but takes a toll on plastics and rubber. It also leaves a coating on surfaces that you'll need to clean.
https://www.satra.com/spotlight/article.php?id=390
      07-18-2024, 11:54 AM   #11
FrankMstein
FrankMstein's Avatar
Drives: F80 M3, R56 Camden, F56
2x - Once you do all this, use this:https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2015 Sakhir/Sonoma (first one totalled) 2nd one MHD and BM3, Eventuri, Mosselman, NICECNC, MAD FAT BOY DP, "Valvetronic Designs" single mid, PAGID RSC1, Hotchkis/GTMore, Vorschlag, Bilstein B16/10.
Soon Powerflex diff brace, Akropovic axle back for sale.
      07-18-2024, 02:10 PM   #12
John in VA
Drives: 2015 228i M Sport
Your link doesn't work - what product are you referring to? Thanks!
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining
      07-18-2024, 03:06 PM   #13
///M Power-Belgium
///M Power-Belgium's Avatar
Belgium
70624
Drives: ///M3-E92-DCT Silverstone II
Soak some vinegar in a small pillow and lay it down in the car on the floor .
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod.
Wolf 3352562.00
      07-18-2024, 03:10 PM   #14
FrankMstein
LOL the one above mine.
      07-18-2024, 03:51 PM   #15
cbpip
cbpip's Avatar
256
Reason for not using an Ozone machine. Degradation of rubber and plastics. Especially on older vehicles where the plastics and rubber have age on them already.
      07-18-2024, 03:59 PM   #16
Josh-PA
One last suggestion: anytime it's parked dry (inside or out) leave the windows and roof open. Getting air circulation helps quite a lot to the point you may want to set up a fan in the garage to blow air through it.
      07-18-2024, 05:04 PM   #17
Limegrntaln
Limegrntaln's Avatar
Drives: 2022 DG/BLk xDrive M4C Wk 34
Light it on fire.
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou
      07-19-2024, 09:37 AM   #18
Wolf 335
Wolf 335's Avatar
Drives: 2007 E92 335i
Key areas of concern are:
- Headliner and pillars (foam underneath headliner)
- Carpet (foam underneath)
- Ventilation including the vent passages, evaporator, blower fan.
- Door panels (behind them)
Headliner foam and carpet foam soak up the nicotine/tar and thats where the issues lies.
All other hard surfaces such as vents passages, evaporator , seats and dash can be cleaned easily and are not necessarily a problem once surface is cleaned.
If your budget allows, best course of action would be to replace the whole headliner including the pillars, with new or used non smoker liner.
When it comes to carpet keep in mind nicotine and tar are embedded not only on top of the carpet surface but rather in the foam underneath it.
To do this right you're going to have to remove the seats completely, front and rear, and have someone with a professional strength extractor try and tackle this.
This is not a one time spray and extract. It needs to be repeated a few times on the carpets, to allow the cleaning agent to really penetrate into the foam.
This is why you can't do this on the headliner as it will begin to sag as glue/foam is saturated.
Another thing that i didn't see anyone mention (or maybe i missed it) is door panels.
You must remove the door panels and clean behind them. I discussed this way back with a professional detailer and he mentioned that a lot of smell comes from there as well.
Door cards must be cleaned from the back side and so does the vapor barrier and metal surface of the door.
Definitely not a one day job, but over time you will be able to eliminate 95% of the smell. Good luck and keep up posted of the progress.
      07-19-2024, 02:06 PM   #19
FrankMstein
Remembers Seinfeld's 5 series that smelled?
https://www.google.com/imgres?imgurl...em=abme%2Ctrie
      07-19-2024, 02:41 PM   #20
x3sm
x3sm's Avatar
308
I have to say that it’s getting better and better. Especially the fact that it’s sitting in the sun, it’s not that bad anymore. My wife who is pregnant can smell it from a mile away though.. lol.
Run this product in your car with the AC on high circulation mode after deep cleaning: https://biobombs.com/collections/all/products/starter-kit?variant=47822537949487.
Then, wipe down your entire [...]
Thank you, this is very helpful. With vents cleaning, what’s the best way to do that? Romove them? A member here suggested the FrigiClean, which has been ordered.
https://www.amazon.com/gp/product/B00JAP7388/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I did use it, good results!
I heard about the issues, a local detailer with 14 years of experience who does Barrett-Jackson show said you can do it as last resort. I did it in small increments and let it air out. I did wipe it down as well.
Question is, will vinegar smell come out?
Yes, I do this all the time and I think this probably helped the most.
Definitely not a one day job, but over time [...]
I ordered a strong carpet cleaner, but I’m not sure it will be that powerful. Many times I smelled the carpets, there was no smell at all, literally my nose to the floor. I’m planning to remove all the seats and clean underneath, you never knew there might be cig butt somewhere still.
lol, hopefully my smell will be gone.
I’ll update everyone after carpet cleaner shows up and I do the FrigiClean!
M3 E93
BMW X3 F25: SOLD
AUDI S4: SOLD
BMW E92 335: SOLD
      07-19-2024, 11:07 PM   #21
2heeldrive
2heeldrive's Avatar
89
Drives: 2019 X5 4.0, 2022 330ix
The only sure way is to replace everything that absorbs odors. Carpet and pad, headliner, etc.
Cigarette smell is very hard to remove.
Or, you could just take up smoking...
      07-21-2024, 10:29 PM   #22
x3sm
x3sm's Avatar
308
Clean interior with
https://www.bgprod.com/catalog/climate-control/bg-frigi-clean/
I’m having a heard time figuring out how to spray in the right place. YouTube videos say you need to drill into evap core. Would it work the same way if I sprayed it into the vents and or through where the air filter sits?
M3 E93
BMW X3 F25: SOLD
AUDI S4: SOLD
BMW E92 335: SOLD
