09-06-2024, 01:35 PM | #1 |
Rep 65
Power increase with mid-pipe and/or downpipe
Wondering what kind of power increase one can expect with a mid-pipe, downpipe, and both. Thinking of AA single mid-pipe and downpipes specifically but I imagine other manufacturers will have similar numbers. Thoughts?
Edit - wondering about increase specifically with stock tune. -Many Thanks Last edited by TrevTrav; 09-06-2024 at 01:46 PM.. |
09-09-2024, 01:18 AM | #2 |
Rep 95
My baseline numbers full stock was
454whp and 407 tq With IRL mid and valve controller 459whp and 430 tq Most single mids should have similar numbers |
Newgenbimmer180.00 reallymarkedup695.50 |
09-09-2024, 12:00 PM | #3 | |
Joint Chiefs of Staff
27252
Rep 196,491
i expect even more HP increase with the downpipes upgrade
09-09-2024, 04:31 PM | #5 | |
Rep 6,528
Unfortunately, you won't see more than 15whp without a tune. The stock computer will likely just lower boost to compensate for the reduced restrictions. They should both have some increased in power. I'd bet the singles out perform the equals but not by a ton until the power levels are increased with a proper tune.
09-09-2024, 07:07 PM | #6 | |
60-130 Enthusiast
1942
Rep 1,016
Thanks for pointing that out. |
09-10-2024, 05:17 PM | #7 | |
Rep 6,528
The single is equal flow for both turbo banks.
rons e921942.00 |
09-10-2024, 05:24 PM | #8 | |
60-130 Enthusiast
1942
Rep 1,016
You'd never know I majored in physics in college for a year. I guess that's what 4 years in private equity does to you. I had equal length on my last M2. In light of recently learned information, I will be going single on the new one. Thank you! |
BradMX5477.00 |
09-10-2024, 06:52 PM | #9 | |
Rep 6,528
Horsepower lovers will tend to go for the x pipe and single.
Newgenbimmer180.00 |
09-15-2024, 03:37 AM | #10 |
Rep 37
09-17-2024, 07:15 PM | #11 |
Rep 6,528
Midpipe only ?
09-27-2024, 12:38 PM | #13 |
Rep 6,528
Tune alone on these cars is big power but the bolts certainly help.
09-27-2024, 03:59 PM | #14 |
Rep 3,661
09-27-2024, 04:49 PM | #15 |
Rep 784
Drives: M2 G87 Brooklyn Grey
M_Power Rob4576.50 |
09-27-2024, 05:01 PM | #16 |
Rep 6,528
Thats MAD POWER
09-27-2024, 08:51 PM | #17 |
Rep 3,661
NewToM1639.00 Info@mad-us.com3112.00 |
09-28-2024, 08:57 PM | #18 |
Rep 354
09-30-2024, 01:01 PM | #19 |
Rep 2,547
I don't know, I'm running the Evolution Racewerks midpipe and crossover pipe. I don't know if there's any more power but my butt dyno thinks that i'm in boost longer. I'm assuming with less backpressure, the turbos spool easier and i'm able to get more useable mid range torque. These are of course simply speculations. I haven't done a pre and post dyno.
Present BMW: 2023 M2 BSM W/Carbon everything, 6 Speed
Past BMWs: 2020 M2C HS Executive, 6 Speed 2017 M3 YMB Executive, 6 Speed, ZCP Everything else: 2024 Wrangler 4Xe 2020 MK 7.5 GTI |
09-30-2024, 02:00 PM | #20 | |
Rep 6,528
10-01-2024, 03:16 AM | #21 |
Rep 109
https://g87.bimmerpost.com/forums/sh....php?t=2135772
I just posted my dyno numbers with a mid pipe only and BMC filters and basically there were no power gain* (or its within the margin of error for a 465whp car). It just sounds pretty sweet. Downpipes would be the biggest gain by removing the primary cat. I'm sure there are dyno numbers floating around online. * I personally wouldn't consider a 10hp increase over stock (a 2.17% increase) a "real power gain". A really cold day could yield better results.
@DutchBoysRacing
10-01-2024, 10:20 AM | #22 | |
Rep 4,362
Steve Dinan said 11rwhp is what the OEM DPs cost |
