08-10-2024, 11:53 PM | #1 |
Rep 719
Front brake discs look scored
Hey guys,
I was washing my car today and when I was cleaning the front wheels, I noticed that the front brake discs on both sides looked scored and I don’t really remember them looking like that before. I’ve included some pics which compare the front brake discs with the rear brake discs (first two are front, last is rear. Car was just washed so rear has rusty rotors). Is this normal? Car is at 5600 miles.
Current: 2024 G87 M2 (ZF8)
Past: 2022 330i RWD 2020 M2 Competition DCT |
08-11-2024, 06:51 PM | #4 |
Rep 719
I was referring to the smudging on the front discs, those look normal? I’m not concerned about the rears
08-11-2024, 07:02 PM | #5 |
Rep 1,502
08-27-2024, 10:32 PM | #6 |
Supreme Allied Commander
4094
Rep 55,854
Drives: F80 M3
If you exceed the MOT on your pads, they will smear the pad material over the surface of your brake discs. Let us know if it clears up after a few drives. If not, you will have to address it.
08-28-2024, 06:49 AM | #7 | |
Rep 286
Or did you use MOT to mean “Minimum Operating Thickness”?
Car History (oldest to newest): Accord, 318i, 330i, Prius, Prius, M2
08-28-2024, 11:33 AM | #8 | |
Car Geek
4258
Rep 3,906
TallGibbs394.50 |
10-17-2024, 11:08 PM | #9 |
Rep 719
Haven't really had any issues 2000 miles later, and I do have the maintenance package that covers brake pads and rotors, so not too concerned. Was just wondering if it looks like anything out of the ordinary. Thanks!
10-19-2024, 08:03 AM | #11 | |
Christmas Poo
1629
Rep 1,409
Drive the Manual - 2024 G87 - Mr. Hankey's M2 Build Thread
TallGibbs394.50 |
10-19-2024, 09:21 PM | #12 | |
Rep 719
Past: 2022 330i RWD 2020 M2 Competition DCT Last edited by turnsignalslol; 10-20-2024 at 04:38 AM.. |
10-21-2024, 01:00 PM | #13 | |
Christmas Poo
1629
Rep 1,409
First photo is of my rotor - your streak is in the same location of mine. Here is the pad, some of the material has delaminated from it, so it doesn't contact the rotor in that area and will make a groove....eventually the pad will wear down to that level and contact again, but you will end up with a grooved rotor that will need replacing with your next set of pads. If your pad is delaminated you can replace it now and still save the rotor. BMW claims that washing the wheels with certain soaps can cause the pads to stick with the parking brake and then some of the pad material pulls off the pad and stays on the rotor. I'd just keep an eye on it...if the rear streak goes away, you're fine. if it doesn't then have them take a look.
TallGibbs394.50 turnsignalslol374.00 |
10-21-2024, 10:31 PM | #14 | |
Rep 719
Mr. Hankey1629.00 |
