08-21-2024, 02:53 PM | #1 |
8135
Rep 10,613
I've seen so many videos with varying processes and steps so I'm curious what my fellow DIY BMW guys are doing as far as ceramic coating or PPF prep process.
What I'm thinking for a brand new car: - Rinse (or apply the foam on a dry car?) - Foam (Gyeon Foam) - Hand wash bucket with the same soap (Gyeon Bathe) - Rinse - Iron remover spray - Rinse - Clay decon towel with wash bucket soap (or buy a clay lube) - Rinse - Dry - Polish - Prep spray - Apply coating/PPF So many variables on when to do each step. So, what's your process? |
08-21-2024, 03:19 PM | #3 |
8135
Rep 10,613
I can do that. I have Gyeon Foam and CarPro Descale.
08-21-2024, 04:07 PM | #4 |
Rep 1,196
You want to prefoam the car dry as prerinsing hinders prefoam ability.
You also have to prefoam with something meant for prefoam or will actually break down road grime. You'd be surprised how many prefoams do nothing. You could use the chemical decon if you wish but if you're going to clay bar, and polish it probably doesn't matter. You also don't need to prep spray twice unless you're using something that leaves residue for lubricant. |
Game8134.50 |
08-21-2024, 04:24 PM | #5 | |
8135
Rep 10,613
2 . Can I apply the chemical decon prior to foaming? So essentially on a dry and dirty car. |
08-21-2024, 04:58 PM | #6 | |
Rep 1,196
Yes, but not in direct sunlight. Just make sure the spray is safe on paint - there are stronger formulas meant exclusively for wheels. |
08-21-2024, 05:37 PM | #7 | |
8135
Rep 10,613
As far as Iron product, it'll be Gyeon Iron. For the record, last year I ceramic coated my G87 with CarPro's acidic Descale (I put it in my foam cannon) and then did a chemical decon...no claying and had no issues but every video I come across I'm seeing the use of clay on top of the iron remover. |
08-21-2024, 06:01 PM | #8 | |
Rep 1,196
I'm not as experienced as some but I've slowly elevated my DIY detailing over the past decade or so and I don't know if I'm jaded or just woken up to the shill but things can be as simple or complicated as you want it to be. A lot of people making those videos are trying to make money selling you products. AMMO NYC and Forensic Detailing are my go tos that have withstood the test of time. I think Forensic actually has a test on coating with and without decon - just search his channel. Scott HD had really good testing on coatings but unfortunately he's taken a break after his mom's passing. |
08-21-2024, 06:21 PM | #9 |
Rep 589
This was my process (no ppf):
1) Rinse the car. 2) Decontaminate with Iron-x. 3) Wash and Rinse throughly. Dry. 4) Clay bar the car. 5) Wash and rinse, then dry again. 6)Using an Orange CSS pad, with Wolfgang total swirl remover and a porter cable polisher, go over the entire car. 7) Remove any residue from swirl remover. 8) Using a white CSS pad, and Wolfgang polish and porter cable, go over the entire car. 9) Wash the car and dry it again. 9a) Dry thoroughly. 10) Apply ceramic coating per recommended spec’s. and remove. 11) Leave car in garage for 12-24 hours to cure. Enjoy! Last edited by mcsquared; 08-21-2024 at 09:25 PM.. |
Game8134.50 |
08-21-2024, 09:19 PM | #11 |
Rep 1,210
Do not wax/ceramic coat the car before you PPF. If you are going to polish before PPF, make sure it has no wax/coating in it.
If you are going PPF, you want nothing betwenn the clear coat and the PPF. No wax/coating or any other substance. So wash it thoroughly (without adding wax/coating), claybar, rinse it and then PPF. |
08-21-2024, 09:23 PM | #12 |
Rep 589
Added a couple of extra steps. But yeah, complete decon because there’s a lot of iron on the car from all the traveling. Especially the wheels!
It took me a couple of days to do it all, but, after a year, the ceramic coat is holding strong. I just washed the car last night, bugs just don’t stick. |
08-21-2024, 10:21 PM | #13 |
Rep 180
I think you had it pretty much square from the top, Game.
I wouldn't bother pampering on the last drying step with the prep spray but to each his own. That is the step where I use the car dryer to get rid of all the water in all the hiding places. I usually let my house cars sit overnight to evaporate the residual water. If you hit a water spot while polishing( water pops out from the DA vibrations ) it will render the pad useless from diluting the polish/compound. So more than enough pads keeps things flowing. Wipe pad with microfiber to rid of spent polish and clearcoat between passes. |
Game8134.50 |
08-21-2024, 10:54 PM | #14 | |||
8135
Rep 10,613
Yes of course that goes without saying. Quote:
Definitely going to decon but to clay a dirty car wouldn’t make much sense. You need to get off all or the dirt and debris before you clay. Quote:
I’ll probably hit it with my air blaster to ensure it’s dry if I decide to polish that same night. |
