BMW M2 Forums 2023+ (G87) Engine, Exhaust, Drivetrain, Tuning Modifications
      08-14-2024, 03:30 PM   #1
ZPD
ZPD's Avatar
666
Drives: 2022 M850i GC, 2023 G87
CS CSL Axle swap
I am posting this to help the next guy.
Several weeks ago I was at Circuit of the Americas. It was around 100 degrees and I am sure track temps were even hotter. I pushed hard for several laps on Day 2 of a 2-day event and got black-flagged. The pit worker told me that corner workers observed I had smoke coming out when I was hard braking before turn 11 and accelerating out of a few of the corners. I ruled out brake dust and headed home fearing that there was something catastrophic even though there were no errors on the dash or codes.
When I got home and put my car on the lift I saw that the driver's side inner CV boot was ripped and grease was all over the exhaust. There was some oil splashed around out of the diff vent as well. After some googling I found that you can't buy just the CV boot and you have to buy an entire axle. I also stumbled across a note that said that if a customer has a boot failure due to hard driving then replace the axle shaft with an axle meant for the M3/4 CS/CSL because the boot can withstand a higher temperature.
The dealership wouldn't warranty the repair since I modified my suspension but Bimmerworld gave me a good deal on a pair of CSL Axles. The swap wasn't very hard and could probably be done in 2 hours if you have aftermarket exhaust.
For anyone encountering the same problem down the road the part numbers for the axles are:
Left: 33207887199
Right: 33207887200
And here is a video I made of doing the swap:
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Goodyear 3R, SPL links, Adro wing, IRL exhaust, Racechip, Verus Splitter; IG:g87_43
Appreciate 12
apez819.00
myaghi99.00
Reesnat160.50
71dsp99.00
azv31115.00
clutchdj2130.00
GenXG87217.50
      08-15-2024, 08:49 AM   #2
Reesnat
India
161
Drives: BMW G87 M2
Thank you for sharing your experience. Sorry for your troubles but hopefully you have a stronger and more capable car now!
      08-15-2024, 09:37 AM   #3
TallGibbs
Drives: 2024 M2 (coming Sep '24)
Just to confirm, which car model and year did you have to do this swap on?
Car History (oldest to newest): Accord, 318i, 330i, Prius, Prius, M2
      08-15-2024, 11:20 AM   #4
ZPD
ZPD's Avatar
666
It is on my 2023 G87.
The CS/ CSL axles fit G87, G80, and G82
2022 M850i
      08-15-2024, 03:41 PM   #5
TallGibbs
Ok good to know. First time I had read about these parts being shared across platforms so good to know for future track stressing.
      08-15-2024, 07:41 PM   #6
LeggoRacing
LeggoRacing's Avatar
261
Drives: M2
Thanks for sharing and learning for the community. Looks like a fun swap
azv31115.00
ZPD665.50
      08-15-2024, 08:53 PM   #7
ZPD
ZPD's Avatar
666
I feel like I have been the guinea pig for far too many things
2022 M850i
      08-16-2024, 10:50 AM   #8
gnx
Όλα ρόδες
gnx's Avatar
941
This is a known issue with the g8X platform. It was mentioned by Mischa Charoudin in a video as one of the reasons why the APEX G80 M3 Nurburgring taxi car was sold.
ZPD665.50
      08-16-2024, 11:59 PM   #9
Ojala
Drives: BMW m2
2024 BMW M2  [0.00]
Differential heat management is an issue that is fairly common with other platforms. Lots of cars need heat exchangers for the diff which would explain oil from the diff vent. I'm curious about the torn boot. Is the cause the exhaust, the diff, or something else?
      08-17-2024, 12:23 AM   #10
clutchdj
Drives: a few cars
sheesh that is not supposed to happen. At thunderbolt last month it felt like my left hub bearing was about to take a dump right before turn 9 but now that I think about it, maybe the left axle bearing was stressing out. heat index was over 100F. I had to change out hub bearings at 4k on the f87 but axles should not fail. thanks for sharing OP.
      08-18-2024, 10:02 PM   #11
DutchBoysRacing
DutchBoysRacing's Avatar
Drives: 2024 M2, 2013 Mini GP
Left: 33207887199
Right: 33207887200
Interesting, keep us updated on this. I track a lot (monthly) in SoCal and usually keep it mellow in the summer but if this is a common issue I'd like to address it ahead of time.
@DutchBoysRacing
      08-21-2024, 08:24 PM   #12
GenXG87
GenXG87's Avatar
218
Drives: 2023 M2 & 2018 M2
2023 BMW M2  [8.80]
2018 BMW M2  [9.80]
Dang. I was just checking the prices on those. So crazy no one offers a boot replacement kit.
Thanks for sharing the video.
2023 G87 ///M2 6MT - Ohlins R&T, Vorshlag Camber Plates, Fall-Line Rear Toe Arms, APEX VS-5RS, Conti Extreme Contact Force, Pagid RSL29, BM3 Stg2, MAD CAI, IRL single mid-pipe
2018 F87 ///M2 DCT - MPE, BM3 stg1, MAD Intake, xHP stg2, M4GTS Diff/Steering, Euro MDM, Ferodo 3.12, APEX VS-5RS, Potenza RE-71RS, Cobra Nogaro next mods: Ohlins R&T, Vorshlag Camber Plates, SPL parts
IG: Follow ME: genXg87
      08-21-2024, 10:21 PM   #13
ZPD
ZPD's Avatar
666
I had a track day this weekend at Eagles Canyon Raceway and it was over 105 degrees. It's not as abusive COTA but still pretty harsh conditions. I checked my axles tonight and there is no sign of wear on the boots. So that is good news.
2022 M850i
BroDoze2157.00
      08-31-2024, 06:47 PM   #14
ZPD
ZPD's Avatar
666
So I decided to take apart the axle today. It came apart really easily. I might try to find a neoprene or viton boot that fits to satisfy my curiosity.
2022 M850i
