08-21-2024, 07:39 AM | #1 |
Rep 70
Exhaust tone changes when engaging clutch??
When idle, whether M Exhaust Sound is on or off, I notice the tone of the exhaust changes ever so slightly when I engage the clutch: the rumble gets slightly deeper (it sounds better imo).
I can't tell if this is the ASD or actually the engine/exhaust changing. Of course idle would change slightly when the clutch is engaged vs not, but this sounds different, probably ASD? Does anyone else notice this? It is barely perceptible but super weird. |
08-21-2024, 09:44 AM | #5 |
Rep 340
The exhaust valves, while at a stop, only open when the clutch pedal is depressed.
-Nicholas
2024 BMW M2 2022 BMW m240i x-drive (sold) 2018 BMW X5 35d x-drive 2015 VW Golf 1.8t 5-speed (sold) |
08-21-2024, 10:26 AM | #7 |
Rep 3,503
08-21-2024, 02:52 PM | #9 |
Rep 4,215
Idle tone changes as fuel is added a tad to help with clutch engagement. It's not the exhaust valve. You can see your fuel consumption go up a bit when you push the clutch in.
08-21-2024, 07:38 PM | #11 |
1207
Rep 1,190
My Dahler controller doesn’t override this. Clutch out in neutral, Sport +, exhaust valves set to full open all the time via the Dahler controller, and the exhaust gets much quieter until I clutch in.
08-22-2024, 12:15 PM | #13 |
Rep 128
Agree with the above. It's 100% not the valves or ASD. I have ASD coded off and my valves are open at all times. Definitely for clutch engagement from a stop.
I think it's fun to quickly clutch in and out at a light to make my wife roll her eyes. |
08-22-2024, 02:50 PM | #14 |
Christmas Poo
1474
Rep 1,363
This. These cars have anti-stall. Let the clutch out with no gas, it doesn't stall and car will idle at 4 MPH, Gear Change assist on or off. So if you have rough 1st gear engagements, let the car do it.
Drive the Manual - 2024 G87 - Mr. Hankey's M2 Build Thread
mrcheyl226.00 |
08-26-2024, 01:57 PM | #15 |
Rep 66
While getting some exhaust clips yesterday, I noticed that the turbos spool up when revving while the clutch is pressed and in first (compared to revving in neutral). I've got a non-res AA EL and SST controller.
