      08-22-2024, 10:31 AM   #1
shehatezme
Drives: G87 M2 6mt
Hi guys,
I notice a yellow color on my bottom radiator. It’s dry, curious if you guys think it was leaking at some point or it just brush against a speed bump that’s yellow?
I have a mishimoto skid plate that I haven’t installed yet. Maybe I should throw it on.
      08-22-2024, 11:09 AM   #2
DailyDownshift
Battle Tactician
DailyDownshift's Avatar
Drives: TR G87
Does look like a very very small leak. I would get that checked out.
YouTube & IG: @Dailydownshift
Current: TR G87 Stick
Previous: LBB 16' M2 | 20' Corvette C8 | AW 18' M2 | AW 20' M2c |
      08-22-2024, 11:20 AM   #3
two_three_two
Drives: BSM G87, Mk4 R32
i mean, look at the deformed fin where the right hand stain is. its definitely a small leak and you will likely need to replace.
also, not a radiator, its an oil cooler which unfortunately means this may or may not be urgent
Tag21045.00
      08-22-2024, 11:42 AM   #4
Ravenseal
Ravenseal's Avatar
Drives: 2023 M2 6MT
^As said. This is your engine oil cooler. Your radiator is far behind the front bumper.
Retired: 2022 M240i xDrive | 2021 Audi RS5 | 2019 Camaro 2SS 1LE 6MT | 2016 428i GC | 2011 BMW 335is
      08-22-2024, 11:58 AM   #5
Bumpinjeep
Bumpinjeep's Avatar
Drives: 2023 M2
2023 M2  [8.43]
I would either drive it slowly and keep an eye on the engine temp or tow it to the dealer. The last thing you need is your motor to overheat and cause damage. It's very expensive to replace the motor, so honestly, keep an eye on it. Hopefully this is something faulty and a warranty fix and not something that needs fixing out of pocket.
Present BMW: 2023 M2 BSM W/Carbon everything, 6 Speed
Past BMWs: 2020 M2C HS Executive, 6 Speed
2017 M3 YMB Executive, 6 Speed, ZCP
Everything else: 2024 Wrangler 4Xe
2020 MK 7.5 GTI
      08-22-2024, 12:01 PM   #6
DomMuc
DomMuc's Avatar
Germany
743
clean it .. drive it for 20 min check it again.. if it is yellowish again -- you need a new oilcooler
M24ary6.00
      08-22-2024, 12:02 PM   #7
Tag
this is the way
Tag's Avatar
21045
Drives: N-1 starfighter
They'll say it's damage caused by road hazard, won't be covered under warranty. BTW, the last person that had their engine seize up from loss of oil ended up having their car totaled by insurance.
      08-22-2024, 12:04 PM   #8
KC87ZB
KC87ZB's Avatar
501
Drives: 2023 M2
2023 BMW M2  [10.00]
You don't need to even clean it. You need a new oil cooler. You don't need to even take it to the dealer to determine that since it is leaking oil.
2023 M2
2014 Triumph Trophy
      08-22-2024, 12:17 PM   #9
Carefree
Drives: M240i, M2
That’s what many of us would call “bad timing”.
      08-22-2024, 12:30 PM   #10
two_three_two
"hey, that horse looks awfully familiar... i wonder if my barn is locked?"
      08-22-2024, 12:42 PM   #11
ourlee
ourlee's Avatar
2029
Drives: 25 Grigio G87
Suddenly $465 feels a bargain.
      08-22-2024, 01:00 PM   #12
M_Power Rob
Drives: '23 M240 and '23 M2
Hi guys,
That is your oil cooler, and yes, it has been compromised. I would have it replaced asap. As BMW won't do as a warranty replacement, I would so to a trusted shop and replace with a Carbahn or CSF oil cooler (I prefer Carbahn). Oh, and yes, have the skid plate installed at the same time.
      08-22-2024, 01:07 PM   #13
Bret
Drives: 2017 Jaguar F-Type
shehatezme, has your car had its break-in service? I'm just curious because it would create another issue if not. I do appreciate your post as it has motivated me to purchase a skid plate for my yet to be delivered M2. BTW, I'd call it a radiator too as it literally radiates heat from oil, though I do understand that the nomenclature must exist to differentiate similarly functioning items.
I'm not familiar with the layout of the engine compartment, so I have a question for those who are. Would this repair require draining the oil via the oil pan first?
      08-22-2024, 01:26 PM   #14
shehatezme
Drives: G87 M2 6mt
The car has had its break in service completed already.
Thanks guys will clean it today and see it it get yellow again. Car is not over heating or anything. Will keep everyone posted. I haven’t driven the car in 3 weeks and just noticed this.
      08-22-2024, 01:28 PM   #15
TallGibbs
Drives: 2024 M2 (coming Sep '24)
shehatezme
Most of these aftermarket coolers already have a protective screen built into them so consider that with how it would interact with a skid plate (may have interferences or may not skid plate all).
Car History (oldest to newest): Accord, 318i, 330i, Prius, Prius, M2
      08-22-2024, 01:31 PM   #16
Tag
this is the way
Tag's Avatar
21045
No, but there will be some oil lost replacing the oil cooler. It just needs to be topped off.
      08-22-2024, 01:40 PM   #17
Tag
this is the way
Tag's Avatar
21045
shehatezme, from the looks of it I'd say you ran over something. You can see a clear line of damage to the oil cooler. It needs to be replaced.
      08-22-2024, 02:06 PM   #18
M_Power Rob
Are you asking where the oil cooler is located? If so, it's on the underside ,just behind the OEM "splitter" facing daw aka parallel to the ground (very front part of the undercarraige...there are plenty of posts showing pictures as well as googling).
      08-22-2024, 02:08 PM   #19
M_Power Rob
Depending on the number of miles since the breakin change, you may just want to do a full oil & filter change (depending on the shop you go to, they may require it).
      08-22-2024, 02:11 PM   #20
M_Power Rob
Originally Posted by TallGibbs View Post
shehatezme
I have the CSF oil cooler and Mishi skid plate. Regardless of what comes with the cooler, install the skid plate.
      08-22-2024, 02:15 PM   #21
dienstag
This thread has inspired me to get off my butt and install the zunsport screen that has been sitting in my garage for a month.
BroDoze2802.00
NewToM1854.50
      08-22-2024, 02:23 PM   #22
M_Power Rob
Isn't doing any good there.
NewToM1854.50
