BMW M2 Forums 2023+ (G87) Engine, Exhaust, Drivetrain, Tuning Modifications
      08-29-2024, 06:56 AM   #1
Fastfwd
Drives: '24 G87 M2
Aftermarket Exhaust Rattles?
I'm just curious after watching a few installation videos on Youtube for aftermarket exhaust systems if some of these are known to rattle after a while?
Basically, it looks like you're cutting up your solid fully welded exhaust system and depending on how much you are cutting out you are adding multiple joints with nuts and bolts holding those joints together.
Does that become a hassle to keep those joints tightened up over time?
      08-29-2024, 01:03 PM   #2
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
Cutting the exhaust and using clamps to connect it is not an issue. I have been doing it on my cars for over 15 years, and so have countless others.
As for the rattle, that depends on the exhaust you are getting. Some of them are known to cause this sound, others dont.
Let me know which exhaust you are interested in and i will give you my honest opinion
https://x-ph.com/sale/
Phone number 702-494-9435
      08-31-2024, 03:44 PM   #3
Info@mad-us.com
Info@mad-us.com's Avatar
3098
Drives: bmw
Bmw themselves has been using the the cut and clamp method for a long time now and they even included cut points on the factory system now. As long as the clamps remain in good condition you really have no worries with clamping on midpipes or axlebacks.
Are you referring to valve rattles? Those seem to be caused by certain midpipe designs.
- Click Here
Performance Parts For Your Bmw At Crazy Low Prices!
Email: info@mad-us.com
      09-01-2024, 03:06 PM   #4
mike@x-ph.com
Originally Posted by Info@mad-us.com View Post
Bmw themselves has been using the the cult and clamp method for a long time now and they even included cut points on the factory system now. As long as the clamps remain in good condition you really have no worries with clamping on midpipes or axlebacks.
+1
the rattle is either caused by certain midpipe designs or the the midpipe hitting the brace
      09-02-2024, 03:38 AM   #5
merk_millie
Drives: G87
Im running Mperformance exhaust with an active autowerke equal length mid pipe and on start up you can hear a slight rattle for a few seconds. Once the idle comes down it'll go away.
      09-04-2024, 10:58 AM   #6
Ehloo
Drives: 15 x5 m
no one has mentioned it yet but the valves are a common problem causing rattling and noises. something about the valve spring either having too much or too little tension. i have heard this in several system. Looks easily fixed with some adjustment
      09-04-2024, 05:26 PM   #7
mike@x-ph.com
good point
