      08-29-2024, 08:11 PM   #1
safal_shres
Drives: 2017 440i M Sport
F33 idrive issue
Hi guys,
I recently got a f33 2017 440i.
I’ve been having some issue with the idrive system. I can’t seem to work with it. And it’s slow especially maps.
I can’t seem to select the different option for the dash like range, date, current consumptions and so on. I can see it in options and can’t tick it.
I tried soft resetting by holding power button for 30s. Still no result.
I do have the amplifier not working. I’m not sure if this is causing this issue. I got it from a dealership, they seem to think it’s cause of the amplifier unit?
Can I get some help if anyone knows? More to BMWs.
      08-30-2024, 05:15 AM   #2
fantanas
Greece
117
Drives: F33 435d
If the amplifier has a short or not working for any other reason, you could be experiencing these symptoms, because the MOST communication ring is broken. You either need a loop connector (in order to get the features back, without the amp working) or get a new amp.
I had similar issues when water got to my amp in the boot and fried it. I replaced the amp and all was working fine. Quite easy to physically replace the amp your self, but I found it tricky to find a used amp (and it will need coding as well).
      09-17-2024, 08:34 PM   #3
safal_shres
Hi,
After ur reply I bought an amp and right now it’s with bmw specialist for coding. Hopefully it will fix the issue. Thanks for heads up
