08-23-2024, 08:57 PM | #1 |
Rep 1
2024 G87 Door not Aligned
Hey G87/G42 owners,
I took delivery of my M2 last week and I noticed that the driver side door is not aligned when the closed. But passenger side is perfectly fine. Does your G87 also have door/body alignment issues? Will the dealer be able to fix it? |
08-24-2024, 12:23 AM | #3 | |
Rep 3,865
Rubber mallet. I wouldn't have the dealership mess with something like that, will most likely go downhill fast. |
08-28-2024, 02:28 AM | #4 |
Rep 92
Mine was exactly the same, drivers door (UK), was sitting a fraction too high.
The door catch loop thing in the door jamb is adjustable, it’s a larger torx screw, T40 I think. The latch even has lines to gauge how far up/down you’ve moved it. I think I moved mine two marks down and now it’s perfect, no need for the dealer. |
08-28-2024, 08:59 AM | #5 |
Rep 755
Now to throw a wrench into this whole topic...
https://x3.xbimmers.com/forums/showthread.php?t=1976150 This post, specifically: https://x3.xbimmers.com/forums/showp...79&postcount=9 I know it's an X3 forum, but someone posted an image with an adjustment guide, and it states that "protrusion is recommended ..." Not sure if I'm interpreting this correctly, or where that image even came from, but is it possible this slight "misalignment" is desirable / within spec? |
08-28-2024, 09:30 AM | #6 |
Rep 450
It might be to reduce wind noise? I assume if the rear door’s leading edge was flush or protruding compared to the front door’s trailing edge, it’d probably make a bit more wind noise. Just guessing
08-28-2024, 09:52 AM | #7 | |
Rep 1,852
Some owners were so bothered by this they adjusted the front trunk height to be flush with the front bumper cover trailing edge. Wind noise and water intrusion into the front trunk was the result. |
