BMW M2 Forums 2023+ (G87) iDrive, Nav, Stereo, Bluetooth, Electronics
      07-27-2024, 06:47 AM   #1
comp
Drives: Lime bike
CarPlay draining battery/Crap wireless charging
I’m finding that using Waze or Google maps is draining my battery quite fast, the stupid wireless charger makes the phone so hot that it needs to cool down killing the apps running at the time, even then it doesn’t charge the phone well anyway, a few % per hour.
I have some long drives coming up and I’m worried the phone battery will be depleted before completing the drive. Is charging via the usb cable better? Or any other solution to the absolute shit house wireless charging?
      07-27-2024, 07:46 AM   #2
dvchemmy
Drives: 2024 M2
I plug a USB charge plate into the console and put the charger in this
https://www.amazon.com/dp/B0CN9GJKMM...t_details&th=1
      07-27-2024, 09:25 AM   #3
BroDoze
Drives: 2025 M2 LCI
This is why you do not option the wireless charger.
///M
      07-27-2024, 11:25 AM   #4
NewToM
NewToM's Avatar
Drives: M2 G87 Brooklyn Grey
2024 BMW M2 G87  [9.47]
Agreed, $200 down the drain.
      07-27-2024, 06:52 PM   #5
comp
Drives: Lime bike
They are pre configured on Australian cars, not optional. Either way that’s not the point, CarPlay drains the battery, so all of you without the wireless chargers what are you doing to charge your phones?
      07-27-2024, 11:38 PM   #6
aerobod
Car Geek
aerobod's Avatar
Just plug in a mini-USB to Lightning cable between the USB port in the armrest and the iPhone. Took my iPhone from 13% to 44% charge in about 20mins of driving today.
      07-28-2024, 07:09 AM   #7
comp
Drives: Lime bike
Thank you!
aerobod4257.50
      07-28-2024, 04:19 PM   #8
Carefree
Carefree's Avatar
Drives: M240i, M2
I believe it’s USB-C not mini.
      07-29-2024, 06:57 PM   #9
JABCAT
Professor
JABCAT's Avatar
4268
Your car should have 2 usb ports. Simply plug the phone in as already mentioned. I never use the wireless tray.
      08-27-2024, 11:54 PM   #10
LeGoAuToPiLoT
Drives: 2024 BMW M2
thx for the suggestion! I use the armrest USB-C to my iPhone USB-C.....and it charges SUPER fast.
I too optioned the wireless charging. Oops
      08-29-2024, 12:35 PM   #11
JABCAT
Professor
JABCAT's Avatar
4268
Interestingly, my phone overheated using the usb-c charger in the center console last week on my trip from Dallas to Austin. It's never done that before, and I've made that trip nearly every weekend for the last 8 months.
      09-12-2024, 01:16 PM   #12
musicmd
musicmd's Avatar
Drives: 2024 M2
I have had the same issue with my car. Every time I use the wireless charging tray for a period of time, my phone sends an alert that it is getting too hot. (and it is really warm to the touch when I take it out of the tray.)
I used to think it was that my screen was staying on, but that isn't the case.
Once I started using a cable, the overheating problems went away. I have to believe there is a heat issue with the tray itself, as I use charging trays at home and work with no heat issues at all.
      09-12-2024, 11:39 PM   #13
JABCAT
Professor
JABCAT's Avatar
4268
Mine overheated using the cable, not the tray. This was the first time it did that in 8 months of making the same trip. I don't use the charging tray.
      09-13-2024, 12:49 PM   #14
musicmd
musicmd's Avatar
Drives: 2024 M2
That's really strange. I'll have to keep an eye out, to see if that happens to me.
      09-13-2024, 11:20 PM   #15
JABCAT
Professor
JABCAT's Avatar
4268
My wife's phone overheated today in her X3MC while plugged in (no wireless tray in her's). Also first time that's happened. Maybe it's something with the iphones (both iphone 15s)? :
      10-11-2024, 04:51 AM   #16
Liosandro
Hi all!
Small suggestion: use you armrest charger with any connection you need: magsafe, QI2 or plug directly to the phone and put it face down in the armrest.
Then use the rear seat's air outlet, lower the temperature and close the flaps.
You will find that the plastic on the bottom of the armrest space is at least fresher than any other part of your car.
The air going to the rear seats flows under the armrest...
Ciao
Ale
      10-21-2024, 01:57 PM   #17
ajchoi
Drives: 2024 ZB M2 6MT
15's are notoriously bad at heat dissipation. 16's seem to be much better so far.
