      07-19-2024, 01:41 PM   #1
RemoWilliams84
Drives: 2024 ZB M2
PSA: Clutch pedal releases parking brake
I don't know why they would design the car this way, but if the engine is running and you depress the clutch pedal, it will release the parking brake. I learned this the hard way. I was sitting in my car in a parking lot. I was about to leave so I depressed the clutch, but I remembered I needed to get my umbrella out of the trunk. Got out of the car and it started rolling. Luckily I stopped it before it hit anything.
At first I thought I must have done it, but I tested it out and sure enough, pressing the clutch pedal releases the parking brake.
Edit to point out this only happens if your for is off the brake.
      07-19-2024, 02:16 PM   #2
Msondeck
Msondeck's Avatar
Drives: f85 x5m
2016 X5M  [0.00]
2024 M2  [10.00]
Interesting.... only thing i can think of is for extra time on hill assist
      07-19-2024, 10:26 PM   #3
youloze
Drives: 2020 BMW 330i
The only time my parking brake is released automatically is when I clutch in and give it gas. Interesting that yours is releasing when only clutching in.
      07-19-2024, 10:47 PM   #4
Resoelg
Resoelg's Avatar
Drives: 2024 M2 ZV-Blue
I have to see if I can replicate this. Not had that experience.
      07-20-2024, 02:13 PM   #5
Celestion
Celestion's Avatar
Drives: '24 M2 6MT Toronto Red
If true, this would be a dangerous design. Hope this isn’t the case
      07-20-2024, 02:57 PM   #6
RemoWilliams84
Drives: 2024 ZB M2
This.
Maybe you posted this in haste OP.
Try to replicate it again. Clutch shouldn’t release the parking brake, whether the car is on or off. Maybe you did something else (like forgetting to apply the brake, or forgetting you disengaged it, or maybe you pressed the gas)
I sat there and did it about 5 times in a row to make sure. Will make a video when I can.
Car was running btw for anyone trying to replicate.
      07-20-2024, 03:29 PM   #7
RemoWilliams84
Drives: 2024 ZB M2
      07-20-2024, 03:55 PM   #8
youloze
Really strange. That is definitely not supposed to happen. I'd take it in to the dealer to have it checked.
      07-20-2024, 05:04 PM   #9
RemoWilliams84
Drives: 2024 ZB M2
This really has me perplexed. Just another data point, doesn't happen with the door open
      07-20-2024, 05:04 PM   #10
Covfefe
Drives: '14 M235i 6mt
Scary! Sad that they didn't bother giving the M models a physical handbrake.
      07-20-2024, 05:37 PM   #11
fangelov
Mine does not do that. Might be a glitch with yours.
      07-20-2024, 06:27 PM   #12
xps
xps's Avatar
Drives: bmw M2
Mine doesn't do it. However I can release the park brake by pressing the switch when the clutch is pressed.
So, checkout if your PB switch is faulty? Stuck close? There should be fault logged if there is such failure. Another possible reason could be that your gear position indicator is faulty? Does it show N on the screen when the gear lever is neutral?
Another thing could be your changed some settings with Bimmercode?
https://streamable.com/a63rsh
      07-20-2024, 07:00 PM   #13
RemoWilliams84
Drives: 2024 ZB M2
I'll reset my bimmer code settings. I wouldn't think you'd be able to change something like that though. Gear selector seems fine.
      07-21-2024, 12:12 AM   #14
aerobod
Car Geek
aerobod's Avatar
Couldn’t replicate on my car, no auto disengagement of the parking brake until the clutch is on the way up with a gear engaged and throttle is applied.
Perhaps if the clutch isn’t pressed all the way down before release, a faulty clutch position sensor, faulty gear position sensor or less than full clutch motion due to a clutch stop, may modify the behaviour?
      07-23-2024, 08:57 AM   #15
MASHCT
MASHCT's Avatar
Drives: 2024 BMW M2 BSM
Can't replicate this on my car at all. Depressing the clutch should not release the parking brake. Pressing the gas will.
2024 M2 | BSM | 6SPD | Port-Installed M Perf HAS | MAD Axle-back Exhaust | MAD CAI with blue filters | Dinan Midpipe | Richland Forged RF-GT3R Wheels Brushed Competition Gold & machined face | AudioControl D-6.1200 Amp & DSP | CDT Audio ES Gold Fronts & Rear | Morel BMW-Specific Subwoofers | Lots of neat interior upgrades!
      07-23-2024, 11:32 AM   #16
KC87ZB
KC87ZB's Avatar
447
Drives: 2023 M2
2023 BMW M2  [10.00]
Similarly, I cannot duplicate this by just pressing in the clutch.
2023 M2
2014 Triumph Trophy
      07-23-2024, 12:08 PM   #17
DrewNewM2
Drives: Brooklyn Grey G87 Manual
Could not duplicate either
      07-23-2024, 02:12 PM   #18
JMcLellan
JMcLellan's Avatar
Drives: 2024 M2
Mine stays engaged until throttle is applied.
2024 M2
2019 M240i- Sold
      07-23-2024, 02:19 PM   #19
RemoWilliams84
Drives: 2024 ZB M2
Thanks for all of the responses guys. I reset my bimmercode settings and everything was the same.
I'm going to take this thread with me when I go in to have my 10,000 mile service done in a few weeks.
      07-23-2024, 04:13 PM   #20
RemoWilliams84
Drives: 2024 ZB M2
So no different software version?
I forgot to check that. I know I downloaded the latest a month or two ago.
      07-23-2024, 04:18 PM   #21
Squidget
Drives: 2023 G87, 2011 E90 335i
I also can not reproduce this.
      07-24-2024, 03:44 PM   #22
KC87ZB
KC87ZB's Avatar
447
Drives: 2023 M2
2023 BMW M2  [10.00]
Makes me think there is something up with the throttle position sensor.
The right answer is let the dealer fool with it as it is definitely something screwy that will require a new part. Be prepared to wait for it though.
Please let us know what they have to say.
2023 M2
2014 Triumph Trophy
