      07-25-2024, 02:16 PM   #1
banem2
Drives: M2
Bad Fuel Injectors/Fuel in Oil
So after 3 tries I finally got my dealership to agree to check my fuel injectors and the injector at cylinder 1 was indeed bad. I was having rough starts and black smoke coming from the tailpipe for months, but the car wasn’t throwing any codes so BMW wouldn’t approve any repairs.
The mechanic mentioned during the two previous visits that my oil levels were high. I said I haven’t touched them. I now know it’s because the injectors were leaking fuel into the cylinder and down into the engine oil. This was most likely happening for roughly 3k miles since BMW wouldn’t work on the car without any codes.
I’m just wondering if I should be throwing a fit here or if this isn’t a big deal? They are definitely trying to minimize it. Thoughts?
      07-25-2024, 02:21 PM   #2
BroDoze
Drives: 2025 M2 LCI
Well good on you for pushing them and not backing down. Does the car drive any different? Were you getting stuttering or anything while driving?
///M
      07-25-2024, 02:47 PM   #3
Tag
this is the way
Tag's Avatar
20015
Drives: N-1 starfighter
Fuel dilution of oil is bad. Depending on how much fuel was in the oil it could lead to premature wear of components that are lubricated by engine oil.
Recommend you talk to a manager and work with them to do the following.
  • Get an oil sample and have it sent to an independent lab for testing.
  • Inspect oil filter for any metal wear.
  • Request a compression test on all cylinders.
banem28.00
///M TOWN32295.50
      07-25-2024, 03:02 PM   #4
banem2
Drives: M2
You think 3k miles was enough to cause these kind of issues. They told me the cylinders look “brand new”
Thanks for the advice!
      07-25-2024, 03:15 PM   #5
banem2
Drives: M2
Yeah I was definitely annoyed by how long of a process this was. BMW actually wrote a note stating that stumbling starts are normal in the s58 and not something to be concerned with. 🙄
I’m not sure if the car drives any differently because this has been happening since the car was pretty much new. I only know the car one way.
      07-25-2024, 03:43 PM   #6
Tag
this is the way
Tag's Avatar
20015
Only way to know for sure is to do the tests. 'Looking brand new' means nothing.
///M TOWN32295.50
      07-25-2024, 03:52 PM   #7
banem2
Drives: M2
No metal in the oil filter, but BMW won’t approve a compression test on the vehicle. 😑
      07-25-2024, 03:58 PM   #8
Tag
this is the way
Tag's Avatar
20015
No metal in the oil filter, but BMW won’t approve a compression test on the vehicle. ��
Did they show you the filter or are you just taking their word? If they haven't drained the oil yet get yourself a sample and send it in for analysis yourself.
Take it up with the manager and if they're not helpful escalate it with BWM NA.
///M TOWN32295.50
      07-26-2024, 10:46 PM   #9
DutchBoysRacing
DutchBoysRacing's Avatar
Drives: 2024 M2, 2013 Mini GP
100% this. Even if the test come back "good", this is still indeed "not good. How much extra wear was done or will this become an issue down the road when you don't have a warranty?
@DutchBoysRacing
///M TOWN32295.50
      07-27-2024, 01:54 AM   #10
///M TOWN
///M TOWN's Avatar
Drives: M GmbH
2018 M2  [9.23]
You’re not wrong
Just reading this thread is enough to make me concerned for the OP
banem28.00
      07-27-2024, 12:02 PM   #11
yash27
Drives: '25 M2 Voodoo Blue (on order)
How long did it take for this to start happening? Was it after a service?
      07-27-2024, 01:47 PM   #12
Dave07997S
Dave07997S's Avatar
1266
Drives: 2024 BMW M2 Toronto Red 6MT
They better check for cylinder scoring as well. The fuel strips the oil off the cylinder walls
      07-28-2024, 07:48 PM   #13
banem2
Drives: M2
Originally Posted by ///M TOWN View Post
You’re not wrong
Yeah and this is happening to a fair amount of people. I know of multiple owners who have had stumbling start/long crabm issues that their dealerships “can’t figure out.” Seems fairly common in M3/M4 as well.
      07-28-2024, 07:49 PM   #14
banem2
Drives: M2
They scoped the cylinder. Said it looked brand new, so that’s a plus.
Dave07997S1266.00
      07-31-2024, 04:54 PM   #15
banem2
Drives: M2
It started happening a couple months after owning the car. So like 500-1000 miles in.
